Question about Whirlpool Duet GHW9150P Front Load Washer
When i do a Heavy load i am getting an error code that flashed D and L. Whats the issue
  • Whirlpool Master
  • 3,361 Answers
Your door lock is out of adjustment.
Posted on Sep 23, 2009
My name is raza. i have west point washing machine model no 1225tl , Fix error LE is coming. please tell me about this urgent.
An LE error code on the washer's display indicates that the motor is locked, possibly due to a heavy wash load.
Large and heavy sized loads will put a strain on the motor, causing the LE code to occur. Performing a reset on the washer will normally resolve this error.
To reset the washing machine:
  1. Press POWER to turn the washer off
  2. Unplug the washer from the power outlet. If the outlet cannot be reached, turn the circuit breaker to the unit off.
  3. With the power disabled to the washer, press and hold the START/PAUSE button for 5 seconds.
  4. Plug the washer back in, or turn the circuit breaker back on.
The washer should now be reset and the LE code cleared. If washing a heavy or large load, reduce the load size and attempt to restart the cycle.
Note: For your safety and to preserve your warranty, if the issue persists, LG recommends that all repairs are performed by an Authorized Service Center.
Jan 06, 2017 | Washing Machines
I have 3blinking lights on a Samsung dishwasher DW9733LRABB/AA the normal,heavy, and smart auto
Dishwasher Heavy Error Code Repair Samsung - YouTube
? 2:24
https://www.youtube.com/watch?v=uLoj9TpqVRM
Aug 14, 2014 - Uploaded by JoeBrownToolGuy
Dishwasher error code "Heavy" flashing light. Samsung Model DMT400. Video shows what you need to do ...
Nov 23, 2015 | Samsung Dishwashers
The waching machine won't do anything when turn to rinse or wash, it only starts to rotate when turned to spin? the machine is only 2 1/2 years old
Whats the exact brand and model.Is it front load or top load.Is it showing any error code on display or any flashing light error code.Is it draining properly or not draining.Also is it making any kind of noise when turned towards spin mode.------------------- Keep updated with the details.Thanks.Helpmech.
Jan 30, 2011 | Kenmore Kitchen Ranges
Someone put some heavy things in it and it stopped mid-cycle. We removed the heavy objects, and then attempted to drain the leftover water by putting it on "rinse and spin." It never really...
The ND error code on a digital Neptune front load washer. The ND code means 'No Drain' and it is probably just something caught in the pump. Sometimes this is a early sign of the pump going out or a control board issue.
Nov 23, 2010 | Maytag Neptune MAH5500B Front Load Washer
Flashing f 21 heavy loads will not drain and spin
When F21 error code appears press PAUSE/CANCEL two times to clear the display.
Also check for the following issues
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Thank you !!
Jun 29, 2010 | Whirlpool Duet GHW9150P Front Load Washer
2003 ford f 150 4.6 v8 and the idle went from smooth to rough also sputters and sluggish while driving check engine light is flashing.
have the vehicle scanned for error codes at autozone, its free. Post codes for more help....These engines have issues with the COPs (ignition coils-over-plugs) failing prior to 80k miles. When they fail typical problems are: Sputtering under load/acceleration, rough idle, random misfires, random stalling, light or heavy jerking under load (usually at 15-35mph and 45-65mph)..hopefully this helps!!
Apr 28, 2010 | 2003 Ford F150 Regular Cab
Flashing ce
Most all error codes on a Calypso end up being a pump problem. If all the water can't be pumped out, the tub gets too heavy for the motor to handle and it will cause a CE error code. Something like lint or wire or screw may be caught in pump impellar. If your not familiar with repair you need to call for service.
Feb 02, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Error code 7
The error code 7 is in fact a motor error.
The motor that drives the spin cycle has become faulty. The only solution now is to get an engineer in to fix it or get it sent away to get repaired.
Sep 08, 2008 | Haier XQG50-11 Front Load Washer / Dryer
Error codes
if this is a fridgidaire washer, I guess it's a clogged coin catcher. You have remove the front access panel and clean it out. I am working on that now.
Nov 05, 2007 | Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
32 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
