Question about kawasaki 19.2V 4 Piece Cordless Tool Kit
Kawasaki 19.2V Cordless
I dropped it and bent the main shaft. Can it be repaired?
  • Anonymous Mar 03, 2008
    I have no idea how it happenned, but I also have a bent shaft. Pretty lame.
  • 25 Answers
Yoy bet, just pack it up and send it withyour explanation to:
Stefan Hollstein
Alltrade Parts Department
1431 Via Plata
Long Beach, Ca 90810-1462
If it can be repaired, they'll advise or provide you with other options.
Posted on Apr 23, 2008
2004 Kawasaki Vulcan 1500 Nomad will not shift
Hi, Randy and the usual suspects are:
1. Improper clutch adjustment or not disengaging.
2. Bent shift shaft.
3. Shift fork bent or seized.
4. Gear seized on the shaft.
5. Gear positioning lever binding.
6. Shift return springs weak or broken.
7. Shift return spring pin loose
8. Shift mechanism arm spring is broken.
9. Shift mechanism arm is broken.
10. Shift drum is broken.
11. Shift lever loose on the shift shaft.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Stuck in neutral or will not shift to first gear Kawasaki Vulcan 750 Forum...
1996 Kawasaki Vulcan 1500C bent shift forks
Kawasaki VN1500 Service Manual
OEM Parts for Kawasaki
http://mybikemanuals.com/kawasaki
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Sep 05, 2014 | 2004 kawasaki Vulcan 1500 Nomad
2000 Kawasaki KLX 300 will not shift into 6th gear
Hi, Anonymous and the usual suspects are:
can change gears GONE HARD KawiForums Kawasaki Motorcycle Forums
2009 wont shift to 3rd
Kawasaki KLX300R service manual repair 1997 2005 KLX300 Download Manuals... $15
2000 Kawasaki KLX300R Owner Manual
Jul 01, 2014 | 2000 kawasaki KLX 300
2005 Kawasaki KX 125 stuck in 2nd gear will not shift
Hi, Ian and the usual suspects are:
Transmission problems 2004 KX125
KTM stuck in gear or wont shift repair
Kawasaki KX125 Service Manual
2005 Kawasaki KX125 Owner Manual
Aug 12, 2013 | 2005 kawasaki KX 125
1996 Kawasaki ZX-6R Ninja will not shift into 2nd gear
won shift up to 2nd
2nd gear problem help
Kawasaki 1985 ZX600 Service And Repair Manual
Kawasaki Ninja Owners Manuals
Jun 21, 2012 | 1996 kawasaki ZX-6R Ninja
1990 Kawasaki ZX-6R Ninja will not shift
Hi, Steve and the usual suspects are:
won shift up to 2nd
http://zx6r.com/zx6r/38529-bike-will-not-shift-up-into-2nd-any-higher-gears-please-help.html
May 07, 2012 | kawasaki ZX-6R Ninja Motorcycles
2007 Kawasaki Ninja ZX6R shift lever does not return
Hi, Free2b_ameri and the usual suspects are:
1. Shift linkage bent.
2. Shift linkage contaminated needs cleaning and lubrication.
3. Return spring bent or broken.
4. Shaft shaft bent.
Shift lever doesn always come back up KawiForums Kawasaki Motorcycle Forums
Shift lever doesn return after downshift Kawasaki Forums
Kawasaki Ninja ZX 6R Service Manual
Kawasaki Ninja ZX 6R Owner Manual
May 02, 2012 | 2007 kawasaki Ninja ZX6R
1988 Kawasaki VN 750 Vulcan will not shift
http://www.vn750.com/forum/26-transmission-rear-end/1601-shifter-not-working.html
Shifting problems Kawasaki Vulcan Forum Vulcan Forums Kawasaki VN 750 Service Manual
1989 Kawasaki Vulcan 750 Owner Manual
Mar 29, 2012 | 1988 kawasaki VN 750 Vulcan
1995 Kawasaki VN 750 Vulcan will not shift
Hi, Lori_camp and the usual suspects are:
Bike not shifting Kawasaki Vulcan 750 Forum Kawasaki VN750 Forums
07 Vulcan 900 Classic will not downshift to 1st or Neutral Kawasaki Vulcan...
1995 Kawasaki Vulcan 750 Owner Manual
Aug 09, 2011 | 1995 kawasaki VN 750 Vulcan
1994 Kawasaki VN750 Vulcan, transmission won't shift
Hi, Rock_johnson and the usual suspects are:
http://www.kawasakimotorcycle.org/forum/mechanics-corner/128592-2004-vulcan-750-cant-shift-into-2nd-gear.html Kawasaki VN 750 Service Manual
1994 Kawasaki Vulcan 750 Owner Manual
May 13, 2010 | 1994 kawasaki VN 750 Vulcan
I have a t801 mixer with a bent planetary shaft.
Remove the whole planetary from the bottom... There should be a large nut on the main shaft...remove it ....whole assembly drops down...careful...don't drop it......At the top of the bent shaft you should see some center punches holding a thin nut in place.....drill them slightly so you can loosen the nut. There are some studs that hold the lower bushings in place...remove them with a straight blade that fits the screw snug. You can have a new shaft made out of stress proof steel shafting from a competent machine shop........MONSTROSPIZZA.COM
Jan 29, 2010 | Hobart Food Mixers
kawasaki 19.2V 4 Piece Cordless Tool Kit Logo
104 people viewed this question
Top kawasaki Drills Experts
Marvin
Marvin
jasbo
jasbo
john h
Are you a kawasaki Drill Expert? Answer questions, earn points and help others
