Question about Video Game Consoles & Games
My sims got a money bag from a genie and somehow it ended up in the shower so when they want to shower, they cannot. why and how do I fix?
    Problem Solver:
  • 6 Answers
Shift+ctrl+c
type in "boolprop testingcheatsenabled true"
then type in (if the box didn't go away) "moveobjects on"
go to buy mode and move the shower.
go into live mode and have your sim pick up the money bag
make sim walk into other room
go back into buy mode and move the shower once more
type shift+ctrl+c and then enter "moveobjects off"
and again (if the box did not go away) "boolprop testingcheats false"
Posted on Sep 26, 2009
How do you unscrew Hansgrohe showerhead (needs cleaning to remove calcium deposits)?
Easiest is to simply pour some CLR cleaner (from grocery or hardware store, it is a brand name) into a plastic bag, and tie the bag around the pipe with the shower head soaking in the solution.
Easy fix!
Jul 26, 2014 | Hansgrohe Home
Shower problems I have a zy-137 shower and steam cubicle The steam wasn't commingled through the valve and I turned it to have a look one it has come unscrewed and there is a visible hole and I am unable...
Somehow you have to get that pipe coming back through the wall of the shower.
There is a pipe with threads on it that the nozzle threads onto.
Once you can get that pipe back through the shower wall you can thread the steam nozzle back on.
If the steam nozzle has been replaced onto the threaded pipe you can trouble shoot your steamer as to why there is no steam coming out.
ROD
U S Parts Center
May 14, 2014 | Home
Genie 1024 remote programming
On model 1024 genie garage door the carriage trolley jumping out of the chain what should i do to fix it or replace parts...
Feb 19, 2014 | Genie Company Genie Intellicode GITR-3...
The handheld sprayer on my Eurostream NSF 61/9 kitchen faucet will only spray. It will not go to a full stream of water when the faucet is turned on. I have taken it apart and tried to get the spring in...
if the sprayer is old it may need to have some lime or calcium build up -Just fill a small plastic bag half full with white vinegar and attach the bag over your showerhead with a rubber band up side down of course -Leave the bag in place for an hour or two. Then remove the bag and scrub the shower head with an old toothbrush or rag. Your shower head will look and should function like new if that is the problem
Nov 08, 2017 | Home
How do I remove the case from the generator on a B & S motor / power boss 030249? the gov. is fried.
take the end case off the end of geny 3 x 10mm bolts?
on the end of the geny shaft is a 10mm bolt wip it out,
the geny is held to the motor by 3 or 4 bolts wip them out too,
then with a sharp rap on the geny case near the motor end the geny should pop off the taper its held on to the engine crank shaft,,,there tight as well!
Jun 26, 2010 | Briggs & Stratton Power Products 5,550...
My electric shower will not work although the power is still on no water will come through the shower head
Hi im Rossouw
Reamove the head of the shower end clean out the sif at the back of the head , iets easy .let me know if the first trix dont work bt sure that will fix it
Plz rate my advice .
Jun 19, 2010 | Zenith Metal& Shower Caddy
Genie 400PC 16 gal shop vac but can't find filters
If you need paper filters, you can easily use a bag filter cut in half, and have less dust clouds than the original filter. Remember to use the lock ring. Generic ShopVac mini's have the same filter in foam.
Mar 11, 2010 | Genie Company GV150 Wet/Dry Vacuum
Tried to install a one handle delta shower fixture. Water comes on but will not shut off.
Try taking the handle back off, and turning the water back on. Spin the valve stem and see if you can find the off position that way. Hope this helps
Aug 16, 2009 | Delta & Single Handle Shower Faucet
Pantech Matrix water damage T-T
honestly within the past two days I have gotten my matrix soaked...once in the shower and then my boyfriend threw it in the toilet when we were playing around. the first time I used aerosoft keyboard cleaner and sat in on the vents on top of my tv. The second time I wasn't at home so I filled a bag up with rice and silica bags and then turned it on the next day and it's working fine...I just get this random beep every now and then. And I can see moisture in the corner of the screen. My phone has been through hell. Just do what you think is best and go for it. Not in the freezer though...BIG NO NO
Mar 21, 2009 | Pantech U4000 GSM UNLOCKED 1.3MP CAMERA...
Video Game Consoles & Games Logo
77 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
