Question about KitchenAid KESC307 Electric Kitchen Range
The right front burner light stays on even when I shut the oven off.
  • KitchenAid Master
  • 3,361 Answers
One of your switches is bad. It is not unsafe just annoying. You can open the control panel and remove one PILOT wire from each switch. When the light goes out, that will be the bad switch. Before you do this,turn off the power to the range. After you remove the pilot wire(which controls the light) plug the range back in. If the light is out,that is your bad switch. If the light is not out,unplug the range,replace the wire you removed,then remove the next wire on the next switch. Plug the range back in. Repeat this process until the light goes out. When it does,that is the switch that needs replacing.
Posted on Sep 23, 2009
2 Suggested Answers
jtbjtb
  • 135 Answers
SOURCE: burner light stays on but burner does not work
Replace the burner switch, and you should be back in business. Hope this helps!
Posted on Feb 05, 2009
Oven wont bake
If this is the design that the oven will click to light they generally will preheat but shut down once they go to standard bake. The oven will try three times to relight but then shuts down and will not try to light again until you reset the oven. If this is the case the oven burner itself is usually the problem. the burner comes with the electrode.
Nov 27, 2013 | Whirlpool Ovens
The burner in question is the center back the indicator light stays on even in off mode
u may have a bad switch.. if the light stays on while all burners are off.. u will have to check each switch one by one to get the right one..
Dec 12, 2012 | DCS Professional RDU486GLL 48" Pro-Style...
The burners light indicator stays on even when the burners are turned off
Here is a tip that I wrote about the problem of the cooktop light staying on.
Oven Hot Surface Indicator Light stays on heatman101
Apr 23, 2011 | Microwave Ovens
The light for the right back burner stays on,even though the burner is turned off and is cool
heatman101
Dec 25, 2010 | Microwave Ovens
Range indicator light doesn't shut off
the poles for the light are reversed or miswired
at the selector switch
make sure the light goes back to p1 or p depending on your switch
Oct 09, 2009 | Kitchen Ranges
Hotpoint Glasstop Stove - Burner turns on by itself
I have a GE stove which I purchased in 2004, and it is doing the same. I heard beeping coming from the kitchen in the middle of the night . I went to the kitchen and the oven was on by itself. I have been unplugging it when not using it. Maybe this could be a recall.
Oct 08, 2009 | GE Profile JKP18 Electric Single Oven
Burner light stays on even if burner is off and stays cool
you have the ground wire for that burner on the wrong pin your loosing ground somewhere
so the sensor is reading hot
Sep 26, 2009 | Kitchen Ranges
Burner light stays on but burner does not work
Feb 05, 2009 | GE JBP69 Electric Kitchen Range
Burner will not turn off
I will need the complete model #. There should be a sticker near the bottom front behind the drawer. Can't use the # that is on the owners manual.
Oct 08, 2007 | GE Spectra JBP78 Electric Kitchen Range
Lighting the oven
I have similar problems with several 20-inch Avanti ranges. Solution(s); Get a new range, different brand. Cool the range between lightings.
Dec 21, 2006 | Avanti DG241BS Stainless Steel Gas Kitchen...
KitchenAid KESC307 Electric Kitchen Range Logo
438 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
