What happens to the battery when there is water damage? is there some sort of indication or mark that appears on the battery after water damage?
What happen to d radiator if when u pour d coolant in it mix with oil and leaks out
Hi,normaly this indicates that the headgasket has failed,which means the oil mixes with the water,dont drive or run car in this condition it will couse more damage,sorry,hope you get it sorted.
Sep 06, 2015 | Cars & Trucks
Samsung mobile sgh e840 fell into water
remove all possible [parts, battery, back cover, sim card, memory card and other things you can open using a special screw driver, let it dry several days or use a hair dryer on cool settings until determined everything is dry.
As for the battery, let is dry under the hot sun before attempting to put it back in the phone.
after that make a simple power on test, if it works, you are in luck, otherwise consider your phone completely water damaged and will not be accepted for repair due to the red water damage mark indicator.
Nov 25, 2013 | Computers & Internet
Might have water damage but power is off and won't turn on
Can u change the battery and see if that was the issue? If so and its not the battery you could open the watch on visibly check for black/scourched marks that would indicate that (probably the water) something has shorted said part(s) with the marks. If you see nothing strange then its time to use a meter to test parts.
Mar 31, 2013 | Watches
My Samsung SGH-E420 has completely stopped responding - no sign of life at all. Any ideas what's wrong?
Could be a number of problems take out the battery and look for a water mark, if any bright red color on battery or back of phone could indicate water damage. Look into upgrading
Apr 02, 2010 | Cell Phones
Phone won't hold charge
You can get a universal charger that charges the battery independent of the phone at :
http://www.factorydirectcellular.com/home/universal/universal-battery-only-charger.htm#instructions
I got one for my phone and it works GREAT!
Sep 23, 2009 | LG enV VX9900 Cellular Phone
Samsung SGH-i617 where is the water mark?
I'm not really sure about the "water mark", is it the liquid damage indicator that you are referring to? it is located at the back of the phone or on the battery, it is a white little square sticker that changes color to pink when the phone got wet.
Jul 05, 2009 | Samsung Cell Phones
Samsung A737 water damage..??
the little square that you are referring to is a liquid damage indicator, it will change it's color if the phone is exposed to any kind of liquid or moisture.
Jun 27, 2009 | Samsung SGH-a737 Cellular Phone
Same ting just happened
Well if anybody else has this problem, I've managed a solution but haven't confirmed if it fixes it permanently. It turns out the main cause for this is due to water damage but it can be from either direct contact or sweaty fingers of some sort. The solution is to take the battery out and leave the RAZR opened up to dry out for 12-24 hours. That way the keypads can return to normal under little contact/use the next day. The water damage may be slight so I recommend staying out of contact with the RAZR for a long period of time afterwards (presumably a day).
Jun 18, 2009 | Motorola Mobility RAZR V3
Verizon Voyager will not chage or work on battery, fine on AC
Sounds like the battery connections may be corroded, try gently cleaning them with a pencil eraser. Clean the connections on the battery and in the phone. Water damage is indicated by a red indicator in the phone. if it is red it indicates water damage which is probably why they will not replace it. If you have insurance on the phone that may be an option for you.
Apr 21, 2009 | LG VOYAGER VX10000 Cellular Phone
Computers & Internet Logo
50 people viewed this question
David Payne
David Payne
