Question about Seagate (ST3160203U2-RK) (ST3160203U2RK) 160 GB Hard Drive
How to open case: Seagate ST3160203U2RK External Hard Drive ??
I have a Seagate (Model: ST3160203U2RK, Part: 9BD862-560) External Hard drive, 160Gb. The drive won't power on at all - no green light. We've tried another AC adapter with no luck. I want to open the case, remove the drive, and put it in another external case. My question is: How do I open the case ?
There are 4 5-pointed star shaped screws on the bottom of the drive. I don't know how to open the case.
Any ideas??
  • wonderful840 Sep 24, 2009
    Thanks for the help. I forgot to mention that I purchased a 'star' socket set. However, the hole was too deep for the socket. I played around with a slotted screw driver for awhile, but didn't make any progress.
    So, I decided to crack open the case. It took awhile, but I finally got it open last night.
    The good news?! .... the hard drive appears to be fine, and all the data is now backed up !
    2 things about this experience really surprised me:
    - That Seagate would design an external drive that a customer can't open.
    - That Seagate wouldn't publish a Service Manual, explaining how to open the silly case.
    In their greed to get my 'Data Recovery' money, they've turned me off to their products !
  • 4 Answers
This is one of the mean tricks that the industry uses to discourage people from opening things and then totally ruining them.
What about getting yourself a 5-star-shaped screwdriver? Ask your hardware store guy.
Too expensive? Well - I have a lot of different simple slotted screwdrivers. Normally I find one that fits into 2 corners of these "miracle screws". If you don't have fitting one use a cheap one that is slightly too large to fit and grind it down just to size.
The same trick works with the other kind of "discouragement screws" that have ALMOST a normal slot --- but there's an elevation in the middle of it. A slot screwdriver with a ground-in **** in the middle (Dremel tools work fine) does the trick.
Posted on Sep 24, 2009
  • will8d Sep 24, 2009
    Oh... I just see the bashful system replaced the word  s l i t  that I used by ****
    Oh... I just see the bashful system replaced one word I used by ****. The word was like "slot" but replace the "o" by an "i".
Internal hard drive
They do make cases that you can buy to turn an internal HD into an external. Best Buy I think sells them.
Dec 19, 2009 | Seagate 160GB 3.5" External USB Drive 160...
The compaq presario v3000 replace hard drive
Yes of course you can install the Seagate Mementus 160GB, the laptop will take a dive with a 320GB capacity.
Regards.
Dec 02, 2009 | Compaq Presario Notebook
I use windows 95, it doesnot recognise my seagate external HDD
Dear! You have to install software of your external hard, after install the software or driver of your external hard it could be accessible.
Thank You
Aug 10, 2009 | Seagate (ST3160203U2-RK) (ST3160203U2RK)...
Seagate,external, Hard drive,160GB,knocked over,doesnt work
Buy a new drive. The beeps are coming from the hard drive and they say I'm broken. If you need to recover data, and only if you need it like life and death because it will cost a bit, send it to a data recovery company. I would search on line and look for somebody local to you for this if you need it.
As for your old drive, if you like to tinker, you may be able to remove the drive from the case and replace it with a similar sized drive with a matching interface (ide or sata). I personally like to remove the rare earth magnets from bad drives to make refrigerator magnets and toss the aluminum housing into the metal recycling barrel. It also ensure personal data is never coming off those platters.
Aug 09, 2009 | Seagate Momentus 5400.2 120 GB Hard Drive
External hard drive wont stay connected to computer
This depends where the failure is.
If your controller board for the external casing or your power supply have failed the drive can be removed from the casing and placed in a new one($30-$40), then it should work fine. If the circuit board on the hard drive or an internal circuit for the drive has failed then you may require the help of a pro.
Reply back if you need a recommendation for a pro, include your location.
Chris
May 19, 2009 | Seagate (ST3160203U2-RK) (ST3160203U2RK)...
I have a seagate external harddrive that my father gave me can it be locked? the harddrive is 160gb it is about 2yrs old gray and black casing
When you say lock the drive are you asking to lock access to the drive entirely when you disconnect it from your computer no one can access your files if they find the drive and try to put it on their computer and open it,
Apr 18, 2009 | Seagate (ST3100203U2-RK) (ST3100203U2RK)...
About my seagate 160 gb hard drive (external)
i hav usb seagate 160 gb hard disk.nw it is nt getting open message is the file or directory is corrupted or unreadable........CHKDSK is also not working for it.error is "unable to determine volume version and start"....plz help fast
Jul 26, 2008 | Seagate 160GB 3.5" External USB Drive 160...
External hard drive capacity
very simple.if you can make use of DOS-COMMAND then you can be able to finish the stuff.but i will advice you to send a message to my box so that i can giv you the steps:jaxdchamp@yahoo.com
Feb 05, 2008 | Seagate (ST3160203U2-RK) (ST3160203U2RK)...
Using hard drive on a Mac
If the drive is empty, use disk utility to reformat the drive as HFS+. DO NOT DO THIS IF YOU HAVE DATA ON THE DRIVE!!! :-)
Dec 03, 2007 | Seagate 160GB 3.5" External USB Drive 160...
Seagate (ST3160203U2-RK) (ST3160203U2RK) 160 GB Hard Drive Logo
3,847 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
