Question about Magic Chef CAV2000AWW Top Load Washer
Washer fills w/ water, but will not stop filling. Therefore it never goes into the agitation cycle. Any help greatly appreciated!
  • 1 more comment
  • jon_morton Sep 23, 2009
    Thanks Bro
    Thanks Bro
  • nievesluismi
    nievesluismi Nov 16, 2012
    Where is the control vale on the magic chef cav2000aww machine
  • 98 Answers
Level control valve is bad or line came off it or a hole in line. But it's likely the valve. It could be that you can adjust it and it will work at one level only. it has a screw where you can do that. Just take the panel off and you will see what I mean.
Ken
Posted on Sep 23, 2009
  • 220 Answers
Unless it is overflowing then you probably have the drain hose to low try lifting the hose above the water line the washer is trying to fill to,there is no check valve or air break to stop the water from just running out if you lay the hose on the floor.and the washer will just keep trying to fill.
I have a GE spave maker Laundry that fills up with water than stops!
GE Washer Not Agitating Repair Guide
www.appliance-repair-it.com/GE-washer.html
If your washer will not agitate or spin take a look at this page GE Washer Not ... If the washer fills up with water then doesn't do anything at all and you do not hear ... if this were the problem, the water would not stop running, over-filling the tub.
GE washer spin cycle not working - ApplianceBlog
www.applianceblog.com/.../217-GE-washer-spin-cycle-not-working
Mar 12, 2005 - 10 posts - ‎3 authors
I have a GE "Spacemaker Laundry" (Stackable) model number ... Today it filled withwater initially then stopped working all together when it ... Bad motor, something jammed/seized up holding the motor back from running?
Jan 10, 2016 | GE Spacemaker Washer and Dryer Electric...
Wash cycle
What is the model number of the unit?
Dec 02, 2012 | Washing Machines
My wahser just stopped working it filled with water and then started agitating and then all the sudden stopped please help
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water
  • Jan 29, 2011 | Kenmore 24032\24036 Top Load Washer
    Washer wont agitate or stop filling on any setting
    Hello Friend, Just replace the water pressure/level switch. Replacement will make it fill correctly and agitate. Happy to help.
    Nov 18, 2009 | Kenmore 24712 Top Load Washer
    When it gets to Spin cycle, stops and does not pump out water
    This switch is a safety switch and needs to be working properly.
    The condition that you describe sounds like the switch is not indicating the lid is closed...so no spin.
    Also, check that both hot and cold fill hoses are on, <<Be sure.
    Doc
    Sep 20, 2009 | Washing Machines
    Agitator starts at begining of cycle before washer is full
    Please be carful as running the agitator without enough water will overheat and kick out the motor, however it should be ok when it resets itself.
    Yes, the machine should stop agitating when you lift the lid so this too is part of the problem.
    After looking at the print I can only suggest that the cam contacts in the timer ( contacts 12 and 14) that start the motor are burned and stuck together.
    Quentin
    Sep 17, 2009 | Frigidaire FEX831CS Top Load Stacked...
    Washer functions but doesn't fill with water, with
    if it agitates without water then the fill pressure switch is stuck , this will lead the unit to beleive its full already.
    replace the water level/fill switch for the fix.
    Phil
    Jun 10, 2009 | Washing Machines
    Frigidaire front load washing machine won't stop filling
    it sounds like your water valve is bad or you pressure switch is bad or hose from pressure switch to tub is cloged
    Feb 07, 2008 | Frigidaire ATF6000ES Front Load Washer
    Magic Chef CAV2000AWW Top Load Washer Logo
    193 people viewed this question
    Top Magic Chef Washing Machines Experts
    Ian Jones
    Dan Webster
    Dan Webster
    Are you a Magic Chef Washing Machine Expert? Answer questions, earn points and help others
