Question about Lexmark X3470 All-In-One InkJet Printer
Plastic Strip is out
All of a sudden I started getting Cover Open issue. After resolving that (Thanks to the forum), the cartridge hit one and twice very hard at both side and the plastic strip was out. I tried connecting at few place but didn't work out. It showing a message "Clear the carrier jam and then press start to continue" and gives irritating sound. Please help
  • klc721 Dec 16, 2007
    I too cant get my plastic strip back in it says carrier jammed
  • Lexmark Master
  • 1,113 Answers
Must get the strip threw the sensor slot on print head.
hard to explain, see different model lexmark but same problem
http://www.fixya.com/support/t114418-error_0502
Posted on Jan 03, 2008
Dell AIO 924 Carrier Jam Problem
To clean the encoder strip, perform the following steps:
  1. Power down the printer and unplug the power.
  2. Lift the cover on the printer.
  3. Using a dry, lint free cloth, pinch the encoder strip on the right-hand side of the cartridge carriage and pull your fingers across it toward the right-hand side of the printer99d8177.jpg
Figure 1: The Encoder Strip to the right of the cartridge carrier. The encoder strip is a narrow band of clear plastic and can be difficult to see without direct lighting.
  1. Plug in the printer and power it on.
  2. Open the cover to allow the cartridge carriage to center itself.
  3. Using a dry, lint free cloth, pinch the encoder strip on the left-hand side of the cartridge carriage and pull your fingers across it towards the left-hand side of the printer. 43e0b19.jpg
Figure 2: The encoder strip to the left of the cartridge carrier.
Nov 16, 2008 | Dell 924 All-in-One InkJet Printer
Carrier stall.
There could be 4 possibilities.
1. Ink cartridges lids are open which is not allowing cartridges to move freely.
2. Ink cartridges carriage will not move from its original position(left) when front cover is opened
3. Encoder strip is Dirty.
4. Encoder strip is Out of position.
Solution:
1. Open the front cover and check if ink cartridges lids are properly snapped in.
2. Turn the printer off and pull out the power cable from power socket, open the front cover and manually center the ink cartridges carriage.
Clean the metallic rod inside the printer using WD40 or Kleenex from Left corner to right corner properly.
3. Cleaning the encoder strip:
a. printer should be off and disconnected from power.
b. open the front cover.
c. Using a dry, lint free cloth, pinch the encoder strip on the right-hand side of the cartridge carriage and pull your fingers across it toward the right-hand side of the printer and you can move the cartridges carriage to clean the strip completely.
d. Note: The encoder strip is a narrow band of clear plastic and can be difficult to see without direct lighting running parallel to metallic rod.
e. Close the printer and try again to print.
4. Repositioning the Encoder strip.
a. Remove the power cord from the printer.
b. Open the front cover.
c. Gently slide the ink cartridge carrier to the middle of the printer.
d. Gently move the top part of the printer belt to the right.
e. Using an index finger, gently push encoder strip down and then back up, to get it back into the slot located on the back of the ink cartridge carrier.
f. Gently press the strip first to the rear, and then forward, to ensure that it is seated correctly.
g. Manually move the ink cartridge carrier to the left, then to the right, to check the positioning of the encoder strip.
h. Once the encoder strip has been re-seated, close the scanner lid.
i. Re-connect the power cord to the printer and try again to print.
Incorrect position of encoder strip
Correct position of Encoder strip
Hope it should fix the issue.
Nov 04, 2008 | Dell 962 Photo All-In-One InkJet Printer
Carrier jam on printer
Solution:
Oct 28, 2008 | Dell 924 All-in-One InkJet Printer
Clear carrier jamed
Solution:
Oct 20, 2008 | Dell 924 All-in-One InkJet Printer
Solution:
Sep 01, 2008 | Dell 942 All-In-One InkJet Printer
CLEAR THE CARRIER
Solution:
Aug 19, 2008 | Dell 924 All-in-One InkJet Printer
Printing Problems
to resolve this issue , execute the following steps
1. Unplug the power adapter from the printer
2. open the printer cover and look for the transparent plastic strip behind he cartridge holders, ,wipe the strip using a soft cloth.
3. connect the printer to your computer and on your computer , click on start , All programs , Dell printers, Dell AIO 924 , and then click on All in one center, a new window opens up , Click on maintenance and Troubleshoot tab (which you would find on the top in All in one center)
4.you will get a new box for maintenance and troubleshoot, in that you will get an option, Clean to Fix horizontal Streaks , click on that and it will print a page ..
Follow these steps and it will resolve the issue.
Apr 16, 2008 | Dell 924 All-in-One InkJet Printer
Cartridge stall message
Solution:
Apr 07, 2008 | Dell 922 All-In-One InkJet Printer
Hardware error:0502
Solution:
Apr 05, 2008 | Dell A940 All-In-One InkJet Printer
Cartridge stall
Solution:
Sep 04, 2007 | Dell 924 All-in-One InkJet Printer
Lexmark X3470 All-In-One InkJet Printer Logo
129 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
