Question about Acer Aspire 5100 Notebook
Broken ac adapter
All of a sudden my battery in my acer laptop would not charge *cries*...i tried my sons adapter from his acer laptop and it charges it...i have had the lappy since May. will the warranty cover this?
    Problem Solver:
  • 5 Answers
Look for the lights on your adapter if its plugged on. if its lighted, then its probably the small connector issues.
Follow this link if you are DIY guy. The other option is to buy new power adapter.
Posted on Mar 20, 2008
    Problem Solver:
  • 5 Answers
Hi
1. The Adapter may be malfunctioned in the manner of the defects of PINS, replace first your wiring plugs
2. Warranty is not mentioning about the adapter anyway
3. The Solution is check your wire when continuity and the Power plugs has some bad conduct
Thanks,
Senthil007
sundari_changi@yahoo.com.au
+91 9789227782
India
Posted on Dec 15, 2007
Battery won't charge at all
maybe you have ac or dc adapter problem try to bend the wires back and forth while you're laptop is plugged in, and see if it is charging whenever you move the wires. if not, your whole charger (ac/dc) is damaged/broken or your battery is. if your unit is still under warranty have it replaced instead of spending money for something under warranty.
Feb 09, 2012 | Dell Vostro 3400 14" Laptop (V34004168ABS)...
I have a acer 5741. I have tried many times to charge it but it wont charge no matter how long i leave it plugged in. It is stuck on 10%. When I plug it in it says its charging but nothing actually...
1. Unplug AC adapter. Shutdown
2. Remove battery, Connect AC Adapter
3. Start windows7. Remove Microsoft ACPI-Compliant Control Method Battery under device manager , battery
4. Shutdown, Remove AC Adapter, Install battery, Reattach AC Adapter.
5. Power up -
Now Plugged in and Charging.
Aug 04, 2011 | Acer Aspire 5520-5908 Notebook
My Acer aspire 4935 is not recognizing the AC adapter. When ever I shutdown the system and connects the AC adapter, it works and the charging LED lights up. Once I press the power button to boot the...
Problem description:The battery charges only when the laptop turned off. The battery charge LED lights up as normal and the battery gets charged to 100% while the laptop is off.
When the laptop is turned on, the battery charge LED goes off even if the adapter is still plugged in.
Possible cause:1. AC power adapter failure.
2. Battery failure.
3. Broken/loose power jack.
4. Motherboard failure.
Possible troubleshooting steps and repair solution:1. This problem could be related to a faulty AC power adapter. It's possible that the AC adapter doesn't provide enough power when plugged into the laptop. To find out if this is your problem, you'll have to test the laptop with another working adapter.Replace the adapter if needed.
http://www.chargerbuy.com/replacement-acer-aspire-9400-ac-adapter-19v-3-42a.html
2. There is a slight chance that you have bad battery. Test the laptop with a know good battery and replace the faulty one if needed.
3. The battery charge problem could be related to the power jack. Maybe the jack is broken or not making good contact with the motherboard. It is necessary to remove the motherboard and take a closer look at the power jack. Resolder or replace the jack if needed.
4. If the power jack is in a good working shape and new power adapter with battery do not fix the problem, most likely you have a faulty motherboard. Replace the motherboard if needed.
Feb 09, 2011 | Acer Aspire 4730-4947 Notebook
My laptop battery i guess hit critical stage but now the system wont work with ac power
DC connector problem:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jan 26, 2011 | Acer Aspire 7520-5185 Laptop
Sometimes the Adapter Charges other times Doesnot, and now finally out, cant charge!
Possible cuase:
1 AC adapter failure
2 Power jack failure
First replace it with another working charger, see if the problem gone. If not, there may be strong possibility that the power jack was broken.
Here below are some common symptoms of a bad charger.
-The laptop only runs when you keep the power cord in a certain direction.
- The laptop only runs on battery power.
- The laptop will not charge the battery.
- The laptop switches from AC power to battery power intermittently.
- The unit suddenly shuts off
- Sparks come out of the back of the laptop.
Reference: Dell Latitude D620 Charger
Jan 20, 2011 | Dell Latitude D620...
The battery is not charging
Hi
Turn the Acer notebook off by pressing the "Power" button. Remove any power sources connected to the notebook. If the notebook is open, close it.
Flip the Acer upside down and place it flat in front of you. Slide the battery locking mechanism to the right. The locking mechanism is diagonal to the lower left corner of the battery. While sliding the mechanism, slide the slimline battery out of the battery bay.
Insert the AC power adapter. The AC power adapter outlet is located toward the middle of the right side of the notebook. Attach the other end of the power adapter to a functioning electrical outlet. Open the laptop. Turn the power on. If the Acer notebook powers on, the AC power adapter is properly working. Replace the AC power adapter if the laptop does not turn on. Remove the AC power adapter and turn the notebook off.
Inspect the slimline battery. Look for signs of damage such as dents and corrosion. If the battery contacts appear to be dusty or have residue, gently clean them with an alcohol wipe or cotton swab dipped in rubbing alcohol.
Re-install the battery by sliding it back into the battery bay. You may hear a click or snap when the locking mechanism locks the battery firmly into place.
Plug the AC power adapter into the laptop. Leave the power adapter in the notebook for eight hours so the battery charges.
Remove the AC power adapter. Power on the Acer notebook. If the notebook does not power on, the slimline battery must be replaced. If it does turn on, the battery did charge.
Oct 04, 2010 | Acer Aspire One Netbook 8.9" Notebook
Battery not charging
two possibilities:
1. AC adapter is not working well. 2. laptop DC power jack loose or broken
most likely 2, quite common for laptop, Acer
try if you can power on your laptop only with the AC adapter without the battery;
also keep monitor the indicators on your front panel, see if the AC input is on.
Dec 05, 2009 | Acer Aspire 5570-2758 Notebook
Acer aspire laptop won't charge
First of all you have to determine whether it's the battery, charger or the laptop itself.
Remove the battery and boot the laptop on AC power only, if the laptop boots up you can rule out the charger and the laptop, you may need a new battery if that is the case.
Regards.
Sep 08, 2009 | Acer Aspire 4520-5582 Notebook
Acer Aspire 5100 Notebook Logo
56 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
