Question about LG RU-52SZ51D 52" Rear Projection HDTV-Ready Television
Reset lamp timer
I recently had my lamp replaced on my 52in TV but the service guy can't figure out how to rest the lamp timer . Can you hel?
    Problem Solver:
  • 15 Answers
Hold the menu button on the TV and menu button on the remote for 5 seconds.The service menu should appear.Select the lamp option and reset lamp hours.
Posted on Dec 15, 2007
I recently replaced the TY-LA1000 lamp but I'm getting a yellow flashing light that goes on every 5 secs.I made sure that it was installed correctly and tried resetting the timer by pressing + and - o
Yellow flashing light? Did you get any picture? Bet, not!
It means: your lamp door interlock is not engaged: did you forget to turn the locking knob? Did you install lamp compartment door? That might be the only issue. Lamp timer blinks 'red", while TV works normally. Reset the timer, it's gone, along with annoying message. Yellow means: interlock or thermal protection is off. Try to repeat lamp installation procedure. then, you'll find out your mistake. don't need to remove the lamp. It would be "red", if lamp won't fire up.
good luck,
Dec 06, 2011 | Panasonic Televison & Video
How to reset the lamp timer on Sony Projection TVs.
If you have replaced the lamp in your Sony projection TV you must reset the lamp timer to get rid of the message saying that your lamp needs to be replaced. Let's face it, you know you already accomplished replacing the lamp but the TV isn't smart enough to know that. I will explain in detail how to accomplish the reset procedure.
Resetting the lamp timer is a complicated procedure but you should be able to do it if you have plenty of patience and know how to follow instructions. Read the procedure over first several times before trying to do it and locate all the buttons on the remote. You may want to try the procedure on the remote to make sure that you have the sequence memorized.
By the way the lamp life is figured to be from 5000 to 8000 hours. That is not much time if the TV is being used for more than 8 hours per day. If you do the math and watch your TV for 8 hours per day (not uncommon) the lamp will need replaced in 3 to 5 years. So be ready to do this procedure again in the very near future.
Here is the procedure.
All commands should be done using the factory remote:
1) enter the service mode by pressing display, 5, volume +, Power on
2) press JUMP 3 times
3) to display the time press channel 2, 9 times
4) to reset lamp timer press channel 3, MUTE, Enter
5) to check the time press channel 1, 7 times
6) when complete turn set off to exit.
Thanks for using FixYa and for the great rating. Please consider a testimonial. Thank You.
on Oct 30, 2010 | Televison & Video
Procedure for resetting your lamp timer,
Use the Remote Commander to put the set into service mode to display the service menus.
1. TV must be in standby mode (Power off).
2. Press the following buttons on the Remote commander within a second of each other: DISPLAY ==> Channel 5 ==> Volume + ==> POWER. The first service menu (TV) displays.
To reset the Lamp Timer:
1. Press the JUMP button 3 times on the remote to get to the Panel OSD mode.
2. Next press the remote channel 2 button 9 times to get to the Lamp Timer mode.
3. Press the remote 3 button, mute, then enter to reset the timer to zero.
It will take 45-50 seconds for the timer to reset. After the timer is reset you can shut the TV off. The lamp timer will remain reset (no need to save).
Jun 30, 2011 | Sony Televison & Video
TY-LA1001-K I replaced the lamp and didnt restet
I have searched and searched on how to reset the timer. Most solutions say you have to press and hold the volume down button on the tv while also holding down the zero button on the remote, or the pip or split button on the remote until the screen display reads that the timer has been reset to zero or the lamp and power button both flash.
I have tried every combination and cannot seem to reset my lamp timer. If you figure it out, please share it with us!! I'm frustrated and can't get it to work!!
May 07, 2010 | Panasonic PT-52LCX66 Projection Television
After just recently replacing the bulb I am
Here is proceudre to reset lamp timer in your TV..
While pressing the VOL Down button on the projection display, hold down the PIP or SPLIT button on the remote control at same time for more than 5 seconds.
When reset procedure is complete, the screen message ' lamp time was reset to 0' will appear.
Hope this info will help you.
Nov 18, 2009 | Panasonic TY-LA1000 Projector Lamp for...
Same problem
You mean physically replace the lamp or reset the lamp timer?
To replace the lamp, you unplug the TV, take the front cover off of the TV under the screen, open the little door, unscrew a screw, then pull a handle that will pull out the entire lamp assembly.
Shove the new lamp assembly in place, reattach the screw, shut the door, snap the panel back on, and fire it up.
To reset the lamp timer you have to have your TV remote (not a universal - the original remote). Turn the TV on and wait for the lamp timer reset message to disappear or push Exit on the remote (or any button similar to exit, depending on the model).
Then, simultaneously press and hold the VOL- button on the TV and the PIP button on the remote at the same time (usually near the bottom left of the remote). On some models it is the SPLIT button instead.
IRT the other answer, there are more than one type of rear projection television. The one's you have seen with three lamps are CRT-based and have one CRT for each primary color of red, green, and blue. Panasonic no longer makes these and any issues with the lamps must be referred to an authorized servicer. Therefore, I conclude in this case that the question is in reference to a DLP or LCD rear projection display.
Aug 22, 2009 | Panasonic PT-44LCX65 Television
Turns off by itself-Powerled blinks 5 times
the lamp driver is the power supply which supplies the lamp with electricity. with the rear cover removed it is located in the center. there are 4 screws holding it in place and you will see 2 thick red wires leading to the lamp.replaced this ( part # 1-468-875-11 ) and your tv will be ready for the super bowl
Jan 19, 2009 | Sony KDF-E55A20 55 in. LCD Television
Lg tv 52sz8r-tb new lamp installed, red lamp light still on
you need to reset your lamp hours timer. as far as i know this can only be done with the service remote
Dec 12, 2008 | Televison & Video
Replacing the projection lamp
Try resseting the lamp timer following the info below: Procedure for resetting the KDF42WE655, KDF50WE655, KDF55WF655, KDF55XS955, KDF60WF655 or KDF60XS955 lamp timer:
Dec 05, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
Zenith Lamp Light on
When the lamp is replaced the lamp timer must be reset. The timer is set for just so many hours and then the warning lamp is illuminated. The only way to reset the lamp that I am aware of is with a zenith programmer remote. Perhaps you can find a local lg/zen service center to allow you to use a programmer and instruct you on resetting the timer.
Jan 29, 2008 | Zenith E44W46LCD 44" Rear Projection...
LG RU-52SZ51D 52" Rear Projection HDTV-Ready Television Logo
167 people viewed this question
Computer Repairing
Computer Repairing
