Question about Poulan "" Push Mower
Mulching lawnmower does not mulch. Mowed on Saturday, and raked when finished. Mowed aging on Tuesday. Grass needed to be raked again! Why?
4 Suggested Answers
  • 124 Answers
SOURCE: how to change from mulching to grass catcher
What is the model number and do you have the catcher or do you need to purchase one. you can contact southern supply company at 205-833-2525 or email them at southern.supply@mindspring.com and I feel sure Jason or someone there can help you.
Posted on Sep 15, 2009
Testimonial: "thanks, I managed to find the manual."
  • 93 Answers
SOURCE: poulan push mower question
Check the engine manufacturers web site. You will need your engine number. .....You will find an on line diagram and part numbers for your engine. Also, Most Mower Parts stores have the same thing !
Posted on Sep 17, 2009
  • 293 Answers
SOURCE: Poulan Pro PR550N22SH does not mulch properly.
Can you describe in details what is the problem with the molching on this machine? What exactly is happening to the molch?
thanks
Posted on Jul 27, 2011
Briggs and stratton 190 cc toro lawnmower engine runs too slowly for mulching operation. How can I increase rpms?
Mulching loads the engine much greater than collecting or side ejecting as the grass cannot escape, maximum revs should not exceed 3600, there will be a stronger govenor spring available, or bending the arm that connects to the spring, but do not exceed 3600
Jun 01, 2012 | Briggs & Stratton Garden
My 21: self propelled yardworks lawnmower leaves a strip of grass about one thiird from the left hand side of the mower when i mulch with it. When I bag it works good.
I'd check your blade and see if it needs sharpening. The mulching mowers need to cut then vacuum the grass up and then cut it again. They must be properly sharpened for this process to work properly.
James
Aug 26, 2011 | Garden
I own a cordless Black & Decker 19" rechargeable mulching mower, CMM 1200, 24V. There are days that it starts beautifully, and others where it remains quiet and uncooperative. Temperature seems to...
Mulching mowers are notorious for needing to be cleaned out frequently. The problem usually is the cutting height. The lower it is, the faster it gets clogged up.
Cutting wet grass doesn't help this situation either, it actually makes it clog up much faster.
Set the cutting height to about 3", and wait until the grass is dry before you cut it. This should help with the cuttings buildup.
As a landscaper, I deal with lawnmowers on almost a daily basis, and on cold mornings, the mowers are sluggish and don't want to run well.
If you keep your mower stored in a weather proof building with a consistent temperature and humidity level, there shouldn't be many issues with startup. Start it up and let it idle at half choke before cutting.
I hope this helps you.
var geo_Partner = '1890d1e7-e721-4f9c-b474-1a19eda23e94'; var geo_isCG = true;
Jul 31, 2011 | Black & Decker Cmm1200 24v 19" Cordless...
I have a model 944-604810 riding lawn mower and find that it leaves a trail of cut grass even though it is equipped with a mulching blade and a new mulching cover. It would appear that the grass is not...
yes that is most likely the cause of it, also, you have to cut more often when mulching, and the higher the cutting deck, the more likely the grass will blow out without getting mulched enough. More than likely, the blades are dull, and/or the grass is too high, or possibly even wet if it is high.
Aug 23, 2010 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
To mulch my grass clippings, do I have to use the side discharge or can I simply remove the bag and insert the rear plug?
Insert the rear plug if mulching is desired. The key to mulching is to mow the lawn frequently.You want to keep the mower deck height high enough to cut the grass and allow the mulching blades to work, but just low enough to actually cut the grass in a smooth uniform height. To low of a cut setting will clog the mower and create a mess. 2 times a week is a good frequency to start with.
Jun 10, 2010 | Toro Lawnmower 20099 Mower Mowers Lawn
Deck will not shed the grass . the grass has to be cleaned after each mowing, lawn is not mowed when wet,
The only way to shred the grass while mowing is to have a pair of mulching blades on your mower, they work, but they wear out fast. They do in Florida anyway with all the sand. And don't for the grass to look a hayfield to mow it. You have to keep at it. Hope this helps.
Apr 04, 2010 | Husqvarna Garden
I would like to buy a petrol lawn mower, i have found out there are mulching lawn mowers on the market, what are your views on this type of mower
Mulching mowers are great if you dont have the time to rake the excess grass or the means ( time or ability) to dispose of te collected remains. The mower will mulch te grass right back over te top of the cut grass with minimal apperance of grass being left behind, if you kep up on the cutting schedule that is. Better for larger areas where "lines" would usually remaine with a non mulching mower.
Aug 11, 2009 | Black & Decker Black and Decker Mm575 18"...
Can a mulching blade work in a non-mulching mower?
True Mulching mowers have a specific deck design to them, but I would say yes to your question.It's been quite a few years, but I have done this little conversion myself - replace regular blade with a mulching blade. Just make sure the mulch blade does fit your mower. Also, use something substantial in terms of strength to close the discharge opening. There can be a good deal of force placed at the opening from flying debris. You'll also want to make the cover removable, so you can mow damp grass without the cover.
Jun 02, 2009 | Garden
What is the difference in a regular blade and a mulching blade?
A regular blade has a straight cutting edge, a mulching blade is bent to have a high and low cutting edge. Even if you have a mulching blade on, if the grass is too high or wet or you're cutting too low, it won't do a good job and may require a second pass.Raising your cutting height can help. Hope this helps. Dwain
May 17, 2009 | Craftsman Garden
Poulan "" Push Mower Logo
149 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
