Question about Lanier Office Equipment & Supplies
Wrench (repair)light is on. It's a Lanier 7313.
  • Lanier Master
  • 1,297 Answers
Set the maintenance counter:perform test command 72.Press C - interrupt key - 0 - interrupt key - 7 - 2 - PSW.The currently set maintenance cycle code is displayed and the ready lamp lights up.After the ready lamp lights up anter the set code corresponding to the maintenance cycle mode.0 = 10000 sheets ; 1= 15000 sheets ;2=30000 sheets.See the toner full detection part and remove the wastw box,change it.Perfor the test command 14.This command used to cancel troubles other then U1 and U2.After cancellation of trouble the test command is also cancelled automatically,also used to cancel toner full detection the maintenance lamp blinking.
Posted on Sep 26, 2009
Our Lanier copier is showing a wrench. What could be the problem?
Could be an error code, is there a number preceded by an sc displayed on the panel?
Aug 01, 2011 | Lanier 1205 Copier
The copies on our Lanier/7313 come out zebra stripped. The copies appear to copy better if we change the copy darkness to a lighter color.
Zebra striping is typically caused by a bad development clutch. Most likely, the developer and the development clutch will need to be replaced, but the 7313 is so old you may have trouble finding parts, or finding a technician to work on the machine.
Sep 21, 2010 | Lanier 1205 Copier
How do I reolace the toner in a lanier 7313 copier.
It was very easy. I just had not seen the machine when I posted the question. Thanks
Jan 07, 2010 | Lanier 1205 Copier
How do you enter simulation mode and the code when you replace developer on lanier 7313.
Press C00C or C interupt key 0 interupt key and 41 for developer counter display 42 for developer counter clear 46 for exposure level adjustment 72 for maintenance preset counter setting 25 for automatic developer adjustment. 40 for developer preset counter display.
Nov 10, 2009 | Lanier Office Equipment & Supplies
Lanier Model #7320 Copier SN 826255. Has a wrench
Press "clear/stop" and "8" at the same time. An error code will be displayed in the copy quantity window as long as those two button are held down. What is the error code? Each code is specific to different areas of the copier. I will be more than happy to assist you in resolving.
Sep 23, 2009 | Lanier Office Equipment & Supplies
I have a Lanier 7313 Copier which doesn't copy properly. Even with a new ink cartridge, the copies come out faded. Any ideas on what I can do?
This machine goes through developer pretty quickly. Sounds to me like it needs new developer and possibly a drum (and drum blade).
Aug 24, 2009 | Office Equipment & Supplies
How do you reset a lanier 6112 copier so the wrench stops flashing. thanks
The maintenance time is flashing.To be use the service enter code C-0-0-C or C -Interrupt-0-Interrupt,then press 20(maintenance counter clear) and 72 maintenance preset counter setting for a new value.
Aug 07, 2009 | Lanier Office Equipment & Supplies
Lanier copier 7313 AG
The clutches arnt too bad putting them in however... I own this model as a home copier but parts are hard to come by and to get a tech that knows how to repair is harder.
Sep 18, 2008 | Lanier 1205 Copier
LANIER COPIER 7313
I guess by your fault description that there is a blank gap before the printing starts? The only way to cure this problem is to replace the registration clutch as it is turning on too late and not releasing the paper quick enough. Also check that the paper tray dial is displaying the correct paper size and position.
Thanks Jason
Aug 15, 2008 | Office Equipment & Supplies
Lanier tape dictation machine
Send an email to service@tvps.com or call (800) 644-9525. Please indicate model, serial and detailed description of problem
are the Best
Jul 01, 2008 | Audio Players & Recorders
238 people viewed this question
Top Lanier Office Equipment & Supplies Experts
Adorjani Laszlo
Anthony Karuku
George Mclaughlin
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
