Teac V7010 posted to me but stop and play buttons
Teac V7010 cassette deck posted to me via E-bay, but very badly packed. Stop and play buttons got bust in transit. Can I get a spare set of Teac buttons. There is a bank of 5 buttons on left front of machine, STOP, PLAY PAUSE REC AND REC MUTE. They look as if they are connected in one long strip?
Without these buttons to push the PCB-mounted switches, I cannot use this deck, so a mega problem!
  • Audio Player... Master
  • 5,056 Answers
Sometimes you can repair these type of connected strips by melting them back together or on with a soldering iron. Do it in a well ventalated room with a mask and goggles, to prevent the plastic fumes going in your eyes.
The only other way is strong superglue.
You could phone the maker if they still have the parts. But I wouldn't hold out much hope if the model is over 3 to 5 years or more old. Even then it might be cheaper to get the same model off E-Bay.
Posted on Sep 25, 2009
Teac troubleshooting
Find the phone number for Richer Sounds, they are helpful and deal with Teac.
Jul 22, 2014 | Teac A420 Cassette Deck
TEAC R-H300 Forward Play Fault
The unit need some work by a technician. The bad thing about the drawer type decks is that it makes it hard or impossible to clean the tape path. I have not seen one of these but I could probably fix it.
Some of your description sound like a loose capstan belt and then other times the Pinch roller is not engaging- they may be related if the mechanism is tied to the capstan motor system.
Sep 11, 2012 | Teac R-H300 Dual Cassette Deck
When playing a tape it may stop randomly and the counter displays zero. I have to push play button again and it goes on; but may stop after a while. It does not depend on cassette type or tape length (I...
This would indicate a power supply problem in that the counter being reset. I would check the entire power supply for a any thermal broken solder joints and redo them with the power off. If you need further help I am in the Chicago area and am known as Skywave Tape Deck Repair.
Feb 07, 2011 | Teac V-8030 Dual Cassette Deck
TEAC CX-370 Cassete Deck
Could be a worn out belt? The cassette loads it the drive down too much. Hence why it turns with no tape.
Jul 04, 2008 | Teac DUAL CASSETTE A/R 110/220 Single Dual...
Older Teac cassette decks
I had an Aiwa dual deck and by the way your describing it, when you select Cont. Play press play on one deck then play on the other. I am not sure if there's a difference as to which you start with. When the first deck is done playing both sides, the unit will goto the second deck and play both sides, then back to deck 1.
Jul 01, 2008 | Audio Players & Recorders
I Have a Teac W525R double auto reverse cassette deck and I cant dub from ;Play (left sd) to Rec. (right sd). What gives? I push rec then play on the other side and the rec stops. Then I tried the other...
Don't do either of those things. Just hit one of the DUB START buttons (NORMAL OR HIGH) Located right under the tape counter. The deck does the rest.
Feb 19, 2008 | Teac Audio Players & Recorders
Cassette Recorder play problem
Sounds like the tape tension sensor is stuck. The sensor is always telling the mechanism that the tape has reached the end.
Sep 17, 2007 | Onkyo TARW255 Single Dual Cassette Deck
304 people viewed this question
 Grubhead
Grubhead
