Question about InFocus ScreenPlay 61" Rear Projection HDTV
Round black spot in middle of the picture/screen
Dark picture, tried picture settings, changed bulb
  • 335 Answers
Hi :-)
The round blotch your seeing on the screen is the melting of an acrylic lens inside the light engine. Its a design flaw which unfortunately Infocus will not stand behind. To fix this problem requires opening the light engine and putting an equivalent lens in place. This task is very involved, but this problem is repairable and you need a glass smith to cut the right size lens from the original.
Posted on Jan 18, 2010
  • 4 more comments
  • Circuit World
    Circuit World Feb 03, 2010
    Do you have any other questions about your TV problem? would would you like more detailed answers and other possible causes?
  • Iain Searcy Jan 11, 2011
    Yes, this happened after replacing the bulb with a new one (off ebay)
    Did the new bulb do this?
  • Iain Searcy Jan 13, 2011
    I Got the burnt lens out . Where would I find a glass smith? I live in Atlanta.
  • jd-audio Jul 16, 2011
    I have the same problem: big round black spot in the middle of the screen 3 houres after lamp replacement. How did you get the lens out and did you already found a new lens or someone to make one?
  • Iain Searcy Jul 18, 2011
    Nothing you can do but buy a new light unit. I took that out and found the one plastic lens. HUGE design flaw!
  • Reid Nov 13, 2011
    Can you give instructions on how to R&R that lens?
Replace the DMD Board
Posted on Nov 06, 2009
  • Alan Quattrache
    Alan Quattrache Oct 20, 2012
    where can i purchase a dmd board with the acrylic lense ?
Dark spot in middle
A plastic prism between the lens and the lamp is melted. can't find part no. PLNS-A056WJN2
Jun 30, 2013 | Sharp XR-10X Multimedia Projector
Black spot in the middle of the screen looks like it has a burned spot
Yes if it uses 3 picture tubes one is burnt dead center--cover the lens one at a time to see which is causing this--permanent damage caused by a arc.
If a newer set you have a display unit with a dead pixel.
Mar 31, 2012 | RCA Televison & Video
I have a hitachi 50vs69a with 2 yellow spots in the middle of the t.v when powerd on.....black when off. these spots almost resemble states...there is also blue splotches in the middle of these spots. any...
Yes, if the spots are round or teardrop it may be burnt picture tubes.
Easy to confirm this by covering lens of tubes one at a time with set on and see which removes the blotches.
What happened in a lot of these sets is the set arcs and burns a black dot dead center in one or all three of the screens of the picture tubes used--fatal case and permanent.
Mar 14, 2012 | Hitachi 50VS69 50" Projection HDTV
My camera has developed small cluster of dark spots on the LCD screen interface, the pictures however are fine with no such marks when developed or viewed on any other media device. At first, It was one...
Mine has been doing this too! The spots are getting so large that it covers 1/4 of the screen. I'm sending mine in to get repaired because it came with a 1 year warrenty.
May 10, 2011 | Olympus SP600UZ Digital Camera
Having a big yellow spot background in the middle of the picture.
Hi , it seems you are experimenting a light engine problem.Here's how your tv works: http://www.youtube.com/watch?v=ZLLHnQ4y-wo Basically there's 3 LCD chips that create the colors and image by blending together.When these chips start to melt you will get those blue spots, pixilation even vertical lines.You will need to replace the light engine. Have a blessed one!
Apr 09, 2010 | Hitachi 50VS69 50" Projection HDTV
Black spot in bottom of tv
I just had my caps replaced and after the tech put it back together there was a spot. He tok the screen off and cleaned the mirrors around the bulb and the large mirrors(they were reaaaalllllly dirty. It did brighten up the picture and it looks crisper, oh and the spot was gone.
P.S.. Like nettiser stated. If it's unde warrenty have them do it. If you drop something "you will be pissed" if you don't !
Aug 10, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Gray spots on screen on a JVC HDILA model HD 56G 787
The HD-ila sets accumulate a lot of dust in the light engine. The worst offender is the little fold mirror just under the lens. I take my set apart about every 8 months or so to clean all the dust from the light tunnel and all lenses, mirrors, diffusers etc. The picture really regains it's pop when this is done. Unless you are a skilled technician though, I would recommend against attemptimg this procedure as you need to disconnect the individual color lcds. Check with a local service center to get it properly cleaned.
Oct 16, 2008 | JVC HD-56FN97 56" Television
Dark spots on tv
I have the same TV, and I was getting the black spots on my screen as well. It is dust settling on the bottom mirror. Yoiu can call Mitsubishi and spend 150-200 on getting it cleaned, or you can do like I did and take the front panel off and the 10 screws around the edge on the back of the black plastic border around the screen. Then lift up gently and have someone hold the screen for you and gently dust the bottom mirror. I did this by myself, but it would be wise to have 2 people do it.
Nov 26, 2007 | Mitsubishi WD-62525 62" Rear Projection...
InFocus ScreenPlay 61" Rear Projection HDTV Logo
1,243 people viewed this question
Top InFocus Televison & Video Experts
rostit
Are you an InFocus Televison and Video Expert? Answer questions, earn points and help others
