Question about Daewoo Washing Machines
I don't have space in my kitchen and i intend to install the washing machine F1013'S. Can i install it in a close place(between block work)right & left:1cm; rear: 5cm; top :2cm
  • Daewoo Master
  • 3,361 Answers
Yes.
Posted on Sep 23, 2009
Kitchen aid dishwasher whisper quiet model door stuck closed
I found this on another site hope it works for you.Take a bamboo shishkabob skewer and look were the handle is underneath the plastic console head unit and place the skewer on the right hand side... angle towards the center of the console and wiggle it in and push up...After i thought of the skewer it took me around a minute to push the latch up.
Read more: http://appliancejunk.com/forums/index.php?topic=5096.0#ixzz3Yhgf8Ihd
Feb 24, 2015 | KitchenAid Kitchen-Aid KUDD03DTSS...
Fire Safety Concerns
Check this link; http://www.selectappliance.com/exec/ce-product/ry_ryc168 The wok model is approved for zero clearance installation by the AGA and CGA. That means that regardless of worktop etc material, it can be right next to the unit, so long as you do not modify the casing of the unit in any way. here's the link to contact the AGA if you want more info; http://www.aga.org/contactus.htm The other thing to try if you want reassurance would be to knock up a simulated worktop out of cheap wood/plywood just to represent the bit near the range, and use it carefully for a couple of days just to see if there is any problem. It should be fine. Hope this helps :)
Jul 31, 2007 | Robert Yick Co. RanRYC168 Gas Kitchen...
Leveling kenmore elite front loader
  • Place the level on the top of the washing machineicon1.png to see if it is level. Make sure you test it side to side and front to back.
    Pull the washing machine away from any walls if you have to make an adjustment to the legs.
  • Lift the washericon1.png and place the wood block underneath the washer. Place the block near the leg that needs to be adjusted, but don't let it obstruct the leg.
  • Loosen the nut that secures the legicon1.png with the wrench.
  • Raise the height of the leg by twisting it to the left, or lower the height by twisting it to the right.
  • Remove the block of wood from under the washer and recheck the machine with the level.
  • Raise or lower the leg if additional adjustments are needed.
  • Tighten the nut on the leg with the wrench when the machine is level.
  • Repeat the process for each leg that needs to be adjusted.
  • Move the washer back into position and check with the level again to make sure the washer remains stable to finish leveling the machine.
    Regards,
    Richard Roth
    http://appliancecafe.com
  • Nov 13, 2012 | Kenmore Elite 45986 Front Load Washer
    Samsung Intellect Washing Machine SW55APP2 It was running and stopped suddenly displaying error code "dE".
    Possible solution - Check under the lid on the right-hand side about halfway. There should be a white plastic looking block slotted onto a couple of clips. This is the magnet that triggers the lid closed sensor. If it is out of place you will get this issue. Just fixed mine with exact same problem. Make sure it is slotted correctly into the grooves, Should sit flush. Good luck !
    May 27, 2011 | Washing Machines
    Kenmore HE2 plus 11047532601
    If it's stackable, you'll want to start by removing the dryer.
    Open the door and remove the outer bellow spring around the bellow to release it from the cabinet lip. At this point lean the machine back to give more space between the drum and the cabinet.
    Remove the kickplate for easier access and to visually check for leaks later.
    At the top/right of the bellows (close to the tub) loosen the bellow to tub clamp and pull out the bellow.
    Install the new bellow starting at the top by aligning the marks. Work your way around until bellows is properly seated snug against the tub.
    Replace the tub to bellow clamp and tighten it (make sure the bellow stays snug against the tub while tightening the clamp). Once in place, lay the machine back to level and reinstall the front of the bellows to the cabinet with the outer bellow spring clamp.
    With towels handy (just in case), let the machine fill and agitate for a few minutes and check for water leaks. If all is well, re-install the kickplate and wash some laundry.
    Feb 22, 2009 | Kenmore Elite 45986 Front Load Washer
    Can a dish washer be installed in a corner of my kitchen cabinets
    It depends on you kitchen layout. If it is small and you need a place to install the dishwasher, the corner is fine. It is no different than placing a sink, wall oven, or refridgerator there. I have done all of the above, and they were not in small kitchens.
    Dec 09, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
    Haier washing machine E2 error
    normally pump filter is the best place to start it could be jamed with a coin or hair clip if you take machine outside and empty it then lay it on its side you can access the pump take it off then stand up the machine and pour hot water into the soap draw check water should run out of bottom freely taking any fluff or bits with it now take apart the pump and clean it all out dry all components before reasembly if the machine still doesent wory could need a new pump
    Sep 07, 2008 | Haier XQG50-11 Front Load Washer / Dryer
    LG Fuzzy Logic
    Place a piece of magnetic material at the edge of the lid, for the wf-s6697tc model.
    Standing in front of the washer, it is slightly off centre to the right (at the edge where the lid covers, space between the wording speedy soak & fuzzy). If you pay attention to the lid, you might notice some brownish rust stain.
    This is where they place the magnet.
    Feb 01, 2008 | LG WFT1071TP Top Load Washer
    Washing machine
    Possible your inlet valve is clogged. Plug off the wall; close your inlet valve to the machine;(this is the place water comes in from your supply to the machine) examine, could be blocked with dirt or something, clean, refit. Open the valve, appropriate pressure shd be there. Try the machine.
    Sep 24, 2006 | Siemens WFXD8400UC Front Load Washer
    Washing Machines Logo
    Top Daewoo Washing Machines Experts
    dweatherby
    Are you a Daewoo Washing Machine Expert? Answer questions, earn points and help others
