Ok, so I just found this laptop in my closet and I wanted to see if it still worked. But when I turn it on, the loading screen says that the software didn't load right so I tell it to start for the last safe spot but when I do that the screen goes black and just sits there. Any ideas on what's wrong with it?
Lacking other information due to the fact it has been in your closet, I would suggest re-installing Windows. If this does not work, then you will have to narrow it down to a hardware problem.
ibm thinkpad type: 2652-BVG Issue: Boots up past the thinkpad logo to the bios setup.Has fan error...
(More)
ibm thinkpad type: 2652-BVG Issue: Boots up past the thinkpad logo to the bios setup.Has fan error and 0187 warning.
i am having problems with advent hi-grade green 320 drivers i'v just installed a fresh install of xp...
(More)
i am having problems with advent hi-grade green 320 drivers i'v just installed a fresh install of xp home but iam touble locating driver for this particular model
This is an intermitten problem. Occasionally, when the computer is booted, the screen is dark, as if...
(More)
This is an intermitten problem. Occasionally, when the computer is booted, the screen is dark, as if in sleep mode. Nothing I seem to do will return the screen to normal mode, except for restarting. I can press the correct buttons to get to the re-start menu (Start, up arrow, enter, down arrow, etc) with a black screen, so I know the system is up. Do you know if there has been a similar problem, and hopefully a solution (ie Function keys, etc) that will return the screen to normal mode without rebooting? I have tried all the standard steps for sleep mode, etc. Thanks
