Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
2005 HD dyna superglide custom running great. turned off now wont start. headlight, turnsignals and netural light wont come on. Changed the start and main system relays. checked the ingition plug and battery, security system all good.
  • 986 Answers
So are you getting spark? if not check your coil and electronic ingnition system. that is usally the problem in these cases. best of luck
Posted on Sep 23, 2009
Horn doesn't blow wont crank when ignition turned on a 2003 dyna superglide
Harley horns fail. Replace the horn. If this fault has happened at the same time as engine wont crank then problem with wiring. If not then check starter relay (grey one). Also check ignition switch. Are the head lights coming on when turned on? If so the ignition switch is o/k. Connect a voltmeter to horn to check horn circuit. Accessory fuse 15 Amp supplies horn circuit and brake light and turn signal circuits so if these are working fuse o/k. Ignition/start circuit requires system relay and ECM fuse to be o/k. If fuel pump operates when run switch is activated then system relay o/k. Check start relay and circuit to start button.
Sep 15, 2013 | 2008 Harley Davidson FXD Dyna Super Glide
HD Dyna 2010 Superglide won't start
Hi Clements_car, and the usual suspects are:
1.Ignition/Light Key Switch not in IGNITION position.
2.Engine Stop switch in the OFF position.
3.Discharged battery, loose or corroded connections check negative cable at both ends. (solenoid chatters).
4. Bank Angle Sensor tripped and Ignition/Light Key Switch not cycled to Off and then back to on.
5. Starter control circuit, relay or solenoid faulty.
6. Electric starter shaft pinion gear not engaging or over-running clutch slipping.
7. Security alarm not disarming
For a prime suspect please visit website below and good Luck.
Harley Diagnostic Codes 04 to Present
Set Change Override Transport Harley Security Alarm PIN Code No Key Fob...
Mar 25, 2013 | 2010 Harley Davidson FXDC Dyna Super Glide...
WHAT TYPE VELOSITY OIL FOR 05 HARLEY DYNA SUPERGLIDE SHOULD I USE
Hi Anonymous, depends on the average temperature you expect to be riding in untill your next oil change. Contact your local dealer for advice. HD makes several different grades of oil. If you elect to run HD 20w50 SYN 3, which I highly recomend, then it does not matter what temperature you are going to ride in. As an added bonus they call it SYN 3 because you can run 20w50 in your engine, transmission and primary and it comes in a single container to change all 3. No longer do have to purchase 3 different types of oil for your Harley. Great stuff
Mar 25, 2012 | 2005 Harley Davidson FXD - FXDI Dyna Super...
2007 fxd dyna superglide started running rough after the engine light turned on. makes a loud hissing noise near the fuel tank
The hissing........do this once. turn the bike to the "on" position. Dont start the bike, just turn ity so you can hear the fuel pump engage. After the pump stops, listen really close to the inside of the tank......do you hear anything, like some gas still sprinkling out inside the tank? hopefully, you are at about a half tank or less. You wont hear it with a full tank. need to know where this hissing is from, under or in the tank. you arent going crazy.........yet. :o) I'll keep an eye out for your response.
Aug 30, 2011 | 2007 Harley Davidson FXD Dyna Superglide
Can't ride at night as tail light not working, brake light OK. Is there a switch I'm not seeing or is it supposed to come on and stay on when engine running? Nothing found in owners manual. Simple...
The only switch on your tail light is the ignition switch. Any time your headlight is on, you tail light should be on. Check the bulb first as this is the most common problem. If it still doesn't work, check the contacts in the socket. Next check the wiring.
good luck
steve
Jul 17, 2011 | 2005 Harley Davidson FXD - FXDI Dyna Super...
2003 HD dyna superglide, bike will not idle and
either the idle jet in carb is clogged, and or it is running to lean
Jul 15, 2011 | 2003 Harley Davidson FXD Dyna Super Glide
My speedometer and turn signals and brake light quit working on 2005 Harley dyna superglide
Hi Bdthng, always check fuses and bulbs first, you could have a faulty turn signal module or a bad turn signal button/switch, remove it from the switch housing and check for continuity, check your wiring and connections from the turn signal switch to the turn signal module with a testlite. Make sure all wires are not worn or pinched and connector pins are not corroded, broken, or loose. For a free wiring diagram please visit the website below: Harley Davidson Wiring Diagrams and Schematics
Jul 10, 2011 | 2007 Harley Davidson FXDC Dyna Super Glide...
2005 superglide wont start
Check your batt. cables  good, especi ally the terminal ends. Pull and twist them to make sure they aren't almost burnt or worn into. This same thing happened to my nephew's 1200 Sportster. Pos. cable was almost completely into INSIDE the insulation near the battery terminal.
Sep 23, 2009 | 2005 Harley Davidson FXD - FXDI Dyna Super...
Turn Sigal wont work and headlights dim
You will need to use a test light to verify voltage at the turn signal flasher.
Turn the key on to the run position, car does not need to be started.
Set the turn signal switch to right or left turn, doesn't matter.
Probe the "purple" wire terminal at the flasher unit. If the turn signal switch is working properly, you will have voltage at the flasher unit.
If you do not have voltage, the switch may be the problem, make certain all connectors to the steering column are fully seated and there are no broken wires.
Good luck and let me know.
Regards,
Apr 08, 2009 | 1994 Buick Regal Gran Sport
Lands Phones Logo
35 people viewed this question
Top Harley Davidson Lands Phones Experts
ted dux
WTF Chuck.....
WTF Chuck.....
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
