Question about Troy-Bilt Pony Garden Tiller
What kind of oil and how much - Troy-Bilt Pony Garden Tiller
What kind of oil goes in the oil fill?
Use standard bar and chain oil...it is for the chain
Jan 06, 2012 | Homelite Garden
For an 80 cc kawasaki dirt bike what kind of oil mixes with the gas and in what ratio and what kind for engine oil?
I WOULD USE AMSOIL,OR RED LINE SYNTHETIC OIL ( WILL MAKE TOP END LAST ALOT LONGER).. AND THE MIX IS 32:1..... AND FOR ENGINE/TRANY OIL YOU CAN USE BEL-RAY ( BEST IN MY OPINION)
May 20, 2010 | Fender 2 Stroke Full 49cc ATV # ATG-47B...
What kind of oil does it use?
Your dodge should use a 5w-30sae oil.I prefer to use a semi synthetic oil it mixes with conventional oil and provides better break down resistance.
May 09, 2010 | 2004 Dodge Stratus
Type of oil filter/amount & grade of oil
Manufacture suggest you use 5w20 oil and the oil filter most common one used is a Fram Filter
Jan 08, 2010 | 2001 Ford Ranger Regular Cab
What kind of oil do I use when replaceing old oil
Air Compressor oil ... in the absence of that (should be available at Auto parts store) 30 weight non detergent oil will do.
Dec 20, 2009 | Air Tools & Compressors
What kind of oil do I put in my Comet AXD2524G-T pump?
If the Comet Pressure Pump Oil is some kind of a
Synthetic Oil that supposed to be extra effecient than
an ordinary oil, then that will cost extra. If that is ordinary multi grade engine oil (SAE 20 - 40), then, you
can buy over the counter. Most synthetic oil have additive that give extra longer life to all moving parts.
Nov 27, 2009 | Plumbing
78' 80cc suzuki
Use 10w40 motor oil in the gear box. Don't use any synthetic oils, oil marked "EC", or oil with "special" additives. Use Two Stroke ENGINE oil in the pump.
Top rating? Thanks!
May 25, 2009 | 1978 Suzuki GT 380
What kind of oil to I put in a Shadow VT1100 94
try using this kind of engine oil..or any brand but with the same property.."Synlube 5w-50 Fully Synthetic Colloidal Gas Engine Oil"....if not this brand....try finding same property.."Synthetic Colloidal Gas Engine oil"
May 20, 2009 | 1994 Honda VT 1100 C Shadow
Troy-Bilt Pony Garden Tiller Logo
125 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
