Question about Cell Phones
My surround sound is displaying "unlock" when set on Video 2 and I am not getting any sound
I just bought an Onkyo tx-s804 receiver. and some new rear surrounds. Since I am moving, have not set up anything formally, but have plugged my dvd player into the front video 4 input via an optical...
PCM is what it's receiving from the DVD player. The player has output bitstream settings, too, maybe even speaker configurations and distances. Read its manual.
May 11, 2011 | Onkyo TX-SR804 7.1 Channels Receiver
Unable to get surround sound thru all speakers
Some features do not give surround sound such as tuner. If input cables attached to analog dtv/cbl and speaker cables attached to wire end output serround should work fine when set to dtvcbl on front display.
Mar 31, 2011 | Yamaha HTR-5850 Receiver
I have had the Kenwood VR-407 since 2001. I also have a Mitsubishi projection TV, attached to the receiver. When watching regular cable TV (u-verse), I can not get sound from the rear speakers. I am using...
Most TV stations you watch don't send a surround sound mix so you won't get anything in the back speakers. DVDs generally all have a surround mix which is why it sends to all speakers. What you are experiencing is normal, Bob.
Jan 04, 2011 | Kenwood VR-407 Receiver
My surround sound speakers don't work. No power
LCD will display which speakers are active. And this depends on 2 things: the source signal and decoder mode.
If source signal is stereo, only front L+R speakers are used. For 5.1 signal (for example DVD over HDMI / optical/coax spdif) all speakers installed (which are not set to None) are used.
To listen to stereo input signal using all speakers, switch decoder to enhancer mode.
Feb 24, 2010 | Yamaha RX-V457 Receiver
Yamaha HTR-6030: all speaker have sound coming out but it is not true surround. The display only shows front speakers on, how do I get all speakers to come up on the display?
I think you mean the display only shows Front >>Channels<< available.
What source? Digital or analog (analog is only stereo).
Dec 27, 2009 | Yamaha HTR-6030 Receiver
Error s10
Did it ever work properly? If not, let's get down to basics and set it up for the simplest configuration it can have: FM source in stereo with front left and right speakers, no Surround Mode, no DSP, no Tape Monitor, no Mute, Volume not turned all the way down. Does that work?
Do you have Surround Speakers defined in System Setup A? If not, only Dolby Surround or Off are valid Surround Modes.
Is T2 Monitor indicator lit? Press the Tape-2 Monitor.
Is there acceptable sound other than during Speaker testing? NO? Is MUTE On?
Apr 29, 2009 | Onkyo TX-DS838 Receiver
My surround rear spks dont work
The rear speaker decoding has to be enabled for them to function, regardless of the media. Enter the speaker setup menu and choose "yes" for the rear surround speaker decoding.
Mar 10, 2009 | Sony STR-DA3000ES Receiver
My HD only works on my video setting, but I have no sound
Ok so the sound is fine on all of the other sources,
The component is running from the cable box to the amp, and you can see it.
just take the audio Red/Whit RCA out of the cable box, and input it to Cable/TV or whatever its labled, Red White, RCA.
If you want surround, then you will have to go Coaxial((single orange RCA) or TOS out of the cable box to the Digital input on the AMP. When you use this instead of Red White RCA, your amp will automatically switch between the different types of surround depending on what the source calls for or is encoded in.
You may have to get into the amps menu and change that amps input to Digital/Coax/TOS for the surround sound.
Any more specific questions, I need the model #s.
Jan 10, 2009 | Mitsubishi WD52527 52" Projection HDTV
Harmon Kardon unlock error
I have the same problem. All of a sudden no sound through my TV connection (but through the DVD connection the sound was still working). I changed the connection from video 1 to video 2 and got the sound back. It is not a real solution, but a practical one :-)
Apr 13, 2008 | Audio Players & Recorders
Speakers not working
They will only have ambient sound (not same sounds as front speakers). Also for each input (video 1, video 2, dvd, tuner, etc...) you need to choose what surround mode you would like to use via the "Listen Mode" button. There is a little pictogram in the display which indicates which speakers are in use.
Sep 12, 2007 | Arcam AVR-200 Receiver
Cell Phones Logo
23 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
