Question about NetGear WG111 802.11g/b Wireless Adapter
My wireless network was found but cant connect
  • 1,272 Answers
IF the computer has windows Vista then perform the steps below:
1. Click START, Click Control Panel then click classic view in left hand side menu.
2. In the main screen, open up NETWORK AND SHARING CENTER.
3. In the left hand side menu open up MANAGE WIRELESS NETWORKS.
4. If you see any name in the list, please select the name and click remove.
5. Once the list is empty, click on ADD, select the first option, ADD A NETWORK THAT IS IN RANGE OF THE COMPUTER.
6. Click on your network name SSID and click on connect. If you have a password setup on the router enter the security key.
7. This should setup the wireless network.
For windows XP perform the steps below:
1. Right click on My Computer icon and go to Manage.
2. Go to Services then go to Service and Applications.
3. Double click on Wireless Zero Configuration.
4. Change the Start Up Type to Automatic and click on Apply
5. Click on Start and press OK to close the window.
6. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
7. Right-click on the wireless Network Connection icon and select 'Properties'.
8. Go to the 'Wireless Networks' tab .
9. Check the option 'Use Windows to Configure this Wireless Connection' and click 'OK'.
Now please perform the following instructions to connect to the wireless network:
1. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
2. Right-click on the wireless Network Connection icon and select 'Properties'.
3. Click on the 'wireless network' tab.
4. Under Preferred networks if you see any name in the list then highlight the name and click remove. Click OK.
5. Right-click on the wireless Network Connection icon and select 'View Available Networks'.
6. Look for the SSID (aka Network Name) of the Wireless router or access point.
4. Highlight thee SSID from the list that you want to connect to.
5. Type the security Key here and click on the 'Connect' button.
6. You should have successfully established a wireless network connection.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Posted on Sep 24, 2009
How do i install x box 360 to wireless internet
if it sees wifi networks then try removing your saved network profile and readding it. If no networks are found try wired connection or replacing wifi adapter.
Oct 24, 2016 | Microsoft Xbox 360 Console
Cant connect to the internet..
Hi, What error do you get when connecting to the internet?
Anyways, Probably the Wireless connection your trying to connect to has a Network Security enabled on it.
Gaming consoles cant' access that type of Encryption, reason I do not know why but to be able to get wireless connection using your Nintendo DS you will need to disable the Wireless Network Security of your Wireless Router to be able to get Wireless Access using your Nintendo DS.
I also had issues with mine before and found out that disabling the Network Security will let me get Internet Access on my portable console.
Just Disable the Network Security this will allow you to get Internet Access on your Nintendo, for the Security of your Wireless you can get the MAC Address of each wireless device you have and input those MAC Addresses into the Router Settings to get Security and not allow other poeplt to gain access on your Wireless Internet.
I hope this Helps.
Have a nice day,
mvincentc
Jul 27, 2011 | Nintendo DS Lite Console
I have belkin connect n150 and i have two laptops my one laptop is connect to wireless but the one laptop cant access to wireless it says no wireless network were found in range..
If your message is like this " no wireless network found in range make sure wireless on the computer is On". All you need to do is look for the wireless switch usually located on the side or the back of your laptop. Sometimes its near the F keys or start button. You may check your laptop manual to see where to locate the wireless switch , or you can check the laptop manufacturers website usually they gave information on where to locate or enable the wireless feature of laptop.
KA
Mar 30, 2011 | Belkin Basic Wireless Router
Cant connect to a wireless network
You need to turn on your wifi which maybe on the outside or on your keyboard, then go to bottom right of screen & left click on wireless connection then click on "connect to a network"
Apr 24, 2010 | Toshiba Satellite A100-S8111TD Notebook
Multiple network adapters found
Go to Start->Control Panel->Network and Internet->Network and Sharing center->Manage network connections
You will find icons like local area connection, wireless connection and lot more. Just have one local area connection enabled and disable all other icons. Then run the setup
Nov 01, 2009 | Belkin (F5D5231-4) Router
I cant connect wirelessly but if i put the cable in i can connect
not true. can you see your wireless router?
also can you connect from a network cable. we will have to reconfigure the router as to allow you to connect
Jun 14, 2009 | D-Link AirPlus DI-524 Wireless Router
I have my wireless adapter connected and it shows my required network in the list, but I am not able to connect to it
I had trouble with linksys router and modem, it saw connection but would not connect. I found that my network adapter (drivers) were not installed. Make sure you check that the drivers are installed. If it looks like it, then uninstall then re-install again.
Hope it helps.
Jan 11, 2009 | Belkin (F5D7050) 802.11a/g/b Wireless...
I need to turn my wirless internetnet option on and cant for my IBM thinkpad thanks
mostly the button is found on the left float side of your laptop 'IBM'. with two icons of a computer. please make sure that the button is on the side of the icon that shows a computer with weaves. so that your able to check the wireless access points you have in your range.
Wireless Connection:
Start > Control Panel > network connection>
Show network connections. If there is an X on wireless connection then connection is disabling and if no X then connection is enable.
make sure its enabled.
Right click on wireless network connection and click view available wireless networks.
You should see a list of available wireless networks
Then select the wireless network that you need to work on and click connect.
An icon in the lower right hand corner of your laptop should eventually appear stating that you are connected.
Then this will show you your wireless connection.
Excellent you connect to your wireless network.
Dec 15, 2008 | IBM ThinkPad T40 2373 Notebook
I cant enable my Linksys WUSB54Gv4_20051110
I'm not sure what you mean by "this thing will not enable linksys". Do you mean when your USB adapter is plugged in, it will not "see" your wireless network?
If this is the case then you will need to use the software that came with the adapter to connect to your wireless network.
Jul 10, 2008 | Computers & Internet
HI Asus Eee
you may have another wireless connection other than your own set as automatic, or more than one connection in your settings of the same name, so right click on your network icon in your task bar or in network connections in device manager and select view all wireless connections, click on it and when all the connections show, highlght, delete all of them, then close the window.
Your notebook should now indicate that it found new wireless connections, click on the popup and select your connection name and click connect, at this point you will be asked to enter the passkey if you have security enabled.
Jan 12, 2008 | Computers & Internet
NetGear WG111 802.11g/b Wireless Adapter Logo
880 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
