Question about Motorola Walkie Talkies 2-Way Radio
T 5950 the unit will receive but will
T 5950 the unit will receive but will not send to my other 2 units ?(midland)
I have a midland 2 way radio trying to transmit and receive without static
If a handheld radios check your battery and/or antenna. Trade with a known good unit to see if the problem is solved with either. A poor battery can often cause static.
If a mobile radio, check your antenna connections and your antenna and coil. This could be a sign of a poor antenna or antenna set-up.
Best regards.
May 15, 2015 | Midland Radio Communications
One walkie talkie will send but not receive
Check your programming, specifically the private line (PL code) settings. This is one problem which can cause the problem you are describing.
Feb 22, 2014 | Midland Radio Midland Gxt 795 Vp4 Radio...
Midland LXT410; one of the units makes a continuous noise when receiving if the volume is turned up louder than 3. It doesn't matter how close or far apart the two units are. We hadn't noticed...
It sounds like a damaged or dirty volume control. I have seen controls where the element inside the control snaps and this sounds like what has happened to your radio. You did not say if the squelch control was set open or closed. If what you are hearing is loud static, I would adjust the squelch control on the radio to see if it stops.
May 27, 2017 | Midland LXT410 (14 Channels) 2-Way Radio
Receivers complain about squeeling noise from my midland 1001z when I transmit. Is this an RF Gain setting problem?
I had the same (squealing) problem on transmit with the Midland 1001Z when I used it indoors as a base unit. The problem was my power supply: it broke into oscillation when drawing more than 150 mA at 13.8V. The 1001Z draws about 150 mA on Receive, and much more (but only about 900 mA) on Transmit. If using the 1001Z as a base unit, I suggest you power it with a fully-charged car battery indoors, or test your power supply to check if it can't supply the required 1 Amp, approx., on Transmit. It's a GREAT radio, just give it a good power supply. My power supply was defective out of the box, but now I have a good one and get great reports on signal strength and audio quality. Remarkable, for the low price and 3 year warranty. Good luck!
--Sky Junkie / Tucson, AZ / USA
Sep 27, 2009 | Midland 1001Z 40-Channels Base CB Radio
Receveing problem
Check to see you have the interference eliminator (aka tone code, PL, private line, CTCSS) programmed correctly to match the other units you are talking with.
May 15, 2009 | Midland LXT410 (14 Channels) 2-Way Radio
Need to make sure programmed
Program the Midland 74-109 Weather Radio
a) Turn unit on. Extend the antenna. Adjust volume up slowly; Do you hear anything? If not, try replacing the 9 volt battery with a fresh one, in the accessible battery compartment underneath the unit. Repeat above steps.
b) If no sound is heard, turn unit over and look for "WEATHER" slide switch on bottom. With unit on & volume adjusted to comfortable hearing level, slowly slide switch down (or up) through various frequencies [1)162.550, 2) 162.400, 3) 162.475, 4) 162.425, 5) 162.450, 6) 162.500, 7) 162.525] until voice transmissions are heard. This should be the closest National Weather Service (NWS) broadcast for your area. Check the NWS website at http://www.nws.noaa.gov/nwr/nwrbro.htm for your state, click on the state name, and look for the site name or site location nearest you. The frequency for that site should be the strongest, and appropriate for your area.
c) You can set the alert tone, for special weather alert broadcasts, on the bottom of the unit on the slide switch marked "ALERT". Set the switch to the desired type of alert: 1) LED [LED on top of unit (marked ALERT) lights up when alert is broadcast-no siren tone/alarm is heard] 2) LED & ALARM [LED lights up and alarm/ siren tone is heard] 3) VOICE [LED on top of unit lights up and voice broadcast is heard, only; no siren tone/alarm is heard].
d) Be sure to press the "ALERT" button on top of the unit and leave the volume at a comfortable listening level to hear weather alerts for your area (Alert LED on top of unit lights up to show Alert function is active). You can test the present volume level by pressing the "TEST" button. Be sure to press the "ALERT" button again after listening to the volume level to re-set the Alert function. You can listen to weather broadcasts anytime, by pressing the "WEATHER" button. After listening, be sure to re-press the "ALERT" button to reset the Alert function.
e) 9 volt battery life should last about 6 to 7 months, depending on how much unit is used an number of alerts received. Replace battery every 6 months, or when you replace your smoke alarm battery, or at beginning and end of daylight savings time. A 12 volt AC adapter to replace the battery, can be used. One should have been supplied with unit. If not, a replacement can be found at Radio Shack.
f) This should complete your Midland Weather Alert Radio Model 74-109 programming.
Apr 09, 2009 | Midland 74-109 Weather Radio
Midland GTX800 "X-Tra Talk" 2-way radios will not transmit
Are you sure that the batteries are running well?
Try using alkaline batteries just for testing.
Jan 17, 2009 | Midland 20-Mile, 22-Channel FRS/GMRS 2-Way...
Uniden hr2510 10 meter lights up, won't transmit or receive
Have you tried a different michrophone. If you have then the radio will have either a cold solder joint on the main board or a transister has gone bad. The unit will require service at a local radio shop or send to Uniden Service center.
Pat N5SLI
Aug 26, 2008 | Midland Amateur&Consumer Radio Replacement...
Midland GXT550VP4 communication problems
Did you use the sub-codes? Where they tested indoors or out?
Dec 23, 2007 | Midland GXT550VP4 (7 Channels) 2-Way Radio
Motorola Walkie Talkies 2-Way Radio Logo
27 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
