Question about HP PSC 1315 All-In-One InkJet Printer
I just had my ink cartridge filled by Walgreens and now it only prints bottom part of words instead of the whole word. If I just turn on the printer and print one page it prints fine...more than one page skips part of the word.
    Novelist:
  • 144 Answers
The ink cartridge nozzle might be blocked. check that for cloggage.
Posted on Sep 23, 2009
How do I reset a re-filled HP97 tri-color printer cartridge for an HP 7310 all-in-one printer. I have re-filled the cartridge at walgreens, re-installed the re-filled cartridge, but the diagnostic still...
if it continues to show "empty cartridge" that means. the printer is not accepting the refilled cartridges..
You will have to try with a new genuine HP ink cartridge.
Oct 13, 2010 | HP OfficeJet 7310 All-In-One InkJet...
Printer light keeps flashing and will not print
Use ONLY GENUINE HP ink cartidges. This will fix it.
Jan 04, 2010 | Dymo LabelWriter 310 Printer
Lexmark z705 printing blank envelopes soft ware ok
The problem that you are experiencing is caused by the way the text is formatted in most word processing documents. By default envelopes are printed not in black, but a dark gray. This confuses the printer and causes it to use the color cartridge to process gray instead of using the black cartridge.
You can fix this problem with one of two ways:
1. Click on "Start", "Control Panel" and click on "Printers and Faxes." Right click on the "Lexmark Printer" icon and select "Properties." Click on "Printing Preferences." Go to "Quality/Copies" tab and select the option "Print color images in black and white."
2. You can also change the color of you text to a true black in your word processor. This will require you to resort to the word processor's documentation and help files.
Both of these settings will cause your printer to use the black cartridge instead of the color. If either one of these solutions solves your problem, it means your color cartridge needs to be cleaned or replaced. If you feel that the color cartridge should not be out of ink, please follow the steps given below:
Clean Nozzle Procedure:
1. Go to the "Solution Center" and click on the "Maintenance" tab.
2. Select "Clean to fix horizontal strips."
The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean Print Nozzles" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
“Wicking” Procedure:
1. Select "Install color/black cartridge" and remove the cartridge from the printer.
2. Get a damp paper towel.
3. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.
4. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.
5. Next dab the cartridge on the towel to make sure that the ink is flowing.
6. Snap the cartridge back into the printer.
7. On your computer, select "Old Cartridge installed."
8. Repeat the "Clean to fix horizontal strips" procedure listed above.
If this procedure does not help, please let us know so that we can continue with technical support.
Oct 01, 2009 | Lexmark Z705 Inkjet Printer
Refilled ink cartridges at Walgreens, printer won't recognize
Hello!
28 and 29 are not meant to be refilled. They can physically be refilled, but they won't work. That is because Lexmark has put in a smart chip that doesn't allow refill.
You need to buy 28A and 29A or 34 and 35, those cartridges can be refilled with no problem.
If you find my answer helpful, please vote. Thank you!
Aug 05, 2009 | Lexmark X2550 All-In-One Printer
I replaced a new lexmark 23 print cartridge in my X4530 printer.
This happens from time to time. I have bought new 22 & 23 cartridges for my Lex. x3350 before with "flawed" contacts. Either return it for refund or buy a new one. Thw next working one you get, try re filling it. I get mine refilled at Walgreens. Cost for me in Texas is $10 for black and 15 for color. I refill them 4 times before I replace with new. Saved me a ton of money.
Jul 01, 2009 | Lexmark X4530 InkJet Printer
Deskjet printer cartridge problem - won't print
I was having the same problem and just posted it, went back to my printer, put the old cartriage back in and printed, I am taking the refilled cartriage back to walgreens where I had it filled and buying a new/hp cartriage to install.
Mar 17, 2009 | HP DeskJet F380 All-In-One Printer
Hp deskjet 940c printer
Hi.
I think it must be the ink blow-by, you must clear the ink path through the printer head. Try to activate the cleaning of the head pins. Just go to the printer icon then right click and click the printing preferences then look for the head cleaning menu. then try to print test by doing a cold reset.
Jan 24, 2009 | HP DeskJet 940c InkJet Printer
Ink cartridge
you may check your ink cartridge
long time less using cause 3 color ink chanel(holes) a little dryer, could not print well even refilled.you may take out the color ink cartridge and put it's surface of bottom (just touch ) in the clean water 1 -2 Hrs, then set back and test it. still not fixed, you also need to do same thing if your print head is separated from your ink cartridge
Jan 20, 2009 | Lexmark X75 All-In-One InkJet Printer
Unable to print with new ink carts
Usually, that message means that your cartridge is dead. Try removing it, clean the electric contacts on it and the ones on the cartridge carrier. Put it back in. If that doesn't help, you will need to buy a new color cartridge.
If you do not have a replacement cartridge, you can still print in, what HP calls "ink backup mode". Simply remove the problem cartridge, and print with the remaining one, in this case, the black one.
  • If you remove the tri-color cartridge, printouts will be in grayscale.
Dec 23, 2008 | HP Deskjet D4160 InkJet Photo Printer
Problems printing photos with HP Officejet 7410
copy and paste the link below into your address bar.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00219809&cc=us&lc=en&dlc=en&product=391194&dlc=en&lang=en
you can search for other answers at the top of the page.
Nov 22, 2007 | HP OfficeJet 7410 All-In-One InkJet...
HP PSC 1315 All-In-One InkJet Printer Logo
97 people viewed this question
Seeker5211
Seeker5211
