Question about MTX Dodge Ram Quad Cab 2002-2003 Thunderform, Loaded with Dual 10 Inch Subs and Amplified, Charcoal Car Speaker
Need to know what check engine light code po456 means.. and how do i fix it?? 2003 dodge ram 1500 5.7 hemi
  • 301 Answers
Make sure the gas cap is tight.
Posted on Sep 23, 2009
2003 Dodge Ram hemi 5.7L my check engine light has been on now for sometime now, but the truck drives perfectly normal other than the light. when I took it to my local garage they told me it was the P
The next time you go by an auto parts store, stop in at the counter and ask them to read your check engine codes. They will print out a receipt with the actual codes and descriptions of what the codes mean.
The PCM is the main engine computer, if it had problems the engine would not run well if at all. Engine computers tend to be expensive as well. Not a part you want to swap out on a whim.
Please mark my answer helpful and feel free to post the actual trouble codes in the comments if you need more help. 2003-dodge-ram-hemi-5-7l-check-engine-l0u5xrrbjmm23votbgnhzwek-2-0.jpg
Jan 11, 2015 | 2003 Dodge Ram Pickup 1500
How do I fix the p0481 code on my 5.7 ltr dodge Durango hemi to get the check engine light to turn off
this site tells you a lot about what it is and what to do
http://www.obd-codes.com/p0481
Nov 26, 2014 | 2004 Dodge Ram 1500
Code po456 and PO457 on Dodge ram 1500 05 model, how do I fix this problem?
You have a vacuum leak in your EVAP system. You can check all your hoses for breaks and cracks or you can have your system smoke tested. GOOD LUCK FRIEND.
Sep 17, 2014 | Jeep 02 03 04 05 Dodge Ram 1500 Pickup...
2006 dodge 1500 hemi-trouble codes p0700 and p0800, what are they?
the P0700 means Transmission Control System (MIL Request)
the P0800 means Transfer Case Control Circuit
hid conversion kits
Aug 27, 2012 | 2006 Dodge Ram
How many spark plug wires does a 2003 Dodge ram 1500 hemi have
Eight...
2003 Dodge RAM 1500 5.7 liter Hemi V-8 VIN "D"
Dont forgetted rate this answerr. Good luck.
Nov 02, 2010 | 2003 Dodge Ram Maxi
Check engine light 2007 ram 1500 hemi. I've owned
There is no standard interval for the CE/MIL light. You need to get the codes scanned at a local AP store to see what codes you have.
Apr 16, 2010 | 2007 Dodge Ram 1500 Quad Cab Sport
Problem with starting my 2003 dodge ram
My father has the same problem with his 2001 Chrysler Sebring, the key will go into the ignition switch but wont turn. Called the dealer and seems the tumblers inside the ignition have gotten stuck, the solution... put the key in the ignition and tap it gently with a hammer (plastic tip if you have it) and it worked fine. Not sure what the guys at Autozone are pull but on a Ram 5.7 Hemi there are individual coils, not one, I should know I also have a 2003 Ram 1500 and have changed the plugs (not fun)... I have a code scanner (Hypertec) and when I've gotten a check engine light I check it with the scanner. Turned out mine had a problem with the air sensor in the intake. $15 part fixed the problems. Good Luck.
Apr 18, 2009 | 2004 Dodge Ram 1500
Check engine light on, ignition coil diagnostic
i would start with the gas cap and have them read the
code again. its a cheaper way to go first
Apr 09, 2009 | 2004 Dodge Ram 1500
MTX Dodge Ram Quad Cab 2002-2003 Thunderform, Loaded with Dual 10 Inch Subs and Amplified, Charcoal Car Speaker Logo
236 people viewed this question
Top MTX Car Audio & Video Experts
Professor_V
Professor_V
Matthew Spark
Matthew Spark
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
