Question about Boss Music
I have lost the connection diagram for my BOSS NS-2 noise suppression pedal. Can I get a download?
  • Boss Master
  • 5,603 Answers
Here is the retrevo site that has the manual with connection diagram.
http://www.retrevo.com/d/ds/progress?doc=e2d5b73911466148a2b8b5e8a93e4a62
Posted on Sep 25, 2009
How to connect an expression pedal to a Boss gt-3
Just plug FS-5U or FS-5L or EV5 / FV300L (Roland),or other external switch to SUB EXP PEDAL.
You can also use pedal switch that you create by yourself.
Use stereo phone jack and cable.
It can be function for 1 or 2 switch.
Setting function for SUB-EXP-PEDAL is at UTILITY-GLOBAL menu.
You can set switch 1 or 2 for what do you want to function each switch at the external pedal.
If you want to connecting external expression pedal (FV300L),just plug it to SUB-EXP-PEDAL. Setting is same as above.
Aug 31, 2015 | Boss Music
Hello - I have a Boss RC-2 Loop Station. While I enjoy the pedal's capabilities, it almost always creates an unwanted hum and sometimes an electronic pulse in every amp I use it with. (I typically keep...
Make sure the power supply for this is powered from the SAME receptacle as your amplifier is powered. Keep the cable from this to the amp fairly short and high quality cable. Keep guitar away from magnetic field sources... the wall wart adapters are notorious for generating magnetic fields.
Jul 20, 2011 | Roland Boss RC-2 Loop Station Stompbox...
A musician friend of mine asked me to take a look at his pedal. Apparently there are issues with it cutting out. I figure it's just a bad lead connection on either the input or output jack, but...
Diagram is NOT likely to help much. Look for bad soldering at the input and output jacks AND by the power input jacks. Also look for cracked circuit board and or lifted circuit etch. Lastly, the pots and the soldering around them may be part of the problem. Most of the mentioned things are 95% of the problem.
May 18, 2011 | Roland Boss ST-2 Power Stack Distortion...
My OS-2 Distortion pedal will not work. There is current flowing to the battery terminal, there is also contact noise in the output, but none in the input. The red light does not come on when powered and...
Common problem is a broken solder connection where power jack is attached to the circuit board. SOmetimes the circuit board is cracked or solder broken. If board is cracked, jumpers need to be soldlered on to bridge the crack.
May 07, 2011 | Roland Boss OS-2 Overdrive / Distortion...
I have NS-2 Noise Suppressor Pedal, this works fine but in some moment make a radio noise (hum) and the output signal comes down (like turns the volume to 0) ... I don't know what it is, I'm going to...
The probable problem is poor connections at the input and/or audio output jacks.
Usually the power supply will fail either on or off which is sometimes cause by a bad input power jack.
In any case, the problem is likely internal and will require repair.
Aug 06, 2010 | BOSS AUDIO SYSTEMS Boss Ns2 Noise...
Boss noise reduction pedal stopped working for no reason at all. worked fine the day before, went to use today no power at all. it is run from an adaptor so its not the battery, any clue?
The power jack on MANY of the pedals are weak and a yank sideways can damage the jack or the board it is mounted on.
ANOOTHER problem is using an adapter with the wrong size plug. SOME plugs have a larger diameter hole and will work intermittenly.
Oct 05, 2009 | BOSS AUDIO SYSTEMS Boss Ns2 Noise...
How to set up with amp and distortion pedal
With everything switched off. I will surmise that you are using the onboard battery with the foot pedal and not a power supply.
1. Plug lead from guitar/instrument into INPUT side of pedal
2. Plug lead from OUTPUT side of pedal into amplifier INPUT.
3. Turn amplifier volume to about 10 o'clock - to stop blowing your ears out.
4. Turn volume up on guitar to acceptable level.
5. press foot switch on pedal and adjust pedal controls to suit your type of distortion.
6. Play like Hendrix.
Good Luck
ps Just as an after thought rechargeable 9volt batteries are the way to go. I've been using them for years as I always get caught up in the power cable.
If you're going to add another pedal like a Phaser, Compressor, Flanger or what just use small connect leads between each pedal but always, always put the compressor pedal last in the line.
Sep 12, 2009 | BOSS AUDIO SYSTEMS Boss Ns2 Noise...
The treshold needs to be turned all the way up in order to reduce noise..i thought that i must be set in a 9 o'clock position based on the reveiews in youtube.
Yes. Very much so. The noise reduction should be the very last pedal, of course. Try to even plug your chain in a different outlet than the one your amp (or if recording to a computer, different than the computer outlet). If you have a particularly loud distortion, have it be the last one before the noise reduction pedal.
Jul 09, 2009 | BOSS AUDIO SYSTEMS Boss Ns2 Noise...
My Boss DD3 just beeps and nothing else when i turn it on
If you have experience with electronics you could take it apart and use a multimeter. My guess would be one of the delay chips but its something hard to diagnose without taking it apart. An audio tech could help you out. Chances are it would be a pretty cheap fix. Unfortunately Boss pedals are almost entirely surface mount so replacing a component or two takes more skill than the average pedal.
May 16, 2009 | BOSS AUDIO SYSTEMS Boss Dd-3 Digital Delay...
Music Logo
56 people viewed this question
Top Boss Music Experts
Michial Gueffroy
Darial Jr Lasaria
Darial Jr Lasaria
Vito Vacirca Jr.
Are you a Boss Music Expert? Answer questions, earn points and help others
