Question about Boating
40 hp mariner outboard runs good in gear ,but will shut-off in neutral ,won,t idle
    Champion:
  • 233 Answers
Check Idle Air screw Should Be 1.5 Turns Out From Lightly Seated Full In Position. +- .25
+ Idle Screw On Side Of Carburetor.
Posted on Mar 20, 2013
    Guru:
  • 597 Answers
You need to pull the cover and track where the trottle cable goes to on the motor. If you have someone open and close the throttle while you're watching you will find the linkage that it controls. There should be some kind of an idle ajustment screw there that you can readjust to increase your idle.
Posted on Oct 18, 2009
Yamaha 40 hp outboard
Look below lower mountings you will see the shift rod with along nut and a lock nut,undo long nut,do this with motor in reverse gear,some 40s have a stainless plate cover which you have to remove first
Aug 18, 2014 | Clymer Marine Maintenance and Repair...
Why wont my 50 hp mariner start ?
renew spark plugs,mix up some fresh fuel,put choke on,throttle set at just above idle,pump up fuel bulb by hand till tight,put outboard in a water drum,try pulling or turning on starter till it fires,then push choke in and restart
Jul 25, 2014 | Mercury Gear Set, Complete, Mariner, Force...
Why won't my mercury marine engine not restart after running for 30 or 40 min.
is it cooling ok ? run on hose and check engine block and exhaust plate cool ! water inlets clear and impellor good condition ? compressions all over 100psi ? carbs clean ?
Jul 23, 2014 | Clymer Mercury/Mariner 75-225 HP 4-Stroke...
Yamaha 40 outboard stuck at full throttle won't idle
Sounds like accelerator butterflies are stuck,you probably need a good mechanic to sort this one out.try operate accelerator linkage on carburettors by hand but do not force, take off black air cleaner and spray penetrating oil onto butterfly shafts
Jan 27, 2014 | Clymer Marine Maintenance and Repair...
40hp mariner sluggish
compressions more than 100psi ? carb clean and fuel not older than 5mths ? timing correct ? running on all cylinders ?
Mar 06, 2012 | Light Outboard Motor Boat Bass Fishing...
About 4 yrs old 90? hp 4 stroke outboard runs
ignition timing may be off slightly.
Mar 12, 2010 | Boating
Gear shifter for 40 h. p. mariner outboard
With your lower unit off have someone shift the engine into forward while watching the gear shift select shaft's rotation,let gearshift remain in forward,now place your lower unit in forward and reinstall. In the future just put engine in forward when installing a water pump as there won't be a need to move gearshift
Jul 23, 2009 | 2004 Mercury Mariner
1996 evinrude outboard stalls when put in gear idles good in neutral & runs out good in gear but stalls idling in gear
Start by adjusting your idle mixture screw. Start at 1 1/2 turns out and with the engine in gear at an idle slowly turn the screw clockwise until the engine starts to die, then back off a half turn and that will be your proper setting. If you need to you can bump up your idle stop screw just a touch so it will hold also.
Mar 23, 2009 | Boating
Boating Logo
404 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
