RIM BlackBerry Curve 8310 Smartphone Logo
Posted on Sep 23, 2009
My trackball on my blackberry curve works on everything but the mailbox what could be causing this?
Anonymous
Level 1:
New Friend:
  • Contributor 32 Answers
  • Posted on Mar 14, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
32
Questions
0
Helped
5458
Points
33
This may be problem with the software, try the easy way: hard reset. To do this manually, just remove the battery and restart the phone. good luck.
Blackberry curve 8330 keyboard and trackball doesn't work
Your trackball and the keyboard seems not working. You may need a replacement for both parts.
My blackberry scroll pad is not working, and i can't scroll anywhere. i took it to the shop and the man told me it was a hardware problem, i have pop reset it and soft reset it and nothing seems to work. i...
hi Titchypink.
this is all i could find out,hope it helps you out.
Trackpad, trackball, or keyboard not working on a BlackBerry smartphone running BlackBerry OS 7.1 and earlier Article Number: 000029640 First Published: April 26, 2017 Last Modified: April 26, 2017 Type: Support
Environment
  • BlackBerry smartphones running BlackBerry OS version 6 to 7.1
  • BlackBerry smartphones running BlackBerry Device Software 5.0
Back to top ?
Overview
In some situations, a BlackBerry smartphone with a trackpad or trackball may experience issues with sensitivity, latency, or scrolling. Additionally, the BlackBerry smartphone keyboard, or other buttons may be unresponsive.
Back to top ?
Cause
This issue might be caused by one of the following:
  1. The trackball/trackpad sensitivity needs to be adjusted.
  2. Make sure the trackball/trackpad is not affected by a software freeze or an application freezing.
  3. The BlackBerry Device Software is out of date and requires an update to resolve the trackpad, trackball or keyboard issue.
  4. The physical trackpad, trackball or keyboard hardware is malfunctioning.
Back to top ?
Resolution
Resolution for Cause 1
Complete the steps in Article 5447 to ensure the trackball/trackpad sensitivity is correctly.
Resolution for Cause 2
For BlackBerry smartphones running BlackBerry OS version 6 to 7.1 using a trackpad, complete the following:
  1. From the Home screen, select Options.
  2. Select Typing and Language.
  3. Select Trackpad Sensitivity.
  4. Ensure Audible Roll is selected.
  5. Rapidly roll the trackpad up, down, right, and left.
  6. If an audible click is heard while not responding, proceed to Resolution for Cause 4 as this could be a software related problem.
For BlackBerry smartphones running BlackBerry Device Software 5.0 using a trackball, complete the following:
  2. Select Screen/Keyboard.
  3. Ensure Trackball Audible Roll is selected.
  4. Rapidly roll the trackball up, down, right, and left.
  5. If an audible click is heard while not responding, proceed to Resolution 4 as this could be a software related problem.
  6. If an audible click is not heard, the problem may be related to a hardware issue. Please contact the wireless service provider for additional steps.
Resolution for Cause 3
To update BlackBerry Device Software using BlackBerry Desktop Software see, Article 11320.
or
To update the BlackBerry Device Software on the BlackBerry smartphone visit http://www.blackberry.com/update/
Use the BlackBerry Virtual Expert diagnostics application. For more information, see Article 35973.if not try this link. blackberry scroll pad is not working Google Search
How to clean up trackball for curve, cause it won't scroll down....only to the left and right...thx
everyone has the same problem with blackberry trackball. i wonder why the rim installed such a hardware in their phone. it makes a lot of trouble.
to fix it simply use a straw, no need ro replace or disassemble the blackberry, read more from the source http://www.unique-stuff.co.cc/fixing_sticky_blackberry_trackball.html
BB Curve 8310 keys and trackball not working
is there a way to navigate thru options with no trackball
Cannot scroll up with my Blackberry Curve 8310 trackball
It is a very common problem. You just need a new trackball. Should be about $25. If you want to make it work temporary, then just removed it and clean the trackball and the phone part under it (on the phone itself) with 99% alcohol. It might work for a while again
2helpful
The tracking ball rotates but it does not move over the icons on the left side. Is there anything I can do to fix this?
Depending on how comfortable you are with removing the trackball it's not hard to fix... you may have some dirt or grit interfering with the trackball and/or sensors. Take a small screwdriver or blade and gently pop the silver ring around the trackball off. This will free the actual trackball housing. Use an old toothbrush to clean everything. I also soaked the trackball in a little rubbing alcohol. Just make sure it is completely dry before reassembling. If that doesn't work you can purchase replacement trackballs from places like crackberry.com.
Trackball on Blackberry curve not moving vertically
you need a new trackball. Contact www.fixphonenow.com they can provide you with a new trackball.
2helpful
6answers
Trackball reinsert blackberry curve 8310
Usually the clips of the chrome ring break and don't snap back into the frontplate. There are :<a href=http://www.portatronics.com/guide/Smartphones-Repair-Guide/>Blackberry Curve Repair Guides</a>online that show you how to disassemble the Curve, if need be.
Top RIM Computers & Internet Experts
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Alexander
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
