Question about Kenmore Elite 45986 Front Load Washer
How do I change front seal? - Kenmore Elite 45986 Front Load Washer
    President:
  • 704 Answers
You can order and get a new bellows gasket online or from a local appliance shop, as prices vary slightly from place to place. I suggest www.searpartsdirect.com as they usually have the part in stock and you can get it shipped to you anywhere in the US without having to run all around trying to find one locally, etc.
You're missing a couple of digits or letters in your model number, but once you get to the sears parts site, just enter in your complete model number to get a line drawing and parts list for your unit. You can also call the folks at Sears Parts Direct at 1-800-252-1698 and give them your complete model number AND serial number before you start in on the repair, so you can be sure you have got the correct bellows gasket.
It's a relatively easy repair, all you need to do is remove the spring retaining wire around the outer edge of the bellows gasket, just peel it back at the edge to see it. Now locate the locking loop by going around the rim. Once you find the locking loop, you can remove it using a couple pairs of small needle nose pliers as they make it easier to get off.
Once you've done that, you'll see the large hose clamp that holds the other side of the bellows onto the outer wash tub. You can use a nut driver or a small socket and drive to loosen it and remove it from the tub. Once you've done that, the clamp and bellows will be free to take out of the washer. Now you can give all the edges and rims a wipe down with a rag to get rid of any gunk or residue to make installation of the new bellows gasker easier and less likely to leakage. Now just reverse the order and carefully put the backside of the bellows gasket onto the tub and position the clamp over the bellows and tighten it, being careful not to overtighten the clamp so it could damage the gasket. Now carefully pull and install the front edge of the bellows gasket over the outer cabinet lip, working it around the circle a little at a time. You might need someone to help you hold the starting spot, while you continue getting the rest of the gasket onto the lip. Once you've got the gasket on the outer lip, reinstall the locking wire and you're done. Check to make sure the door closes properly and you should be able to wash without any leaks. Remember, take your time when doing the installation so as not to rip or tear it in the process. I'd also suggest you let the new gasket relax for a good 4-5 hours (to get the kinks and folds out of it from the packing box) before you do the installation so it'll be easier to install.
Hope you find this Very Helpful and best regards!
Posted on Sep 23, 2009
  • 5,911 Answers
If you are referring to the door bellow (gray rubber seal) on a kenmore Elite front loader, the following link explains step-by-step how to replace one:
http://www.fixya.com/support/r385210-replacing_door_bellow_kenmore_elite
If you have any questions about this repair, or need additional assistance, please let me know. I hope this helps you.
How do you change the left front axle seal?
Raise and support vehicle, remove left front wheel, separate left front spindle and remove axle nut, remove left front axle, now you can get to axle seal. Replace seal and reinstall front end.
Jul 25, 2014 | 2006 Chevrolet TrailBlazer LS
96 Jeep Grand Cherokee torque converter front shaft seal
the torque converter does not have a seal. there is a front pump seal in the ****** ,and you have to drop the ******
Oct 29, 2012 | 1996 Jeep Grand Cherokee
Replacing door seal front loader bosch
This video will show you how to change a door seal on this bosch
Apr 04, 2010 | Kenmore HE2 Plus Front Load Washer
Front seal leaking in my bosch exxcel 1200
This video will show you how to change a door seal on this bosch bosch exxcel 1200
Mar 28, 2010 | Bosch Classixx WFL 2066 Front Load Washer
How do I replace the door seal to a Bosch Front loader washer Maxx Classic WAE18060AU?
To change the seal the easiest way is to take the front of the appliance off. Remove the kick plate at bottom and you will see some screws holding the front panel on remove these Then open door and remove the screws holding the door lock on and unlip the seal by releasing the clamp on the front. The front should now lift off, if it doesnt then pull out the soap drawer and behind that at the bottom of the drawer is a screw holding the front on remove this then push the front panel down then it will lift off You can now take the clamp holding the seal to the tub off. Fit the new seal, fit the clamp to the seal and tub. From here, rebuilding is the reverse of the strip down.
Feb 18, 2010 | Bosch Classixx WFO 2466 Front Load Washer
How to change front main oil seal on 2001 chevy 8.1
you will need a puller to remove the front crank pulley/ balancer. then its a matter of prying the seal out.
Oct 19, 2009 | 2001 Chevrolet Silverado 2500HD
Transmission leaking nearfront changed front seal still leaking transmission fluid
Most transissions front leak is the front seal but it can also be the pump gasket over flow expelling fluid.To save money you should first change the filter. Them if it still leaks pull the trany and pull the front pump and change the gaskets and seals. If this does not fix it then you should seek professional help.
Jun 20, 2009 | 1999 Chevrolet Silverado 1500
Door seal has two holes in it and leaking
Hi.
You need to remove the front console panel and then the front panel to change the door seal.
Pull the dispenser drawer out and remove the screws.
Slide the console panel to the right and support it while you remove the rfont panel.
Change the seal, and reassemble in reverse order.
Good luck.
Nov 20, 2008 | Hotpoint Ultima WF860 Front Load Washer
2005 Yukon Front Diff Axle seals
You don't have to remove the whole diff to change the seals, but you will have to seperate it where the shaft meets the carrier housing. There is a clip holding the passenger axle shaft in place that you have to remove to change the seal. The drivers side axle stub can be removed with a little force as there is a spring clip holding that side in.
Sep 01, 2008 | 2003 GMC Yukon
Changing front loader seal
easy.isolate from mains. take top off.remove clamp that holds seal to cabinet and unpeal seal from cabinet. seal is held to tub by a clamp (like a huge jubilee clip) undo and peel seal from tub. when fixing new seal, lubricate with washing=up fluid
Dec 11, 2006 | Hotpoint WMA58 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
235 people viewed this question
Sal DeAngelo
fordexpert
Mike Squire
