Question about HP Photosmart 2610 All-In-One InkJet Printer
Printer cartridges/bezel cover for memory card slots
Inserted new ink cartidges. Error button flashes saying cartridges not inserted or inserted properly. We took them and cleaned them and have reinserted cartridges several times. Still says no cartridge present.Cover for memory cards came off printer, These cartrdges are new and put them in the proper location
    Novelist:
  • 79 Answers
As per the information provided , u can try to reset the machine by following the undermentioned steps and the link below would also provide some good troubleshooting steps on differnet issues with this printer that will help u maintain the unit in proper manner .
Take out the cartridges from the unit .
Make sure the unit is connected to the wall jack directly without any surge protector.
Unplug the power cord from the back of the unit ( without turning off the unit ) .
Now press the # and 6 key together , while holding these keys down plug in the power cord back into the unit .
5
Do not release the keys after a few seconds u will find te hp logo or bars moving across the screen .wait while the unit turns off.
6
after one minute turn on the prnter . it will go into alligment phase > let it finish .
7
after its done > try to make a copy .
Note - you can also try the Ok n cancel key combination in place of # and 6 .
LINK >>>
https://astro2w18a.cce.hp.com/webclient/Document?docname=c00227106&lc=en&cc=us#N10532
Thanks
Posted on May 30, 2008
Says my Printhead is loose or missing. It say to remove the ink cartidges but I already removed it.
Remove your ink cartridge, use a paper towel, and wipe the cartridge clean of ink, try inserting the cartridge again, sometimes the ink prevents it from reading correctly.
Post if this does not resolve your problem.
Mar 17, 2013 | Office Equipment & Supplies
False ink empty
Are you sure its exclamation mark?..
This warning message related to print head. (warn out). When you are replacing ink tube assembly use dummy print heads to do the priming (new ink tubes are empty & they have to fill with ink)..
Action: Remove all cartridges and print heads, switch on the printer follow the screen message.(Insert cartridges first next dummy print heads).once its recognizes cartridges then it switch over to print heads,insert dummy print heads. Once printer recognized the dummy print heads, printer will perform priming, during priming dummy print heads will filled with respective inks.(follow the display message)Remove dummy print heads & insert normal print heads. Wait till printer recognizes print heads, load the paper & wait till performs the calibration, once calibration is successfully done issue closed.
If calibration not successfully done, check align print out for which print head is not printed properly, replace it..
Pl ensure that minimum 50% ink levels required in cartridges before performing the priming. Best of luck..
Dec 03, 2012 | HP DesignJet 500 InkJet Printer
Brother MF 5440CN USB Printer won't print. Says "Ink Empty Cyn" and then "Ink Empty Yellow" Replace Ink There is ink in the cartridges.
While there may be ink in the cartidges, your printer is getting a signal from the cartidge that it's near empty. There is no real workaround for this; you just have to replace the cartridge(s). If you use a LOT of ink, you might consider installing a CIS (continuous ink system) now made for most printers. You will save a lot of money over time.
What you describe is typical.
Dec 06, 2010 | Brother MFC-5440 Printer
There is a letter E flashing on the quantity display screen and it says that there is no ink when i just put some brand new ones in there.a window popped up saying that the print head has not been inserted...
Check the printerhead if inserted properly inside or it maybe not in proper position just follow the instruction if were the cartridge can insert. Or press the reset button to remove the error flashing on the screen. If the error are not remove try to restart your printer.
May 29, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
No printing
hi,
Check your black ink cartidge. it may be empty.change it with new balck cartridge
this problem may also be due to cartidge holder .
clean cartrideg holder with moist cotton with petrol or some other cleaning liquid as nail polish remover. clean properly the cartirdge socket and mainly the contact point of cartridge socket
Aug 20, 2009 | Lexmark X3650 Printer
How do i change ink cartridge
open the front panel just lift it u can see the catridges inside that
remove those by just pushing them downwards you can see the instructions of how to remove inside itself in a corner of your printer
try it and buy new catridge and replaceit
or else refil it with the proper advicer
thank you
Apr 22, 2009 | Canon Pixma MP500 All-In-One InkJet...
Paper Jam Issue with the HP Deskjet 5440
Clean the contacts on the HP Cartridge. I've had the same error before and i switched it to a fresh new cartridge.. works fine ever since. THen i decided to switch back to the old cartridge, same error as you but i cleaned the contacts on the cartridge, works for a while but done after a week. Problem is that the ribbon circuit is rusted and the printer doesnt recognize the ink anymore.
Also make sure you both have the ink cartridges in place. Make sure it is seated properly inside.
hope this helps!
-levibit-
Mar 20, 2009 | HP Deskjet 5440 InkJet Photo Printer
I have put in new cyan ink cartridge but printer does not recog
are you sure you got the right ink cartidge put in? Also check if you took that piece of plastic that coverred your ink cartridge contact
Mar 20, 2009 | Canon PIXMA MP530 All-In-One InkJet...
HP Photosmart 2610 All-In-One InkJet Printer Logo
mukhtar21 shaikh
mukhtar21 shaikh
