Question about Dell Dimension 2350 PC Desktop
Turns off after 1-2 mins like it got unpluged dell dimension 2350plus the clip to the heat exchange on top of the cpu broke
  • 3 Answers
Your heatsink clip broke off, so now the heat can't be effectively removed from the cpu. This will cause the cpu to "thermtrip", meaning the computer will cut itself off automatically to prevent damage to the cpu due to overheating. Unfortunately, you may have to replace the motherboard because of that broken part. I suggest Ebay...
Posted on Oct 21, 2009
    Genius:
  • Dell Master
  • 1,479 Answers
It's probably the cpu overheating because of the broken clip. You'll need to buy a new heatsink for the cpu (get some thermal paste at the same time). Take the old one off, clean the compound off the top of the cpu. Put a pea-size blob of thermal paste on the cpu and attach the new heatsink.
Posted on Sep 23, 2009
Why my desk top keep turning off and off by it self
excess heat the cpu needs to be cleaned and the fan removed from the cpu and new lithium grease installed on the back of heat expansion fins. fan replaced back on top after cleaned and turned back on
Dec 13, 2010 | Dell Dimension 4550 PC Desktop
It states cpu fan not on
Hope you can open the CPU and check the CPU fan. Try unplugging the fan power cable on motherboard and inseting again.
If it doesnt solve it, take out the fan (attached to the top of heat sink. Dont take out heat sink) and try with a battery of some 6 volt. Red +ve Black -ve. If it doesnt run, you need to replace that fan.
Aug 08, 2010 | Dell Dimension 2350 PC Desktop
I have a dell dimension 2400. My starts up fine
Most likely a motherboard issue.
Also ensure the CPU Heatsink is firmly attached. If the heatsink is loose, replace the plastic heatsink retainer
If it is secure, then the motherboard is the most likely failure point
http://www.fixya.com/support/r4282412-find_no_post_diagnostic_information_dell
May 19, 2010 | Dell Dimension 2400 PC Desktop
I took out the processor an i'm waiting for another one
Go to a computer-store and buy some "CPU heat paste". You'll need to cover the top of the new CPU with this heat-conducting paste, so that the CPU-generated heat will migratesto the radiator, and the fan on top of the radiator will dissipate the heat.
Apr 07, 2010 | Dell Dimension 2400 PC Desktop
How to remove and replace cpu for dell dimension desktop 2350
the cpu is a intel remove and replace a cpu is very easy
This link may help it is the rong model but dictates the process
You will need to open the case and be carefull of statick
ab510a2.jpg look for the cpu heatsink
Remove the fan unscrwe on the top
then remove the silver part this is held on with clips
gentley remove the cpu and replace new one THE RIGTH WAY look for the corners on the cpu to mach up on the board
Nov 24, 2009 | Dell Dimension 2350 PC Desktop
Alert chipset heat sink not detected system halted error message
It is NOT the CPU fan! There is a heatsink over the northbridge chipset adjacent to the CPU. The clip that supplies pressure to maintain contact between the northbridge and the heatsink has detached on one or both ends. There are wire loops at each end of the clip which feed into the motherboard. When the clip detaches (solder failure), it pops the loop out of the motherboard. The BIOS recognizes this condition as a heatsink failure, hence the error message.
Jul 10, 2009 | Dell Dimension 4600C PC Desktop
My CPU fan for my Dell Dimension 2350 has stopped turning!
If your fan is not turning at all then it is probably dead, the bearings are likely clogged with dust and such. The PC is shutting off because of heat buildup on the processor chip. You need to do an Ebay search for your model and order a fan right away. Continued running of your sysem without a fan will kill the processor and motherboard. You should be able to get a replacement fan for your computer for less than $15 including shipping. Your local computer store may have one to fit your system but they may charge more for it. To change the fan is very easy, the left side of the case will come off your system, right under the power supply is the processor and heatsink and the fan. Disconnect the old fan and reconnect the new unit.
I hope this helps, if so please rate my solution
Buddy
Corporate Computer
WWW.CCL-LA.COM
Jul 02, 2009 | Dell Dimension 2350 PC Desktop
Loose heatsink on dell dimension 1100
I'd seize the opportunity to get a new cheap cooler, as it can also extend the life of the PC.
If not you're in for either some DIY soldering or asking Dell for another clip.
Apr 20, 2009 | NEC CPU Heatsink with Fan CPU Heatsink &...
I have a dell dimension 5150 desktop problem; turn off after 60 minutes working.
Hi, maybe he was over heating, open your tower and look the fan of your CPU and POWER SUPPLY. Did they work? If yes, did the dirt on the heatsink of the cpu hide the heatsink? If yes clean it and make a test!
Oct 29, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell dimension 4700 video card upgrade problem
Be careful with this computer. The cooling system works by blowing air INTO the machine over the cpu then the heat slowly comes out of the holes on the side panel (on the left side of the machine). One reason the text may be blurry is because the video card is heating up too much. This problem is specific to this machine. Most computers have the cooling fan blowing the heat out of the case and not sucking air into the case. On the plus side at least this PC is near silent right? I would know since I own this machine. Amazingly silent it is.
Apr 22, 2008 | Dell Dimension 4700 PC Desktop
Dell Dimension 2350 PC Desktop Logo
408 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
