Question about Western Digital Passport 320GB External USB 2.0 Hard Drive
WD3200BMV not recognized on my laptop
I used my WD3200BMV on another laptop to save some info and when I plugged in back into my laptop it is not working....will not open, says I need to reformat.....I have a ton of important documents, pics, homework that I MUST retrieve....please help
    Novelist:
  • 144 Answers
Try plugging it back into the last laptop it worked in, the other one. and then see if you can 'safely remove' the hardware instead of just unplugging the usb. now try it in your computer.
if thats no good. reboot your laptop, and try to use a one of its different USB ports.
Posted on Sep 23, 2009
Sd card not read
Laptops dont recognize sd cards in general... try using where it came from.. digital camera? phone?? plug usb cord in then go c drive and open it as external hardware then view/save as needed
Mar 20, 2013 | Acer Aspire 5610-4648 Notebook
Tip
How to solve the "Battery Plugged in not charging"
Battery Plugged in not charging and not detected solution I have a Dell Vostro 1510 laptop, and when i have the battery charger plugged in, the battery icon says "10% available (plugged in, not charging)", and if i pull out the cord, the laptop shuts down straight away. Can this be fixed, and if so, how? I bought this laptop new around 6 months ago. The detail info below:
plugged-in-not-charging.jpg The Battery didn't charge or detect being plugged in also caused by four reasons:
  • 1. The laptop battery failed
  • 2. The Adapter failed (can not charge the battery)
  • 3. The motherboard charging electric circuit failed (many caused by short damage). You can view more info here: Dell Motherboard Problem
  • 4. The laptop bios is too old to recognize the battery
After I checked my battery and adapter and confirm they are good. Then I try to repair it by myself.. My Latitude E6400 battery was fixed by myself.
The first solution :I search in the google: Repairman from another site suggested that while the computer is on and plugged in, to unplug the adapter and then plug it back in again. To check the computer can started charging.
So I remove the laptop battery from the laptop and left the AC cord connected, booting it up on the power cord alone until I was able to boot into Windows 7, at which point I then put the laptop battery back into the computer while it was still on. This worked and while a tad unsafe for most people, I wouldn’t recommend you use this idea unless you absolutely had to, that is, if there was no other choice.
The Second Solution: You can download the newest BIOS from dell.com and then flash the bios. But I do not want to update Bios, So I use another way to make the Power manager system to recognize my battery :)
I open up my laptop Device Manager (usually a right click on your Computer/My Computer) and remove all Dell inspiron 6400 battery related devices from the Device Manager. Then after you’ve done that, right click again and select “Scan for Changes”, which should reinstall the proper services and allow for your laptop to charge again. See the more info in the image below.
remove-battery.png If this also can not solve the problem, I suggest you send the laptop to Dell to repair the Laptop motherboard.
The article Via laptop battery blog
on May 27, 2010 | Computers & Internet
My mac laptop suddenly won't recognize it
you may need to swap the usb port it's plugged in
Jun 11, 2012 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
I have a TOSHIBA STOR.E ART 3 ( 1 terabyte ) which is loaded with info from my laptop, then I replaced my laptop with a new laptop and every time I plug in the hard drive firstly i did not recognize the...
Your new laptop is having trouble reading the file system of your drive. the easiest way around this problem is to copy your drive to another drive. then reattach the drive and when it asks to format it say yes. After it has formatted the drive just see if you can use it to save a doc say and then see if it will delete it. If the drive now works ok then copy back all your data onto it and all should be well.
Funny things computers????
Jun 19, 2011 | Computers & Internet
I have the 1.5 TB Western Digital my book--I did the proper steps to reformat it to have it work with my macbook. My playstation 3 does not recognize that anything is plugged in when I hook it up with...
PS3 can recognize only hard disks that are formatted on FAT32. Since now the disk is formatted to HFS (a format only Mac's are using) you can't make it work. Save all the files on it and reformat it to FAT, then put back the files and only then connect it to the PS3.
Mar 28, 2011 | Western Digital My Book Essential 1TB...
I somehow deleted the mouse from my laptop!
Hi there
I read your report. OK you can go to save mode and it will automatically give you your mouse back so you can go to admin rights to restore your computer. So you can get your mouse back. But if your system not set to do that. i recommend you get yourself a usb mouse for your labtop . it will automatically recognize this new mouse. I hope this little info helps. Thank you for writing to fix ya.
Best Regards Richard
Dec 03, 2009 | Office Equipment & Supplies
I need help opening a file saved on my memory stick with my pc
IF the win98 box wont recognize the usb stick you will need to install the drivers in order for the OS to recognize the device, after this you should be able to see the device and files on it
Jan 22, 2009 | Computers & Internet
PNY Optima Pro Attache 4 G
Make sure you are using the right port. There are slow and faster ports on a laptop.. So try plugging it into another and see if it helps
Jul 18, 2008 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
Computer won't recognize drive is plugged in
That's the problem right there. Your external hard drive is formatted for Windows, so you won't be able to access files off your Mac laptop.
Feb 28, 2008 | Maxtor Personal Storage 3200 (U01E200) 200...
Western Digital Passport 320GB External USB 2.0 Hard Drive Logo
1,262 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
