Question about Ikelite Substrobe A35 w/ Arm and Tray f/ Auto 35 Camera (5468) Light
How is the strobe activated (ikelite A35)
How is the strobe activated and can i screw on a cannon ixus to frame ad have it work
It works from the flas on your camera. It will only sync to your camera as along as the ixus does have no pre flash feature.
Posted on Apr 20, 2010
Have a Ikelite ( Octopus) housing that I bought for my Cannon 20D in 2006. Now I have a Cannon 60D. The housing works for still photos, but not for video. Can it be modified to work with my new cam
Yes, this may be possible, send it to Ikelite, if there is room they are able to add another control/knob or push-pin to the existing housing. Also if you have knobs you don't use and find them in the way they have a special plug that replaces an in the way knob. Goo-luck!
Jan 03, 2014 | Ikelite Housing For Canon 60d 6870.60...
What is the battery placement in the Ikelite F35 flash unit?
You have to use 4 "AA" alkaline, NiCad, NiMH batteries for the Ikelite F35.You can read the detailed description below to know how to replace the batteries.
Hope you are satisfied with my solution.Your valuable feedback would be appreciated.Thanks for choosing Fixya.
TinuAlbinAlex
Jun 15, 2011 | Ikelite Cameras
I cant get the strobe to fire. i cant even fire it for test i have full power and the lamp runs but nit the strobe. any sugestions?
This can be many things like the cord is bad, maybe a bit of corrosion on one of the ends or your hot-shoe is not connected all the way on the camera? Send back to Ikelite, if it's bad they will fix or replace.
Ikelite
50 W 33rd St.
Indianapolis, IN 46208
317-923-4523
Feb 27, 2011 | Ikelite SubStrobe DS-125 TTL
I have purchased an Ikelite AF 35 strobe to use with my Sony DSC-TX1 camera and underwater housing. Even with the strobe set to the lowest setting, the photos I take with the camera set to 'housing on' are...
akdenny, have an af35 myself and know from experience the issue is very likely to be the way you have the block out for the cameras flash. if you block it by having the tape inside the housing it confuses the af35 to fire at a higher setting. from what i can gather it senses the strength of the camera flash and adjusts. I get the best results with the blockout on the camera supplied diffuser, stops the flash camera going forward and gives plenty of light to get the af35 to fire right. to blockout i just use some black tape , fabric tape seems to stick well.
you will still need to set the auto level setting.
hope it works out, i find it a great flash. and the guys at ikelite very very helpful.
Dec 28, 2010 | Ikelite 4035 Left Hand AF35 Auto flash kit...
Tried my new Ikelite AF35 strobe for the first time today and had the disposable everready batteries (new) in for about 45 minutes. After taking some practice shots with the Nikon L22 camera in the new...
Sounds like an O-Ring problem, you need to use a bit of silicon when closing and O-Ring should be removed and cleaned after every dive. If the flash isn't working, you will have to send it in for service. Here is the address;
Ikelite
50 W 33rd St.
317-923-4523
Oct 17, 2010 | Ikelite 4035 Left Hand AF35 Auto flash kit...
Toshiba satellite A35-S1592... Does it have bluetooth capability
I looked up the specs on the internet, and it doesn't have bluetooth capability. You would have to contact Toshiba or a repair shop to see if it can be added.
Mar 13, 2010 | Toshiba Satellite A35-S1592 Notebook
Will not release shutter on canon 40D
Cannon is notorious for their auto focus and automatic setting to be very discriminant. If you are to close to your subject while in these settings granted your strobe will fire and your flash may flip into position but the shutter just wont work. Cannon is trying to tell you you are too close. You need to back up. If you are trying to get that close up and don't have the proper lens that's all you are going to get.
It is best to go long lens then go for your close up.
Mar 09, 2010 | Canon EOS 40D Digital SLR Camera Digital...
Nikonos V underwater camera w/ strobe
It sounds like you'll need professional service. Even slight moisture damage can foul up the shutter or the wiring that runs from the camera to the inside of the connection port. You can remove the access plate (4 screws) above the film chamber. The 5 wires below the rewind knob (blue,yellow,purple,green,black) lead to that connector. I would also check the shutter functions on M90. See if it opens.
Sep 30, 2008 | Nikonos V 35mm Point and Shoot Camera
My cannon ixus 70 shows nothing on the screen in picture taking mode but when i take a piture then put it into view mode it can be seen?
Mine too! Screen works fine in video mode as well. Love my camera and dont want to replace it (have been using the traditional viewfinder), but repair too expensive.
All ideas welcome.
May 06, 2008 | Canon Cameras
Settings on my Nikon D-50
The Ikelite S100 is for a Canon Elph camera. I don't think you're going to get your D50 to work with it. If you have a 6805.1, which is designed for that model Nikon, your Owner's Manual is here:
http://www.ikelite.com/downloads/instructions/SLR_pdf/Nikon-pdf/Nik_D50.pdf
Did you buy the housing used? Did someone tell you it would work with your camera?
Dec 17, 2007 | Nikon D50 Digital Camera
Ikelite Substrobe A35 w/ Arm and Tray f/ Auto 35 Camera (5468) Light Logo
224 people viewed this question
Top Ikelite Cameras Experts
Are you an Ikelite Camera Expert? Answer questions, earn points and help others
