Question about GE JGBP88SEKSS Gas Kitchen Range
Sealed burners not working properly
I was making pancakes this morning and I think some oil from my portable griddle spilled over. Now neither of the two burners on the left side ignite automatically, although they click and I can ignite them using a match. The head on the front left burner has some brown gook burned into it which I have tried unsuccessfully to remover by scrubbing. I tried keeping the burners on for about an hour, hoping to burn away or dry the cause of the problem, but to no avail. Help!
What do you use an electric griddle for?
I use mine for okonomiyaki. This way you cook it at the table and it stays warm and then you eat it!
for more about how to make this:
http://www.closetcooking.com/2009/05/okonomiyaki-japanese-pancake.html
Jan 24, 2013 | Kitchen Appliances - Others
Propane Conversion Burner Turndown
It has to do with the diameter of th holes. The holes for natural gas are much bigger and this sounds like could definitely be your problem.
Thanks,
lee
Aug 04, 2008 | GE JGSP23 Gas Kitchen Range
Cuisinart Griddler won't cook pancakes
That is one of my favorite griddles. its possible you opened the lid too early while cooking that is why you couldn't achieve the browning you desired. You can check our post for more info on the Best Electric Griddle Pan.
Top 6 Best Electric Griddle Pan 2017 Buying Guide For Cooks...
Sep 20, 2017 | Cuisinart GRID8PC Griddler Adjustable...
How do I use my Griddle for the first time? We did not get a manual I would like one sent to us.
I can't help you with the manual because you did not provide the make and model number.
Typically, you wash the griddle with soap and water (DO NOT WASH ANY ELECTRICAL CONTROL UNIT!). Rinse and let dry if it has a non-stick coating. If it does not have a non-stick coating (bare metal), towel-dry the griddle, then put some vegetable oil on a paper towel and wipe the entire cooking surface so it is covered with a thin film of oil. Heat it to about 250 °F for about one on-off cycle on the electrical control. It is now "seasoned" and ready for use. If the griddle does not have an electric heater but is designed for use on a range-top burner, set the burner to just below medium heat and heat until water droplets splattered on the griddle boil off quickly.
May 30, 2011 | Microwave Ovens
I am looking for a replacment part for a 3 year old General Electric Gas Stove. The part I want is the grill that goes on top of the cooktop between the burner, whis is used for cooking items such as...
Your looking for the griddle.
I am not sure if this is the exact part your looking for due to the model number listed in your post does not have one as a parts replacement. If you have a good model number I can probably find a source for the part.
Here is one GE griddle:
http://www.appliancepartspros.com/Appliance-Parts/GE-Griddle-item-number-AP3205515.aspx
If this is not what you were l;ooking for please provide a model number so I can better help you.
Thanks for using FixYa!
Kelly
(it may not be the one for your range but it is one of 2 types they used)
May 18, 2010 | GE Adora JBP77SMSS Stainless Steel Kitchen...
Where can I locate the model number on my viking range? (48")
Mine was located to the left of the top burners. Remove the grates covering the burners, remove the 'spill' pans, lift up the surface that held the spill pans and then on the LHS you should see a plate with your units details.
Jan 20, 2010 | Viking 48" 6 Burner, Griddle Professional...
Can grill be safely converted to griddle on Thermador PRG486GLUS?
http://www.instawares.com/add-griddle-top-2.133-1002.0.7.htm
try this.
If it doesnt fit your specs. then i would suggest u find a thermador parts place and begin to buy the parts for the griddle as replacement parts. find a model of the stove set up that you want and make a list of all the parts that go to the griddle attachment.
My guess is that the reason for the flat "No" on the retrofit was that griddles require a thermostat similar to the one on the oven and broilers do not. So if their is no room behind the face plate where the knob would go then you can't put in a griddle. The other issue might be that the burners for the griddle wont line up with the brackets that are holding up all the broiler burners now. The griddle burner looks exactly like the one from the over only smaller so it has to line up strait where a regular front and back burner have to line up offset. maybe since you have the broiler already that should not be an issue? Then the problem is finding the griddle top it self that is going to be spendy. I think the link i gave at the top is your best bet. good luck.
Leslie
Mar 19, 2009 | Thermador PRG484GGUS Gas Kitchen Range
Griddle burner wont spark
Make certain the burner and burner base are very clean by carefully washing in warm soapy water, using a plastic brush to scrub any residue off the surfaces. Also clean the spark ignition nub in this same way.
Jan 23, 2009 | Rangemaster Proffessional 110 Gas Kitchen...
Thermador Gas Range - Griddle ignition will not spark
I have a Thermador Gas Range PG364GDBS - Oven, 4 burners, and center griddle. All are gas. The four burners and gas oven work fine. The griddle just stopped working, no spark. Turning on the griddle control, the gas valve opens(hear it), gas flows (smell it), but the ignitor will not spark (no loud or faint spark that I can hear). I got a replacement ignition device (mount at the burner) thinking it might be the problem, but still no spark. I checked the AC voltage at the terminal and measured 39 VAC between the terminal and ground. Not sure if that is the correct voltage. Any insights or advice would be great.
Dec 07, 2008 | Thermador SGS36GS Gas Cooktop
GE JGBP88SEKSS Gas Kitchen Range Logo
42 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
