Question about LG enV VX9900 Cellular Phone
Computer connect to jabra BT8040, but speaker/mike not ok
My computer discovers my jabra BT8040, but does not work as mic and speaker. What do i do wrong
Why cant i talk or hear any body on my mic?
Since it is Bluetooth, you have to pair the Bluetooth to your host computer or device. Find the correct window or screen and put it into discover mode, do the same with the headset. RTFM
Aug 11, 2014 | Jabra BT2070 Bluetooth Headset
What if i can't find my model phone for instruction to connect to?
Hi
Paring the JABRA head set to Mobile phone
1. Turn headset off. Press and hold until solid light comes on.
2. Activate Bluetooth on your phone.
3. Search for Bluetooth devices and select Jabra BT2070.
4. Press ‘OK’ on the phone ,If the phone asks for a PIN then confirm with PIN code 0000 (4 zeros)
Thank You
Aug 31, 2010 | British Telecom Jabra BT8040 Wireless...
Mike not working
Hi Shirley, you do not give your computer details or OS but here is a typical audio set-up
Laptop x webcam/mic x Vista x Yahoo Messenger
If you have an earlier OS, you may have to access some of your hardware from the Control Panel.
TEST SPEAKERS
Right click on speaker icon in System Tray
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
To set required mic as default - click on mic font to highlight and click "Properties"
In lower drop-box display "Use this device enable" click OK
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
CONFIGURE TO MESSENGER
Open messenger - on top toolbar. Left click ( > ) Messenger > Preferences > Connection - Select 'no proxies' or 'connect direct to the internet' depending on the version of messenger you have
make sure your internet connection and country are correct in the lower two boxes > Apply > OK
Click ( > ) Messenger > Preferences > Calling and Audio
Set mic and speakers to show Default equipment
Run call up assistant to test audio equipment > Apply > OK
Dec 06, 2009 | MSI Starcam 370i Webcam
Cannot get the mike to work
Set up Audio
If you have an earlier OS, you may have to access your hardware from the Control Panel.
TEST SPEAKERS
In lower dropbox display "Use this device enable" click OK
Restart computer
Nov 13, 2009 | Computers & Internet
Can not find instructions to connect jabra bt8040 to my cell phone,,,,now that hands free is law as of today!
Go to this site, and it will walk you through each step to connect your particular Jabra headset with your cellphone. Choose the headset, and then at the next page, choose your phone. Moving your mouse over each step will change the picture to what you should be seeing on your phone at each step.
http://jabra.pairx.co.uk/ Pls come back and let us know if this solved your problem.
Oct 26, 2009 | Jabra BT8040 Bluetooth Headset
Can't get new Jabra BT8040 to connect to LG Env3
I have the env Touch and the Jabra Halo. Initially, I had a problem pairing the two, then I realized that I was not following the directions properly. The manual shows two sections for pairing ("first time pairing" and "later pairing"). I was following the instructions for the former when I should have been following the latter. I also failed to notice that the BT indicator was flashing blue and not solid blue, as it needs to be, for pairing mode. So, if you haven't already done so, follow the instructions for "later pairing" here. Make sure that you see the SOLID blue light on the BT indicator on the headset when you try to pair.
Jul 17, 2009 | LG enV VX9900 Cellular Phone
Jabra bt8040 is not pairing with iPhone 3gs
No problem. When Jabra is off, press and hold till green light turns blue. On the iPhone: settings, general, bluetooth; switch to on. It will search, then it will list the Jabra BT8040, not paired. Highlight the "not paired" line, and it will start to pair; a few seconds later, it will say "connected".
Jul 09, 2009 | Apple Cell Phones
Soft ear pad for jabra bt8040
http://www.msgdigital.com/productdetail.asp?productid=46551
Feb 18, 2009 | Jabra Bluetooth Headset with Adjustable...
Jabra bluetooth adapter A210
hi,
you have to connect the jabra audio jack to the audio source, to the speaker output of your receiver for example. If jabra detects the source it will work. If you cut the connection, jabra watch for a while if something happend and than stops the transmittion. Hope that helps
Oct 26, 2008 | LG Jabra A210 Bluetooth Adapter for...
LG enV VX9900 Cellular Phone Logo
110 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
