Question about Cub Cadet Street Sign- tractor lawn riding mower parts
Cub cadet 2166 won't start. replaced switch. starter doesn't turn over. can jump starter but it doesn't engage.
  • 62 Answers
SOUND LIKE A LOW VOLTAGE PROBLEM. MAKE SURE YOUR BATTERY IS GOOD
Posted on Sep 25, 2009
Where is the fuse on a 1046 Cub cadet?
behind the dash right side try to jump starter if catch then try then go to starter silinoid jump it will try to start if doesnst replace it if dose work go to switch relay beehind dash near fuse let me no what happen
Sep 01, 2014 | Cub Cadet Garden
Cub cadet 2166 dies when I engage PTO or let brake peddal all the way up
replace that safety switch there is two switches built into one
Jun 11, 2012 | Cub Cadet Garden
I have a Cub Cadet 2166 . When I try to start it, the starter drive throws up, but won't turn the engine. I took the starter off and when you turn the key to start, the drive throws up and turns slow...
Can you measure the voltage of the battery? If you are getting low voltage then the battery needs to be charged or replaced, if the voltage is good then you probably have a bad starter. It might be something you can see like shorted windings on the motor.
Jun 07, 2011 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet 2166 series. Mower will not engage.
Unfortunately, the circuit is a little complicated - it involves the "PTO switch" (the switch you pull on to engage the mower), a "reverse switch" that senses if you've put the mower in reverse, and a relay operated by the reverse switch. The reverse switch is there to disengage the blades if you try to reverse while mowing. A failure in any of those items, or the connectors and wiring between them, will prevent the blades from engaging. Unless you want to "shotgun it" and replace parts one-by-one on a guess (which many repairmen to do save time, but at your expense) you need to use an ohmmeter or test light to trace and isolate where the failure is.
Jul 10, 2010 | Cub Cadet Garden
Starting problems with my cub cadet 2166 lawn mower? Battery is good, not turning over, sometimes it clicks? I can jump start but it is a pain. I have taken this to a dealer last year for this problem....
If it works when jump started, then I would suspect a bad battery or lose or corroded connection. check wires from battery to starter relay also known as solenoid to starter,if it is making a click,the ignition is most likely ok . safety start switch is ok ,I still suspect Battery..can you have it load tested or try a known good one?PS if above test OK, then starter or starter solenoid /relay.Hope this helped you fix it. please let us know if this helped.thank you.
Mar 22, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Engine stalls when electric PTO clutch is engaged
check your spacers to be sure you havent locked the clutch assembly directly to the motor shaft
you should be able to turn it fairly free less some clutch drag
Apr 11, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
882 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
