Question about Nordic Track /proform Treadmill Drive/motor Belt 118016
When Im running on the treadmill it stalls and
When Im running on the treadmill it jerks and screeches , what could be wrong??
My TX2.5 treadmill while working fine it will stop and start by itself like jerking. What is wrong and how do I fix it?
first of all Try to lubricate the treadmill belt. If then also the the problem persist check the motor and its carbon brush.
If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Oct 26, 2016 | Exercise & Fitness
I have a gold gym vx 5000, the motor does not keep a consistent speed and jerks a lot, is there any way to fix this?
You have to check the treadmill belt. is it properly tightened or not. If the belt is loose the this type of problem can occur. check the video and tighten the belt and the check is it jerking of not .
Almost all the treadmill have the same belt tension procedure.
Treadmill Running Belt Tensioning
www.electro-medical.blogspot.com
Sep 21, 2015 | Exercise & Fitness
I am a new rider and have a Honda CBF 2009 model. Im getting out on the bike every day yet im still having issues with stalling when moving off from a standing start. I dont think I could let the clutch...
look at your spark plugs , could be a lean out condition causing your engine to stall. Also when were the valves adjusted last? Dirty carbs can cause lean out and make the bike run like s h it
Feb 15, 2015 | Honda Motorcycles
Treadmill jerks back while running. I feel like i might fall off of it
see the video attached, lube the rollers bearing front +back too.Test the drive belt motor for tight or faulty .
God bless you
Sep 29, 2013 | Treadmill Doctor Weslo Cadence Dx12...
Need a users and repair manual for a Nordic Track Epi
type in the website audiostrider 600 and it will come up iconservice.com the screeching is most likely a magnet from the magnetic resistance coming loose.
Jul 29, 2010 | NordicTrack E4000 Treadmill
Reebok treadmill
Hi James
Unplug unit remove motor shroud then plug unit back in , press start and begin walking on the belt normally and try to stall the belt to make it slip ( planting foot to stop the belt).
Be careful during this test. If the problem is in the drive belt, either the drive belt will stop when stalled or the front roller will stop when stalled. Here is the procedure for adjusting the drive belt.
Find the motor mounts. Many motors in Icon treadmills have a main pivot joint in which a bolt runs the full length of the motor mount. This bolt will require loosening to provide maximum adjustability. Some models have a single jack bolt and others have an auto tensioner. Single jack bolts are the easiest to adjust.
Find the set bolt(s) on the motor. This is typically run through only one side of the motor mount or may be on both sides but it does not run the full length of the mounting. Loosen this bolt(s) but do not remove. Jack bolt models will have flat mounts and may contain up to four bolts.
Look for a bolt that will tension the motor. If it has this bolt, it typically runs in the same direction parallel with the drive and walking belts. If your treadmill is not equipped with this bolt, skip to Step 4. If your treadmill is equipped with this bolt (very few are) the repair will only require one person. Using 2 7/16" wrenches, make a few turns to this bolt, tighten the bolts and test your treadmill for slipping. If belt continues to slip, and if their is too much tension ( you should be able comfortably twist the drive belt 90 degrees ) then replace drive belt.
If the motor, drive belt, and front roller continue to turn when the walking belt is stalled, the problem is with the walking belt slipping on the front roller, here the procedure adjusting the walking belt.
If the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD. Using the allen wrench, turn both rear roller bolts clockwise, 1/4 of a turn.When the walking belt is correctly tightened, you should be able to lift each side of the walking belt 3 to 4 inches off the walking platform. Be careful to keep the walking belt centered. Plug in the power cord, insert the key and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened
If the drive belt continues to turn but the front roller stalls, you may have a broken front roller pulley. If this is the problem, you will notice it because the plastic will usually make a loud squealing sound on the metal front roller. The front roller assembly will need to be replaced and the drive belt must be replaced also. We suggest replacing the drive belt as well because it is a low cost item and will most likely, have suffered unusual wear from the problem. Another possibility is that the drive belt has worn down. In some cases, belt dressing may help correct the problem. If not, the drive belt must be replaced.
May 24, 2010 | Reebok 8050 ES Treadmill
I have a Proform 770 EKG Treadmill jerks and squeaks
The drive belt was loose. I tightened up the motor just a smidge using a crow bar. That solved the problem.
Dec 29, 2009 | Exercise & Fitness
Why does my Ironman Triad treadmill motor slow when people try to run on it, the belt completely stops
When running or walking on my Ironman Triad Treadmill it jerks like it is going to stop every once in a while not all the time. Do you have any idea what makes it do this. I have had this Treadmill for 5 years and never had a problem before.
Dec 19, 2009 | Ironman Exercise & Fitness
Proform 590 HR Treadmill. Belt won't run
Hi, i fixed one just the other day, the control unit fails.
broddersbaldrick on a big auction site fixes them :)
Hope this helps
Sep 17, 2009 | Exercise & Fitness
Nordic Track /proform Treadmill Drive/motor Belt 118016 Logo
130 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
