Logitech Harmony One Advanced Universal Remote with Color Touch Screen Logo
Posted on Sep 23, 2009
How di I reset and clear my harmony remote? - Logitech Harmony One Advanced Universal Remote with Color Touch Screen
A
Anonymous
Easy.. Create a new account!
Or, you can delete all of your devices and Activities by clicking on the trash can icons beside them.
Hard reset for harmony 525
There is no such hard reset to this remote control. As soon as you take out the batteries from its compartment, it will reset by itself. Gopakumar Gopalan Google
My logitech harmony 670 remote no longer communicates with my tv
my harmony has a help feature on it have you tried walking through that? if not then after that try to reset the tv within the remote software then try again ok :) good luck with it
My harmony 520 simply stopped working.
Have you tried resetting your Logitech Harmony 520 remote by updating your remote's firmware? Firmware replacement fixes several Harmony problems.
To upgrade or reapply the firmware on your Harmony remote:
  1. Launch the Harmony remote software and log into your account.
  2. Click on the Downloads button at the top-right corner of your screen.
  3. Click on the Firmware button. Follow the onscreen instructions to upgrade the firmware on your Harmony remote.
  4. Once the firmware upgrade is complete, click on the Update Remote button.
I hope that helps.
_____________________________________________
Harmony 520 Manual Download
Logitech Harmony Firmware Update
Harmony Win Software Download
Logitech Harmony Safe Mode Fix
Harmony Remote Glow Light Fix
3helpful
How do I reset the harmony 670 logitech
do a firmware upgrade. this will restore your Harmony remote to factory settings.
1. Log into the Logitech Harmony Remote Software on your computer
5. Test your remote.
Red/ Bright Tint/Color on Sylvania SRCD227
Your Logitech Harmony 550 is able to learn commands that are not included in its command database.
To teach your Harmony 550 a new button follow these steps:
  1. Connect your Harmony remote to your computer to start the Harmony remote control software.
  2. Click Devices.
  3. Click a device.
  4. Select Learn Infrared Commands.
  5. Click Next.
I hope that helps.
Harmony 550 Manual Download
Harmony Mac Software Download
The Logitech Harmony 890 has locked-up on the PVR screen. Any way to reset?
1helpful
NO LCD DISPLAY
1- Remove the battery from the Harmony Remote for 10 seconds and insert it back in, and test the remote to see if the screen is displayed properly. If this does not fix the issue, please proceed with the following steps.
2- Make sure you have the latest Logitech Harmony Software (version 7.6.0) installed on your computer.
3- Connect your Harmony Remote to the computer. Run the Logitech Harmony Remote software on the computer and Login to your account.
4- Click on the "Downloads" button at the top and select "Firmware"
5- Remote will go through the firmware update, which will put the Harmony Remote back to Factory Default with the most updated firmware. Then software will ask you to select "Yes" to update the remote and click on "Next" to do a remote update, which will take the information on your account with your Devices and Activities and bring them into the Harmony Remote.
6- If this Firmware Update process does not fix the LCD screen issue, try doing a Firmware Update in "Safe Mode". To do this; remove the battery from the remote, press and hold the "Off" button on the top of the Harmony Remote and insert the battery back in to the Harmony Remote. Screen will display "Safe Mode" and then please follow the steps 3 through 5 again.
On the screen of the Harmony520, it just saids Harmony and nothing else and i can't acsess anything. how do i get out of this?
I hope that helps.
I have the same problem
Hey!
I had this same issue with my Harmony Remote. Logitech sent be these steps and they got it working right!!!
1) Remove the battery from the Harmony Remote for 10 seconds and reinsert it. If this does not resolve the issue, please continue troubleshooting.
2) Ensure you have the latest version of the Harmony Remote Software (7.7).
3) Update the firmware on the Harmony Remote. The following link shows how to complete this task:
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=10747
4) Try putting the Harmony Remote in safe mode and complete the firmware update again. The following are the steps to accomplish this:
a) Remove the battery from the Harmony Remote.
b) Press and hold the power button while reinserting the battery into the Harmony Remote.
c) To get out of safe mode, remove the battery for 10 seconds and reinsert it into the Harmony Remote.
I hope this gets the display on your Harmony Remote working too!!!
-Kennedy
Changes 2 channels at a time
I can help you with your Logitech Harmony 890 remote control.
The Logitech Harmony 890 remote control is programmed through the
Harmony Windows Setup Software.
I recommend resetting it up with your components to get rid of the two channel problem.
Once installed, you will simply run the program and select the devices you would like to control from menus. This program finds the right codes for you and loads them into your remote control.
You can get a copy of the Harmony 890 Manual by clicking here.
I hope that helps.
Harmony 890 Manual Download
Harmony MAC Software Download
Top Logitech Televison & Video Experts
 Grubhead
Grubhead
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
