Question about Frigidaire Heating & Cooling
My systems cooling works but when I put it to heat it pops the fuse what could it be
  • Frigidaire Master
  • 3,361 Answers
You have a short circuit in the heat cycle.
Posted on Sep 23, 2009
2 Suggested Answers
  • 16 Answers
SOURCE: Fan runs, cooling and heating do not.
sounds like capasitor blew, or bug or snake or someyhing got into compressor area if outdoor heatpump or unit, could be snails also. if so might have killed compressor or something else electrical
Posted on Jun 15, 2009
2003 ford ranger ticking noise when truck is off
It is usually the heat shield on the exhaust system. When you drive your truck, the catalytic converter heats up to about 1000 degrees in order to work properly. The car manufacturers put heat shields over the converter to prevent grass from catching fire, because the shield is thinner and it cools faster. As it cools, it ticks and pops for at least an hour after you stop the engine.
The other option is there is a time bomb counting down....lol.
May 07, 2012 | Ford Cars & Trucks
My 2000 lincoln Ls Over Heating
bleed all the air out.....
Jun 15, 2010 | 2000 Lincoln LS
2001 VW JETTA GLS, V4 OVERHEATING
if your water pump is not working pull the return hose off of the reservoir and see if u get any flow at higher rpms also if you have no heat coming from heat vents the water pump is gone. could have bad t-stat. Does your a/c work? if not check your fuses on top of your battery see if one is blown. if so your cooling fans can cause you to overheat. if you have a air pocket in our system. fill first with water half way then add the pink coolant let run make sure no more bubbles. Back to the use thing. if that fuse is popped your cooling fans are bad as well you will need both fans to fix concern.
Sep 01, 2009 | 1996 Volkswagen Jetta
Jun 14, 2009 | Heating & Cooling
3 amp fuse blowing in York central A/c
a blown fuse is a sign of a short circuit. either connections are touching each other or a relay is busted. Have it checked. Have the system leak checked also, this would result to better cooling/heating and energy savings.
May 13, 2009 | Heating & Cooling
04 trailblazer, NO AIR coming through vents.
once a year you want to check the antifreeze/ freeon in your cooling system. from my understanding the cooling and heating system require this to function properly. they sell cans of this stuff at walmart that you can put in yourself.
Dec 21, 2008 | 2004 Chevrolet TrailBlazer
Cooling system fans quit working and it over eats now
check the sending unit near the out put hose for the radiator on the head one wire or two will go to it. it screws in to the head. or check the relay under the hood in the fuse box.
Dec 20, 2008 | 2004 Pontiac Grand Am
98 Civic with non-functioning cooling fan
bad thermostat or worse a plugged heater core or bad summer/winter diverter valve. look for bad thermostat.
Dec 08, 2008 | 1998 Honda Civic
Analog thermo.stat control kit
Have you tried removing the RH wire connected to the thermostat and try it ? This might rule out furnace as short in system. If it does the same, put RH- (heat) back on and try removing RC-(cool) , if it doesn't pop the fuse, you may have isolated the problem.?
Jul 30, 2008 | Dometic Rooftop RV Air Conditioner
Microwave will not function properly.
The cavity thermal fuse may have failed. It is located on the top of the cavity.
Jun 13, 2008 | Microwave Ovens
Heating & Cooling Logo
23 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
