Question about Bosch 24 in. SGV53E03 Built-In Dishwasher
Dishwasher Dead no power no Lights, check the fuse
Bosch SGV53E03GB/55
Dishwasher Dead no power no Lights, check the fuse ok.
5 Suggested Answers
  • 1003 Answers
SOURCE: ...dead
CHECK DOOR SAFTEY SWITCH OR TIMER MOST LIKE SWITCH ASSOCIATED WHEN DOOR IS CLOSED
Posted on Jan 18, 2008
  • 249 Answers
SOURCE: BOSCH DISHWASHER Loss of power
check fuse in plug top,if its not that it could be door switch 30 years repairing. Close Ire....
Posted on Feb 23, 2008
  • 10 Answers
SOURCE: Bosch dishwasher SHE44CO2UC/22 no power or light
Hi sir,
first thing to say is that whether it may be an short circuit between circuits,,or due to an over voltage the fuse may be burnt,,please check the control panel..back of dishwasher,,,
if u checked fuse and circuit,,and think no problem with incoming voltage ,,the control panel's capacitors or resistors may be burnt..
if so please go to a tech,,,,,
thank u,,,for using fixya
Posted on Jun 26, 2009
Macmarkus
  • 2605 Answers
SOURCE: DISHWASHER COMPLETELY DEAD
Hi John, and welcome to Fixya. I don't believe the greasy water sitting in the machine has anything to do with the problem, rather it is likely a by-product of the problem. Based on your post, I would start by first shutting off the breaker. Then removing the kick plate ( access panel at the bottom ) and checking the wiring at the junction box for the dishwasher 120vac supply line. Remove the murret's and visually inspect the wire for "resistance burn" and strip the wires back and install new fastener's if necessary to repair. This is actually quite common to find a wire connector come loose due to improper fastening and once the unit is in use for a while the connections heat & cool, become loose from normal operating vibrations and burn up from all the added heat caused by "resistance". The end result is no power to the controls. Check it out and post back what you find. Thanks for visiting "fixya" and please take a moment to rate the solution/suggestion provided here for you. Good luck. Macmarkus :)
Posted on May 25, 2010
Testimonial: "Thanks for the solution. I'm afraid I am not very technical and some of what you've suggested is over my head. I'll pass the info to my brother in law to decipher and see if the problem can be sorted"
I own a Bosch home Dishwasher - Model SGV53E03GB-74 - where the wash tablet discharge cavity opens in the wash cycle but doesn't allow the tablet to drop, so the wash is ineffective and needs
Sounds like the dispenser door isn't opening. If it isn't being blocked by dishes, the dispenser door spring might be broken, the dispenser release solenoid could be faulty, or not getting power from the control panel. While you're waiting for it to get fixed, you can just put the detergent in the bottom of the dishwasher and run it on normal cycle. It also possible the dispenser door isn't opening wide enough for the puck to fall out. Make sure the door opens freely under it's own spring assist.
Nov 26, 2014 | Bosch Dishwashers
Dishwasher will not turn on, no lights, power source ok
Unit is Dead, No Lights, No OPS Some units will have thermal fuse of some sort in the wiring before the control. If this fuse is open, no power will get to the control or display. Before checking this fuse, make sure the correct voltage is present at the junction box for the dishwasher. If all is OK, you have a control or keypad issue FAULTY.God bless youff922825-6f57-4ac4-a46d-9ed3b3fedd7b.gif
Apr 02, 2013 | KitchenAid 24 in. KUDI02IRBS Stainless...
I have no power to the dishwasher.No lights light up om the control panel.Checked circuit breaker and there is no problem there.Is there a fuse or power reset button.
if you definetely have power into machine its sounds like a pcb fault these can blow out tracking or relays on pcb causing dead machine can be replaced but not cheap.
Aug 16, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
May 25, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Our bosch dishwasher is not working, when we press the button to turn on nothing happens, no lights, nothing, we have checked the fuse and thats ok. many thanks gail
you may have to turn off power at main box, and check wires at bottom of machine and any other junction box , from dishwasher to main power box. pull on wires to see if they will come apart.
Oct 30, 2008 | Bosch Dishwashers
My Dishwasher has no power.
have you check at the junction box behind the front bottom panel?? is the breaker ok?/ most newer homes have a switch above the counter to kill the power is that on ?? check that and let me know
Mar 15, 2008 | Bosch 24 in. SHX46A05 Stainless Steel...
Sgs43a Dishwasher
Most of the time with dead bosch dishwashers, i find that the wire nut has melted where the service cord is connected to the appliance. This connection is on the lower right side of the dishwasher. you get to it by removing the two screws from the toe kick, then removing the screw holding the cover on the metal junction box, if it has one. Make sure power is off, then check the two connections inside that box. Usually the black wire is melted and needs to be repaired and re-connected with a new wire nut. Good luck!
Jun 10, 2007 | Bosch 24 in. SGS43C12 Classixx...
Bosch 24 in. SGV53E03 Built-In Dishwasher Logo
85 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
