Question about HP 9200C Digital Sender
Our HP 9200c scanner keeps getting error 49 errors and we have to reset LDAP to make it recognize addresses. Have you seen these symptoms before and are they related? What would you recommend?
Santy
  • 14 Answers
SOURCE: HP Scanjet 4400c not recognized by Windows XP Home Edition
Try downloading the drivers from the HP website at: http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&cc=us&dlc=en&product=61902&lang=en
Posted on May 01, 2007
ImWireless
  • 113 Answers
SOURCE: HP ScanJet 6200C
Did you try connecting the scanner to a diffrent computer or tried a different cable to connect it to the computer?? Try this and let me know if there are any further concerns. Good Luck
Posted on May 11, 2007
SOURCE: hp scanjet 6200c scanner recognised only as printer by pc
Where can I find p scanjet 6200c software/drivers for mac? Thank you
Posted on Nov 28, 2008
SOURCE: HP 9200C Digital Sender
Just change the memory flash for HP 9200, if the problem persist, change the power supply.
Posted on Apr 23, 2009
bschilz
  • 2049 Answers
SOURCE: hp m2727 nf Scanner Error 5
Everything I'm reading online at HP says that either will be fixed when you re-initialize or you have to send the Printer/Scanner into HP for repair. The customer service says to call the Support line: 1-800-474-6836 to help with re-initialization.
From what I can see this is a common problem and even happens frequently on brand new machines.
If you are adept at repairing a printer. here is a link to a forum where a number of people talk about what they've done.
http://forums11.itrc.hp.com/service/forums/bizsupport/questionanswer.do?threadId=1114797&prodTypeId=18972&prodSeriesId=3377075
Posted on Oct 04, 2009
I keep getting error code NVRAM err=0x10, what does this mean?
HP Printers 49.XXXX Service Errors ' Market Point's Tech ...
blog.marketpoint.com/2010/07/29/hp-printers-49-xxxx-service-errors/
Jul 29, 2010 - In this article, I'll discuss the meaning of the error, what causes it, and gives ... changes with the firmware or other parts to prevent the error from recurring. ...fixes for a few printers and was surprised to see several 49 errors being ... try a cold reset or NVRAM initialization (see service manual for details).
A wifi spot named "NVRAM WARNING: ERR = 0x10" - DealExtreme Forum
club.dx.com/forums/forums.dx/threadid.1136935
Mar 11, 2012 - A wifi spot named "NVRAM WARNING: ERR = 0x10" ... It has the sameerror, both in wifi settings and in the wifi Analyser app. I did obtain the ...
57.1 printer error - HP Support Center
Dec 17, 2015 | Office Equipment & Supplies
Tip
How To Fix The HP Printer Error 49? The HP printer 49 error is a...
The HP printer 49 error is a result of an internal communication issue where the firm has led to a critical error and the formatter processor has simply aborted its operation. The error also has letters defined as XXXX which refers to the issue of this fault. HP records these messages so that if they have started recognizing a high level of error with the same fault address they can easily focus on making various changes with the firmware or other such parts to help prevent the error from executing on repeated basis. According to HP technical support experts, it is said that the error 49 error is a serious cause of a bad printing command, corrupted data, various invalid operations, firmware, formatter, or even it is possible due to EIO card or memory accessories.
Steps to fix the HP Printer error 49
Step1: Power-Off Phase
    ·Power off the device and then carefully disconnect all the communication cables; Network, USB, or Parallel cable.
    ·Wait at-least for 30 seconds and then turn the device back on. If the error still exists then it is a possible device error. If the error does not go away then it is a symbol of Communication Between the Computer and Network Step2: Managing the printer
      ·Unplug the printer and then carefully remove all the accessories such as EIO cards, memory, extra trays, duplexer (if removable), and envelope feeder.
      ·If the error does not exists after you have powered on the printer, start reinstalling the parts one at a time, by powering off before you go ahead with the installation phase of each part till you find the error cause. Next, the firmware needs to be updated to fix this type of issue. Step3: Further method
        ·If the 49 error is present in the printer after removing possible causes then try a cold reset or NVRAM initialization method first. A cold reset process will further reset every minor stored memory settings such as control panel settings or internal and external jet direct settings. NVRAM is more elusive as well as clears out all the internal memory such as error logs and other possible counters.
        ·If this 49 error continues to exists, it is advised by HP tech support experts to replace the firmware DIMM, if there is one.
        ·Check for a proper service manual for specific 49 errors parts Get in touch with our HP customer support Toll-Free 1-800-213-8289
        department for instant solutions to your issues now! We are always there to help you out for any related HP printer error queries.
on Apr 28, 2017 | Miscellaneous
HP COLOR LASER JET 2605 PRINTER 49 ERROR MSG DISPLAY SOLUTION
49 errors are most commonly caused when the printer receives a print job with commands it does not recognize. You can try updating the firmware as this will often resolve the error. Go to HP's website to find the most recent firmware, however this model is fairly old and likely the firmware update will be fairly old.
Sep 25, 2014 | HP Laserjet 2605dn Workgroup Laser Printer
Ricoh MF Copier, destination list cannot be used now, using ldap,
When it say the list can not be used, it means the hard drive/disk thet keeps your addresses have failed. The fast way would be to format the hard drive/disk and re-program your info. This commonly happens when the hard drive/disk is active during a power surge/failure or incorrect shut down. Go to service mode by pressing yellow button then 107 then hold the red/stop button for more than 5 seconds, when the screen changes press the first option on the screen(should be copy or system), now press 5832 (HD format) and enter/execute, when "completed" is displayed switch off and on. Now open your internet browser on PC, take out the web address and input your printer IP and press enter, username-admin, no password, on the left of the screen click on address book, now go to add, input all you info and press ok, now log out on the top right of the screen and test scanner.
May 01, 2014 | Ricoh Aficio 1515MF All-In-One Laser...
When the printer is booting it is stuck at **************************, when it do comes on it comes with error code Error 49.4c02 Product model: HP Laserjet 4100N
Thank you for contacting FixYa with your printer inquiry.
HP Laser Jet 4100 49.4C02 Error
49.xxxx PRINTER ERROR
Description 49 errors are generally communication errors or file related issues and can usually be resolved by following the steps below:
Action Turn the printer off, and then turn it on again.
If the 49 error returns turn the power off, unplug the power cable, disconnect all network cables, and remove the HP Jetdirect card (or any third-party devices), if installed.
Wait at least 30 seconds before plugging the printer back in directly to a wall outlet. Do not plug the printer into a power strip or a surge protector.
Turn the printer on. If the 49 error returns, turn the power off, and then unplug the printer. Remove the formatter board.
Check that the parallel I/O board is firmly installed on the formatter board.
Check for any non-HP memory DIMMs. If any extra memory is installed, remove it.
Reconnect the power cord, and turn the power on.
If the 49 error returns, perform a cold reset.
Watch the control panel.
When the memory starts counting, press and hold the green (Select) button.
Continue holding the green (Select) button until the Ready, Data, and Attention lights flash once, and then stay on steady.
Release the (Select) button when the Ready, Data, and Attention light are on steady. The control panel will display SELECT LANGUAGE.
Press (Down Arrow) button once. The control panel will display COLD RESET.
Press (Select). The printer will perform a cold reset and then continue its power-on sequence. If the error code continues to come back, it requires a firmware upgrade.
If the 49 error returns, contact an HP-authorized service or support provider.
Hope this helps helps. Please keep us updated and remember to rate this answer.
TF
Jan 05, 2011 | HP LaserJet 4350 Printer
HP 3050 Engine Comm error
I have a HP 3050 three in one and I keep getting a engine comm error
Aug 02, 2009 | HP LaserJet 3050 All-In-One Printer
replace the jet direct card
Apr 26, 2007 | HP 9200C Digital Sender
HP 9200C Digital Sender Logo
119 people viewed this question
Seeker5211
Seeker5211
