Question about Craftsman 26 hp 54 in. Deck Deluxe Yard Tractor - CA Model
The two left-hand sheet metal screws holding the transaxle to the frame fell out. I've tapped the holes and used cap screws to tighten things up However, I think the trans linkage got bent -- Neutral is first, and reverse neutral. Can I adjust?
  • 138 Answers
SOURCE: grinding loud noise in the transaxle
sounds like the bypass lever might not be re-engaging, push it in firmly. OR, the brake is sticking. this, of course, is if the noise is a growl or a groan. if it IS a grinding noise, look for something stuck in the trans cooling fan or between the axles and wheels, otherwise it's inside the trans and that's not good [re: replacement]
Posted on Aug 18, 2009
  • 16 Answers
SOURCE: My front wheels are suddenly out of alignment. I
There are plastic bushings on the front wheels that get worn over time. Pull the front wheels off and inspect them to see if they are still intact.
Posted on May 07, 2010
Testimonial: "Thanks for the feedback, the parts are on order, one side appeared more worn than the other. I'll let you know how I make out. Again, appreciate the help."
  • 252 Answers
SOURCE: when i put mower in
yes
there is a adjustment under the r/h rear gaurd just under where the lever goes to hydro unit you should see a slot and a adjustment bolt arrangement
make sure you put the tractor in true nuetral 1st then undo the bolt that clamps lever to shift arm / shaft ( this connects to plate that operates swash plate on the pump ) and move the lever either fwd or back until (without moving transmission from true nuetral ) it fits into the nuetral slot correctly and tighten the adjustment bolt - test and adjust as nescesary
here is website for parts
http://www.outdoordistributors.com/Craftsman/Craftsman_Search.html
get model and type numbers off machine ie 917-??????
here is web site for parts
Posted on Aug 09, 2010
  • 1388 Answers
SOURCE: 1997,19.5hp,42" cut, std. trans (Sears Craftsman
I had a mower similar to yours years ago, liked it a lot, however traded for hydrostat model. When you press on the brake you are applying pressure to two dowel pins moved by lever #790079 which in turn apply pressue to brake pads (#799021) against rotor(#790003). You should be able to see the rotor to one side of the transaxle. Pads and the rotor will wear causing loss of brake. Make sure that loss of clutch is not adjustment, but v-belt from engine to transmission worn. Have a partner depress the brake as you carefully examine exactly what is happenning with levers under mower. A single adjustment will have an effect or other levers, pulleys etc. Dont worry however, you cant brake anything, just count the turns if you move adjustment so that you can reverse actions.
Posted on Sep 04, 2011
stevestroud2
  • 4 Answers
SOURCE: Husqvarna YTH 2448 Hydrostatic stuck in neutral
There is a brake assy. located on your transaxle right rear side. There is a nut with a cotter pin. First check to make sure there is no debris clogging the assy. Clean it first. you can use a garden hose. If that does not work remove cotter pin and turn nut clockwise until slotted nut lines up with hole. replace cotter pin. Start mower and see if it will engage. these transaxles are notorious for not having the pads snug enough to catch. Good luck. Hope you don't need a new transaxle.
Posted on May 02, 2012
Show me how to repair a cv joint Saturn vue 2006?
Transaxle Removal & Installation
Fig. Disconnect the shift control cable (3) from the range select lever (4)
  • Remove the upper transaxle to engine bolts (1, 3, 5, 6) and stud (2).
    Fig. Remove the upper transaxle to engine bolts (1, 3, 5, 6) and stud (2)
  • Safely support the engine.
  • Remove the transaxle mount to transaxle bolts.
    Fig. Remove the transaxle mount to transaxle bolts
  • Remove the transaxle mount to frame rail bolts.
  • Remove the mount from the engine.
    Fig. Remove the transaxle mount to frame rail bolts
  • Remove the left transaxle mount
  • Raise and safely support the vehicle.
  • Remove the front wheel and tire assemblies.
  • Remove the splash shield.
  • Remove the bolts (2, 3) from the transaxle brace.
  • Remove the transaxle brace (1).
    Fig. Remove the bolts (2, 3) from the transaxle brace
  • Remove the starter.
  • Mark the relationship of the flywheel to the torque converter for reassembly.
  • Use the J 43653, Flywheel Holding Tool, to prevent the crankshaft from rotating.
  • Remove the torque converter to flywheel bolts.
  • Remove the nut holding the transaxle cooler line retainer to the transaxle.
  • Disconnect the transaxle cooler lines from the transaxle.
  • Disconnect the Vehicle Speed Sensor (VSS) wiring harness from the sensor.
  • Remove the steering gear intermediate shaft pinch bolt.
  • Disconnect the tie rods from the steering knuckle.
  • Disconnect the stabilizer shaft links from the stabilizer shaft.
  • Disconnect the ball joints from the steering knuckles.
  • Remove the frame.
  • Disconnect the wheel drive shafts from the transaxle.
  • Support the transaxle with a suitable jack.
  • Remove the lower transaxle to engine bolts (5, 6, 7, 8).
    Fig. Remove the lower transaxle to engine bolts (5, 6, 7, 8)
  • Separate the engine and the transaxle.
  • Remove the transaxle from the vehicle.
  • Flush the transaxle cooler and the lines with J 35944-A, Transaxle Oil Cooler Flusher.
  • Remove the following only if replacing the transaxle.
    1. Remove the shift cable bracket bolt (3), nut (1), and bracket (2).
    2. Remove the PNP switch.
    3. Remove the transaxle mounts.
      Fig. Remove the shift cable bracket bolt (3), nut (1), and bracket (2).
  • To install:
    1. Install the following if previously removed
      1. Install the shift cable bracket (2), bolt (3), and nut (1).
      2. Tighten the bolt (3) and nut (1) to 16 ft. lbs. (22 Nm).
    2. Install the PNP switch.
    3. Install the transaxle mounts.
    4. Position the transaxle in the vehicle.
    5. Install the lower transaxle to engine bolts. Tighten the bolts to 55 ft. lbs. (75 Nm).
    6. Install the wheel drive shafts to the transaxle.
    7. Install the frame.
    8. Lubricate the transaxle cooler pipes before inserting into seals.
    9. Connect the transaxle cooler pipes to the transaxle.
    10. Install the transaxle cooler pipes retainer nut. Tighten the nut to 62 inch lbs. (7 Nm).
    11. Use the J 43653, Flywheel Holding Tool, to prevent the crankshaft from rotating.
    12. Install the torque converter to flywheel bolts. Tighten the torque converter bolts to 44 ft. lbs. (60 Nm).
    13. Install the starter.
    14. Install the frame.
    15. Install the steering gear intermediate shaft pinch bolt.
    16. Connect the ball joints to the steering knuckles.
    17. Connect the stabilizer shaft links to the stabilizer shaft.
    18. Connect the tie rods to the steering knuckle.
    19. Connect the wiring harness to the VSS.
    20. Install the transaxle brace.
    21. Install the transaxle brace bolts. Tighten the bolts to 39 ft. lbs. (53 Nm).
    22. Install the front splash shields.
    23. Install the front wheel and tire assemblies.
    24. Lower the vehicle.
    25. Install the left transaxle mount.
    26. Install the upper transaxle to engine bolts and stud. Tighten all of the bolts and stud to 55 ft. lbs. (75 Nm).
    27. Untie the radiator, air conditioning condenser, and fan module assembly.
    28. Remove the engine support fixture.
    29. Connect the transaxle wiring harness to the main transaxle electrical connector, and the PNP switch.
    30. Install the shift control cable to the shift control cable bracket. Ensure the cable retaining clip is fully seated.
    31. Connect the shift control cable to the range select lever.
    32. Connect the air duct hose to the intake plenum.
    33. Install the battery tray.
    34. Inspect the transaxle fluid level.
      NOTE
      It is recommended that Transmission Adaptive Pressure (TAP) information be reset. Resetting the TAP values using a scan tool will erase all learned values in all cells. As a result, the ECM, PCM or TCM will need to relearn TAP values. Transaxle performance may be affected as new TAP values are learned.
    35. Reset the TAP values
    Jul 22, 2014 | 2006 Saturn Vue
    I have a Brother XR-65. The needle bar fell out as I was sewing. I need a repair manual or some instruction on how to secure the needle bar in the machine. I have the bar itself and a pin sized piece of...
    This was happening to me also - you have to tighten a different screw than the one that holds the needle in.
    http://www.sewingpartsonline.com/needle-clamp-screw-brother-ls-2125-sewing-machine.aspx
    My husband thought the screw was missing - it is actually a plastic screw with a hole in it for a tiny allen wrench.
    You can see it in this picture also
    http://www.sewingpartsonline.com/needle-clamp-babylock-brother-xz0001051.aspx
    If you look at the photo of the screw I attached, you can zoom in and see it has a hexagonal hole.
    It is above the flat head needle clamp screw (the one that holds the needle in)
    It is REALLY annoying that this screw is mentioned nowhere in the manual, and the hex allen wrench is not included with the machine.
    Kind of an important little detail, considering it holds the needle assembly together... you'd think that they would have told you about it.
    Sep 09, 2011 | Brother Sewing Machines
    Just got 1996 chevy cavalier. Where do you add transmission fluid?
    the transmission fluid goes down the dip stick hole ,either use a small funnel or special tranny fluid refill top up bottle
    Feb 04, 2011 | 1996 Chevrolet Cavalier
    How do I change the door from left hand to right hand opening
    on the top right hand side of the refrigerator you should see little screw cover caps,, also on the door and on the bottom of the door. remove these caps -- now remove the screws that hold the hinges for the door and just switch everything over to the other side. everything is a mirror image of the other side --- where there is a screw that holds the hinge on one side -- there will be a screw hole on the other side that is covered by a finish cap,,, same thing with the hinge pin hole. tighten everything up and use the finish caps to plug up the now exposed holes and there you go -- right hand opening door.
    if you have any troubles -- just write me back here and I will do my best to walk you through it.
    c...
    Feb 03, 2011 | Kenmore 72912 / 72914 / 72919 Bottom...
    How to check trasmission fluid no dipstick just a red cap
    4T40E Automatic Transaxle CAUTION
    Removal of the fluid level screw when the transaxle fluid is hot may cause injury. Use care to avoid contact of the transaxle fluid to exhaust pipe. The fluid level screw is intended to be used for diagnosing a transaxle fluid leak or resetting the transaxle fluid level after service that involves a loss of fluid.
    1. The fluid level should be checked when the transaxle is near room temperature or at 104°F (40°C). To acquire this, left the car idle for 3-5 minutes with all of the accessories off. Fig. 5: Location of the fluid level screw and the fill/vent cap needed to check the fluid for the 4T40E automatic transaxle 87951085.gif
    2. Apply the brake, then move the gear shift selector through all gear ranges, pausing three seconds in each range. Shift the lever into P.
    3. Raise and safely support the vehicle.
    4. Place a suitable drain pan under the check plug to catch any fluid that may drip out.
    5. Remove the oil check plug. The oil level should be at the bottom of the oil check hole. Because the transaxle operates correctly over a range of fluid levels, fluid may or may not drain out of the screw hole when the screw is removed.
    6. If fluid drains through the screw hole, the transaxle may have been overfilled. When fluid stops draining, then fluid level is correct and the check plug may be installed. If fluid does not drain through the screw hole, the transaxle fluid may have been low. Add fluid at the vent cap location in 1 pint increments until the oil level is at the bottom of the oil check hole.
    7. Install the oil check plug/fluid level screw and tighten to 10 ft. lbs. (14 Nm).
    8. Carefully lower the vehicle.
    Jan 21, 2011 | 1997 Pontiac Sunfire
    Need easy way to take off transmission fluid cap.Trying to check fluid.
    Hello Eddie.
    Checking the fluid level on these cars isn't easy. Not one of the Generals best ideas. There isn't a dipstick under that cap. The fluid level is checked by removing a screw on the side of the transmission while the car is running and sitting level.
    This makes it tricky to do for the average do-it-yourselfer as you not only need to jack up the front of the car but the back end to keep it level. Probably a vain attempt to get the cars back into the dealers shop.
    Anyway, here is the book procedure.
    Inspect
    The fluid level should be checked when the transaxle is near Room temperature or at 40°C (104°F) .
    CAUTION: Removal of the fluid level screw when the transaxle fluid is hot may cause injury. Use care to avoid contact of transaxle fluid to exhaust pipe.
    The engine must be running when the transaxle fluid level screw is removed, or excessive fluid loss will occur. Since the actual fluid level is unknown, stand clear when removing the fluid level screw. Have a container ready to capture any lost fluid.
    WARNING: Do not turn the engine off with the fluid level screw removed as you can be injured by hot transaxle fluid being expelled out of the fluid check hole.
    1. Let vehicle idle for three to five minutes with accessories off.
    2. Apply brake
    3. Move shift lever through all gear ranges, pausing three seconds in each range.
    4. Place shift lever in Park. Important: Vehicle must be kept level on the hoist.
    5. Raise vehicle on hoist.
    6. Place oil container under fluid level screw.
    7. Remove the fluid level screw with the engine running at idle.
    8. Fluid level should be at the bottom of the fluid check hole. Because the transaxle operates correctly over a range of fluid levels, fluid may or may not drain out of the fluid check hole when the fluid level screw is removed. If fluid drains through the fluid check hole, this transaxle may have been overfilled. When fluid stops draining, the fluid level is correct and the fluid level screw may be installed. If fluid does not drain through the fluid check hole, the transaxle fluid level may be low. Proceed to ADDING TRANSAXLE FLUID.
    9. Install fluid level screw. Tighten 12 N.m (106 lb in)
    10. Lower vehicle.
    11. Shut off engine. Adding Transaxle Fluid: With the engine running, add fluid at the vent cap location in half liter (1 pint) increments until fluid drains through the fluid check hole. Allow the fluid to finish draining through the fluid check hole.
    1. Install fluid level screw. Tighten 12 N.m (106 lb in)
    2. Lower vehicle.
    I hope this helps you along.
    Thank you for using FixYa.
    KL
    Nov 19, 2010 | 2000 Pontiac Grand Am GT
    Check automatic transmission fluid level 2004 Pontiac grand am
    TRANSAXLE FLUID CHECKING PROCEDURE
    Inspect
    2. Apply brake
    1. Raise vehicle on hoist.
    2. Place oil container under fluid level screw.
    3. Remove the fluid level screw with the engine running at idle.
    4. Fluid level should be at the bottom of the fluid check hole. Because the transaxle operates correctly over a range of fluid levels, fluid may or may not drain out of the fluid check hole when the fluid level screw is removed. If fluid drains through the fluid check hole, this transaxle may have been overfilled. When fluid stops draining, the fluid level is correct and the fluid level screw may be installed. If fluid does not drain through the fluid check hole, the transaxle fluid level may be low. Proceed to ADDING TRANSAXLE FLUID.
    5. Install fluid level screw.
    Tighten 12 Nm (106 lb. in.)
    1. Lower vehicle.
    2. Shut off engine.
    1. Lower vehicle.
    Oct 20, 2010 | 2004 Pontiac Grand Am
    I switched my dryer door so that it opens from the opposite side. I got the hindges and screws into the door, but I am unable to screw in the screws all the way into the dryer. Any suggestions?
    The holes are undersized and the screws are probably self-tapping or sheet metal screws. Try installing a screw into the hole without the hinge in place. That way you may be able to thread the hole easier. Then back the screw out and install it through the hinge. When installing the screw after the hole is threaded turn it backwards slowly until you feel it fall into the thread path then tighten normally. That way you will not start cutting a new thread path or strip the hole too large to hold securely.
    Mar 27, 2010 | Dryers
    I have a 1995 chevy blazer and im trying to connect a car audio system but i'm having trouble finding good ground.I need assistant in finding
    Hello stevenavila1,
    Any bare metal on the vehicle is a "ground". If you are unable to locate an existing screw or bolt that goes directly into the frame or chassis, you can drill a small hole through the metal and use a self-tapping metal screw. Use sandpaper to remove any paint and primer down to bare metal before tightening the screw. It's also best to use a ring terminal or spade terminal on the wire.
    Hope this helps.
    Oct 22, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
    Oil pump replacement
    This MAY seem Strange But It IS ALL necessary for Oil Pump Replacement. And Please Don't Forget to Rate Me as Most Folks Do Not. Thank You and GOOD LUCK with the Oil Pump Job Also
    OIL PUMP
    It is necessary to remove the oil pan, oil pickup and chain case cover to service the oil pump rotors. The oil pump pressure relief valve can be serviced by removing the oil pan and oil pickup tube. Refer to Timing Chain Cover Removal and Installation for procedures.
    DISASSEMBLY
    1. To remove the relief valve, proceed as follows:
    2. Drill a 3.175 mm (1/8 inch) hole into the relief valve retainer cap and insert a self-threading sheet metal screw into cap.
    1. Clamp screw into a vise and while supporting chain case cover, remove cap by tapping chain case cover using a soft hammer. Discard retainer cap and remove spring and relief valve.
    2. Remove oil pump cover screws, and lift off cover.
    3. Remove pump rotors.
    1. Wash all parts in a suitable solvent and inspect carefully for damage or wear.
    Oil Pump Assembly
    1. Assemble pump, using new parts as required. Install the inner rotor with chamfer facing the cast iron oil pump cover.
    2. Tighten cover screws to 12 Nm (105 inch lbs.).
    3. Prime oil pump before installation by filling rotor cavity with engine oil.
    4. Install chain case cover. Refer to Timing Chain Cover Installation.
    REMOVAL of Timing cover
    REMOVAL
    1. Disconnect negative cable from battery.
    2. Remove timing chain cover.
    REMOVAL Of Oil Pan to gain Access to OIL PUMP
    1. Disconnect negative cable from battery and remove engine oil dipstick.
    2. Raise vehicle on hoist and drain engine oil.
    3. Remove bending brace to transaxle attaching bolt.
    4. Remove bolts attaching dust cover to transaxle housing. Lower dust cover to gain access to oil pan bolts.
    5. Remove oil pan screws and remove oil pan.
    INSTALLATION
    1. Clean surfaces and apply a 1/8 inch bead of Mopar (R) Silicone Rubber Adhesive Sealant or equivalent, at the parting line of the chain case cover and the rear seal retainer.
      1. Use a new pan gasket.
      2. Install pan and tighten screws to 12 Nm (105 inch lbs.).
      3. Install dust shield and bending brace to transaxle housing.
      4. Lower vehicle and install oil dipstick.
      5. Connect negative cable to battery.
      6. Fill crankcase with oil to proper level.
    Mar 27, 2009 | 1998 Chrysler Town & Country
    Craftsman 26 hp 54 in. Deck Deluxe Yard Tractor - CA Model Logo
    48 people viewed this question
    Top Craftsman Garden Experts
    Wade Mobley
    Wade Mobley
    Jim Parker
    Jim Parker
    Dennis Key
    Dennis Key
    Are you a Craftsman Garden Expert? Answer questions, earn points and help others
