When I load the drivers for this video card it drops the color on my monitor to low function (4 colors)
  • 63 Answers
On your desktop right click then go into advanced and fix it.
Posted on Sep 27, 2009
My monitor gives 16-bit color at 640x480, but will only offer 256 colors at 1024x768 -- and only displays 16 colors when I select that... In order to access resolution options, I have to go into Advanced...
The monitor has no influence here - something is wrong with your video card: either its driver is missing (or corrupted) or the video chip has failed.
Uninstall all the drivers for the video(except the generic VGA one), from Programs and Device Manager
http://pcsupport.about.com/od/windows7/f/open-device-manager-windows-7.htm
and reboot several times then go to Dell
http://support.dell.com/support/downloads/index.aspx?c=us&cs=19&l=en&s=dhs
select your pc and get the correct driver.
If that doesn't fixes it then the video chip has failed, you will need to buy a new video card.
Aug 02, 2011 | Dell Dimension 4600 PC Desktop
I am using a compaq 1701 flat panel monitor. I installed windows Xp. The screen resolution is $4 bit color coz the driver is not installed. Looking for the driver for compaq 1701 flat panel monitor for...
The screen resolution and bit color is controlled by the video driver NOT by a driver for the monitor.
Install the correct video driver for your video card and you will be able to increase the screen resolution to over 1024 X 768 and bit color to at least 32 bits.
Jul 21, 2011 | HP Compaq 1701 17" Flat Panel LCD Monitor
My monitor setting will not stay set on 32bit, it keep on going back to an low 8 bit setting that cause my colors to be off. How can I make this stay on the 32 bit. I have a Phillips 107MB 17 inch/CM2300...
The color bit depth is controlled by your PC Video card, monitor will show what it is being fed with. Please check to see if you have correct video card driver installed in your PC and the video card has enough memory to provide the 32bit color depth.
Jun 27, 2010 | Philips 107E61 17" CRT Monitor
The monitor only displays either 1920x1080 resolution with Low (8 bit) color or 800x600 with High (32 bit) color. I have uninstalled the video card and monitor drivers and reinstalled them a million...
It appears that your video card does not support that resolution and color depth. If you've installed all of the proper drivers from the manufacturer, re-check the maximum specs - sounds like you're looking for HD (1080) and the card can't deliver in full color (32 bit).
Jun 07, 2009 | Computers & Internet
Where can I find the driver for a Princeton VL1919 monitor
Princeton Graphics VL2018W monitor does not require any drivers to function. If you have problems changing resolutions, color depth, or refresh rates, Please consult your video card manufacturer for a video driver or support. Your system will not identify the monitor if video drivers is not installed properly. I agree with this statement. You dont need drivers for monitors 99.9% of the time. Usually you video card is what is wrong if u cant change the resolution.
Jun 05, 2009 | Princeton Digital VL1919 19" Monitor
My Computer Becomes 4 Color
Uninstall the video driver in safe mode. Run driver sweeper in safe mode as well, cleaning out nvidia drivers. (download it off the internet, use safe mode with networking so you can access the internet) Now, reboot back into normal mode in Windows. It will prompt to install the video card, cancel it. Download Nvidia driver 181.20 and install it, rebooting when it asks you to. Once you reboot back into Windows, your problem should be solved.
If this does not do it, make sure your monitor driver in Device Manager is set to "Plug and Play Monitor".
Jan 11, 2009 | ASUS P4S800-MX Motherboard
Can't get improved resolution
You need to download the most recent video driver for the video card in the computer. Open it up, look at the video card and then google the name of the card for the latest windows xp driver.
May 05, 2017 | ViewSonic G810 21" CRT Monitor
Monitor color display problem
Go to the control panel. Click on display. The display applet is your next stop. The display applet is your central location for all of your display settings, including resolution, refresh rate, driver info., and color depth. The display applet has 5 tabs: Thmes, Desktop, Screen Saver, Appearance, and Settings. The 5th tab is where you make adjustments that relate directly to your monitor and video card. Look at the Settings tab. At the bottom of the dialog box, you'll see 2 options. Screen Resolution and Color Quality. By moving the Screen Resolution slider, you can change the resolution. The most common resolutions are 640x480, 800x600, 1,024x768, and 1,280x1,024.Your system may have more or fewer resolution options.
The color quality is the number of colors displayed on the screen .You can change the screen resolution with a simple slider and adjust the color depth from 4-bit all the way up to 32-bit color.
Running a 32-bit color gives a nice, realistic tone to images, and many games insist on it.
Clicking the Advance button opens another dialog box with 4 or more tabs.
The monitor tab gives you details about the currently installed monitor and enables you to make changes to the driver and the refresh rate.
After you make your changes to your monitor and it still is not working properly, it must be your video card which is not seated.
In layman term, your video card is not plugged in firmly in the slot!!
Jul 11, 2008 | Acer X193W LCD Monitor
Can not load f1903 software on microsoft xp system
This has nothing to do with your monitor. Windows has default drivers that will be installed for that.
The problem will be your video card drivers are not installed.
Get the right drivers for your card, install them and you should be away.
Mar 29, 2008 | HP Pavilion F1903 19" Flat Panel LCD...
Driver downloads
http://www.princetongraphics.com/site/support_drv.htm
NOTICE: Your monitor does not require any drivers to function. If you have problems changing resolutions, color depth, or refresh rates, Please consult your video card manufacturer for a video driver or support. Your system will not identify the monitor if video drivers is not installed properly.
You might want to check your video card drivers. Hope this helps.
Mar 25, 2008 | Princeton Digital VL1918 Monitor
Computers & Internet Logo
53 people viewed this question
David Payne
David Payne
