Question about ASUS EAX1300/TD RADEON X1300, (128 MB) PCI Express Graphic Card
Monitor switchehs off when card is installed?When monitor lead is swapped from original socket to that of the graphic card, the monitor just shuts down. operating system is windows 2000 pro.
    Problem Solver:
  • 3 Answers
Try to find the right installer for the video card
Posted on Oct 14, 2011
Hello, Yesterday morning, I have installed a second screen linked to my graphic card. I tried to install a 3rd screen on the VGA motherboard, and it didn't work so I take it off. I could work on the...
from recent experience , it is the graphic card that has failed
I had a problem of the 2 screens suddenly going and then coming back on and a message the the nvidia kernal 387. suffered a fault recovered fully but the second screen never came back the same as screen 1
After I removed the card to fit a new card , that unfortunately had a different connection and therefore wouldn't connect a monitor , the computer would turn on a green light but would not turn on the system fans and all
I built a new mother board and the same thing--green light and nothing
I read forums and picked up this information. The computer in doing a hardware check before it goes to BIOS found a problem and stopped
the advice was to remove all hardware then insert a bit at a time until the problem surfaced
I fitted a ram card and the fans started
installed a monitor of the motherboard gva socket and it lit up
installed the graphics card with the vga connected to a monitor and it lit up
connected the second monitor and back to square one
end result , the original mother board is functional, the graphic card is stuffed
yours is probably the same
Mar 01, 2017 | Dell Vostro 420 Desktop Computer
Destop PC sudenly the screen became black
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have secure dust free connections and are not faulty or just replace them they might be faulty
if its a 40 pin IDE it will be the first to fail
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electical extensions
even something as small as an electrical fan and its lead can cause you problems or just replace them they could be faulty a computer needs all electrical power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error
make sure your graphics card is securely seated with no dust built up or in the socket
if you remove your graphics check the socket to make sure its dust free
restart your computer then reinstall it this should activate found new hardware wizard
hope this helps you
Feb 13, 2012 | Computers & Internet
The monitor working normally and after 15 min. turn off
is it only the monitor turning off or the computer
the leads from your "((MOTHERBOARD TO THE HARD DRIVE))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electical extensions or just replace them they could be faulty a computer needs power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error
make sure your ram modules are securely seated with no dust in the sockets also the Cmos battery has charge with no dust in the socket
if this fails to fix the problem
or it might be your graphics card make sure its securely seated and there is no dust in the socket or dust built up on and around the graphics card
hope this helps you
Aug 23, 2011 | Computers & Internet
I WANT TO INSTALL A VIDEO CARD FOR MY NEW MONITOR
You will need to get a PCI video Card once you have it open the PC case and the card will go in the first blue slot at the top you will also have to open a port in the back of the tower where the card will come out , It will be wise to shut down the computer and unplug it beware of static so ether wear a anti static wrist band or a pair of surgical rubber gloves
Aug 22, 2011 | MSI G41MP33 Motherboard Intel Core 2 Duo...
I have a MX4000-T128 video card installed on a P4MAM-V mother board with intel pentium4 and windows 7. The computer does not recognise my video card. It displays as std vga graphic card. I am not able to...
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electical extensions or just replace them they could be faulty a computer needs all electrical power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error
hope this helps you
Aug 20, 2011 | Computers & Internet
My acer aspire m1460 got a bit wet and will not send a signal to my monitor tried a new graphics card still no joy any help would be much appriacated
check leads from motherboard to hard drive make sure securely seated and you might check the graphics card socket for moisture you might check the socket with a multimetre make sure its getting voltage if it got moisture might have shorted something? did you smell anything burning?
hope this helps
Jul 31, 2011 | Acer Computers & Internet
Signal to monitor lasts for about 20 seconds then stops (initial installation of pci-e card). Neither new graphics port or onboard port works after 20 seconds
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions IDE,SATA
the leads from your "((motherboard to your hard drive))" make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electric extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error If your computer came with a motherboard disc the drivers could be on it or you might have a dirty graphics card remove the graphics card and clean the socket
Apr 20, 2011 | MSI R5450-MD1GD3H/LP RADEON HD 5450, (1...
Ok, i have two things to ask 1: Where is the video card on a emachines W3503? 2: Could a video card swap be done between a W3503 and a W3052? Thank you for viewing :)
1. The emachines W3503 has an integrated ATI Radeon™ X300 based graphics card. It has also a PCI Express (PCIe x16) slot available.
2. The emachines W3052 has a NVIDIA® GeForce®4™ MX graphics card. I'm not sure whether it is integrated or not, but I'm sure that if it is not, it will be an AGP graphics card. Since The emachines W3503 has a PCI Express (PCIe x16) slot available for installing a graphics card, the swapping of graphics cards between the 2 machines is not possible since they support different types of graphics cards.
Jul 11, 2009 | Computers & Internet
Monitor image is totally distorted
First remove the graphics card and use the integrated AGP to check if the monitor is OK. Repairing graphic cards are dicy unless the damage is clearly identified, but no assurance since it must have damaged some other component too. So get a new graphic card if the monitor is OK.....................sodeep
May 16, 2009 | Dell Computers & Internet
Geforce 2 MX-400 (64 bit) with vista
Before you installed the Geforce graphics card was your monitor connected to a video output on the motherboard?
If this is he case you may have to disable the onboard video card from the BIOS.
You can check by swapping the monitor's video connector between each of the video outputs.
If Vista detects a video card and you had not installed the video driver, it would install standard VGA driver, you can then install the Geforce driver.
Jan 02, 2009 | Gateway GeForce2 MX400, (64 MB) AGP...
ASUS EAX1300/TD RADEON X1300, (128 MB) PCI Express Graphic Card Logo
204 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
