Question about Frigidaire 24 in. FDB510LC Free-standing Dishwasher
Refrigerator will not run-has bad outside odor
Smells like rubber burning
  • 89 Answers
It is very common for the "relays" to go out on the compressor. The relays are mounted on the left side of the compressor. You need to find an "Appliance Parts Store" and buy an "RO-41". (this is a relay) it cost no more than 10 bucks. Go home with you new bought relay and pull your refrigerator out from the wall. Don't forget to unplug it! Take off the rectangle card board cover off the bottom of the refrigerator "in back"... More than likely 1/4 nut driver. Now look for the compressor--"The Roundish black thing the size of a basketball". Next, you will see a box looking thing (black, white) mounted on the side of the compressor with 2 wires going to it. Next take it off the side of the compressor. It just pulls straight off! Sometime though it may be held in place by a little clip. Now read the instructions with the RO-41(inside cover). You will end up cutting the old relays off. Take the two wires that went to it and wire them into the relay(follow the instructions w/relay) then other wires on relay plug right into the compressor! AND THATS IT! It sounds hard but aint... goodluck!!!
Posted on Dec 15, 2007
Burning plastic smell when cold out run heater and fan inside car and out
Are you loosing radiator fluid. sometimes the heater core will rupture and you will smell burn odor. also check for strange rubbing sounds or screeching coming from the blower fan motor. or engine exhaust manifolds are hot when car is on, make sure nothing is leaning on them which will cause a burn odor. Any odor coming from outside will find it's way inside through the fresh air vents.
Feb 13, 2016 | Cars & Trucks
Smells like burning rubber
Good afternoon friend, thank you for your post!
I understand that you are receiving a burning rubber smell from your Frigidaire refrigerator. I would like to ask you some additional questions to better assist you. How long have you been experiencing this smell? Have you noticed any additional symptoms? How often do you smell it? With this additional information I can provide further assistance. I look forward to your response. -Matt
Aug 24, 2014 | Frigidaire Refrigerators
2001ford escape burning rubber smell and noise
Check the rear upper strut towers. These are notorious for rusting out, and causing the tire to hit the inner fender well. To my knowledge, no recall on this, but I've fixed a few with a rear quarter panel replacement from rock auto. You wouldn't notice it much on the rear of the vehicle. Smell the rear fender wells for burnt rubber odor.
Apr 03, 2017 | Cars & Trucks
I have a 2004 expedition 5.4 and when running it smells like something is burning. Any idea what it could be?
could you have a small leak in heater core is the smell sweet or something else
Feb 26, 2013 | 2004 Ford Expedition
There is a strong odor coming from the freezer something like a fish smell or a burnt wire. The ice maker is working ok and the fan blows air just fine and the freezer and refrigerator are operating just...
The smell could either be the fan motor or the defrost heating coil...
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Mar 18, 2011 | Amana ABB1927DE Bottom Freezer...
Burning rubber smell from Subaru Legacy
Please have your exaust pipes checked, perhaps a mount is burning. The catalytic converter can make a nasty odor when it is clogged. Check the wear on the serpintine belt.
Sep 18, 2009 | 2001 Subaru Legacy
Dryer stoped running
Your drive belt may have broken if it smelled like rubber burning. If that is the case then your motor bearing are worn out or something has been lodged between your dryer drum and the dryer housing. If the smell was the odor of burning plastic, then your motor is probably burned up.
Feb 24, 2009 | Maytag Dryers
Very Strong Odor When Refrigerator Runs
Without looking at your fridge I would say the strong rubber smell is the heater element has dust on it or the heater contactor is closed and the heaters are staying on. Either way it would be good to get it checked out. I cannot think of anything else that would make a rubber burning smell.
Jan 23, 2009 | Frigidaire FRS26R4A Side by Side...
Odor coming from back of fridge
This is very unusual, most of the time when I get complaints about odor it's form the inside of the cabinet. This should be easy enough to solve though. The odor is likely from dust accumulated underneath, or from something in the drain pan. If the unit has visible fiberglass insulation underneath you should replace it with new because, even if the source of the odor has been removed, the insulation can still contain it.
Unplug the refrigerator, take off the kick plate and rear cover. Clean and vacuum the entire under- carriage, condenser, fan, and condensation evaporator tray.
Be gentle with the components though, especially the capillary tube ( a pipe about the size of a 14 gauge copper wire )
Jan 06, 2009 | KitchenAid Superba Architect KSCS25INSS...
Burning plastic smell INSIDE refrigerator
look for a door/light switch, and depress it do the lights go out?? bad switch will keep the lights on and melt plastic lens covers.. could also be nothing and you happened to open open the door right as a defrost cycle was completing( there is a heating elemnt in your freezer) watch your dairy, ice cream nad milk are real good indicators of refrigeration issues. as far as runnig all the time no real" time limit" as to how long it should be running.
Mar 03, 2008 | Refrigerators
Frigidaire 24 in. FDB510LC Free-standing Dishwasher Logo
215 people viewed this question
Top Frigidaire Dishwashers Experts
Carmen Mikulic
Mike
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
