Question about Volfenhag ZX-862R Coaxial Car Speaker
Speakers are not giving out sound at all. It will randomly come and go. Seems to happen at raised volumes (above 10 on my system). The speakers do not crackle or give any noise.
    Problem Solver:
  • 10 Answers
If it is a factory radio then your factory amplifier is bad. if it is an aftermarket radio the outputs are clipping you possibly have a blown speaker ot too many speakers. then again the radio could just be about had it.
Posted on Nov 07, 2009
How to get sound from a nady audio 4130 mpm 4 channel power mixer
First, plug it in. Next connect the speakers. Center all eq controls both master and channel. Turn off any reverb or effects. Turn the master volume 1/2 way up. Plug a sound source into channel 1 wiyj the channel volume all the way off. Turn on the amp. Slowly raise the channel volume until you heat output. If you get nothing, it's broken.
Nov 10, 2016 | Nady Systems Music
Hello ! I have a Sony DAV-DZ640K Home Theater System, the problem is that I can increase and decrease sound levels for individual speakers, like i am able to increase and decrease surround (back) speakers...
Sound distribution varies according to speaker configuration. You have to select speaker size and placement and a number of other characteristics to get results. A review of the setup instructions in accordance with the physical size of the speakers you are using and nominal impedance values may help.
Feb 26, 2014 | Sony Audio Players & Recorders
MX6050D Subwoofer Issues
Hello, welcome to Fixya!
Fault is either from the main system or the sub-woofer itself.
You need to test both unit in order to detect which of the two is giving the fault, so that you can concentrate on the faulty unit.
Test the woofer with a AA battery or any other battery. Put your ears close to the woofer and observe if you will hear any sound. If the woofer makes sound, then it means the woofer is working, but if it doesn't make sound, then it means the woofer is defective. Or you can disconnect one of the working speakers and connect the woofer to that part. If there is no sound, then obviously, the woofer is defective.
If the woofer seem to be working, then the unit needs to be tested also.
Connect one of the working speakers to the sub-woofer's section of the main unit. If the speaker doesn't bring out sound, check the system's menu settings, check the volume and make sure the sub-woofer volume is raised to the highest level and not on mute. ( Note that most Theater systems has separate volumes for each speakers). If the volume is raised to the highest level and there is still not sound from the woofer part, then it means the woofer channel has burnt. It could be a fuse or a defective channel. At this point, I think you need help from a repairman.
I hope the above is clear.
Regards.
Nov 17, 2011 | Audio Players & Recorders
Alpine Mrp-m850 I'll be driving and suddenly my amp will just stop giving output. the light doesn't even twitch when this happens, and everytime it does, I have to take me faceplate of my...
It sounds like your amplifier is over heating. It might be an ohm issue. Try unbridgeing your speakers from the amplifier and run each speaker seperately to the amplifier to equal out the ohms on the amplifier. If your speaker box is bridged take each speaker out and rewire them seperately. If the problem still happens you may need a new amplifier and wire that one in as stated above.
Jun 12, 2011 | Car Audio & Video
No sound my system
If there is no sound coming from your computer try these "simple" but common solutions first.
1. Make sure the power cord is plugged into an outlet and the speakers are turned on.
*Make sure your speakers are correctly connected to the computer.
*Make sure that the speaker cable is plugged into the speakers and the correct jack on the computer.
2. Make sure your computer has a sound card and that it is enabled and working properly:
To open Device Manger...
*Start
*Control Panel
*System and Maintenance
*Device Manager
*Expand the Sound, video and game controllers category.
If a sound card is listed, you have one installed.
*Check the status of the driver and update if necessary.
3. Make sure that the speaker volume is not muted or turned down too low.
To open Volume Control...
*Click the Start button ,
*Click Control Panel
*Click Hardware and Sound
*Under Audio Devices and Sound, click Adjust system volume.
*Under Main Volume, move the slider up or down to raise or lower the volume.
If you still have no sound after checking the solutions above, you more than likely have a bad sound card.
Jul 13, 2010 | Computers & Internet
Raised volume cuts sound and gives me "overload" message
A couple of possibilities: Bad solder on power regulators (attached to main heat sink) or cooling fan may not be turning on when volume is raised.
Jan 16, 2009 | Audio Players & Recorders
Intermittent, random, loud popping noises.
you have a problem with your amp. most likley the finals are passing dcv intermitently to the load.
May 28, 2008 | Audio Players & Recorders
Amp protection light comes on when raising volume...
It sounds like you either have too low of an ohm load or the voltage is dropping at the amplifier's power terminal.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
If the voltage remains near or above 12v, disconnect one speaker and see if it shuts down. If it doesn't, disconnect that speaker and connect the other speaker. If it only shuts down with both speakers connected and the voltage is staying above 12v, the ohm load is probably too low and you'll need to rewire the speakers.
Dec 31, 2007 | DB Drive A460 Car Audio Amplifier
Subwoofer crakling sound when playing anything.
Hello Ronaldlora
Happy Holidays
Hi, this is a particular problem for this speakers, and subwofer, it is a resistor inside the sub, you have to fix it in a repair shop, or ...sadly, change for another model of Creative Speakers, for example one good one is the 7800 Spk. good ones.
but like I say is a problem that creative labs is aware too.
Dec 17, 2007 | Creative Labs Gigaworks S750 Computer...
Car Audio & Video Logo
Top Volfenhag Car Audio & Video Experts
Robert Rankin
hoyzee1
Are you a Volfenhag Car Audio and Video Expert? Answer questions, earn points and help others
