Question about Tascam 2488 Portastudio Multitrack Recorder System
Linked tracks / unable to unlink them
I just bought a Tascam 2488 and when track 1 is linked to track 2, same thing with track 3 linked with 4 and 5!
Just can's figure out how to unlink them but the point is that track 2, 4, 5 are unusable by themselves. Example I have to move the fader of Track 1 to hear what's on track 2... When I go to "Null", it clearly shows that only tracks 1 and 3 are independent. help!
    President:
  • 1,126 Answers
Page 25 (in the Owners Manual) discusses linking and unlinking.
http://www.tascam.com/details;8,16,5,19.html
Posted on Sep 24, 2009
TRANSFERING OLD TRACKS TO THE NEW TASCAM 2488-NEO
You'll need your PC as the intermediary. You'll have to do a USB export of the tracks you want from the DP01 to your PC and then connect the 2488's USB to the PC and do a USB import of those tracks into new tracks on the 2488.
Page 40 of the DP01FX manual will explain using the USB connection and page 43 details the steps for performing a USB export.
In the 2488 NEO manual refer to pages 80 and 81 for using the USB connection and importing the tracks.
Hope this helps. Best of luck.
bd.
Oct 14, 2009 | Tascam 2488 Portastudio Multitrack...
Having problems recording and playing back tascam dc-02 cf
I'm assuming you are plugging the left and right outputs from the karaoke machine into input A and B of the Tascam to record the stereo output of the Karioke. The Tascam works with mono only (you recreate the stereo mix at mixdown or when bouncing mono tracks together with the panning set). Therefore you should be assigning inputs A and B separately. You could press assign A and then the record button above track 1 and then press assign B and the record button above track 2. Then arm tracks 1 and 2 (by pressing record above each). When you then press play and record together you'll record input A onto track 1 and input B onto track 2.
Hope this helps.
bd.
Mar 25, 2009 | Tascam 2488 Portastudio Multitrack...
Tascam 2488
You'd plug the XLR connection into any of the first four inputs on the 2488 (labelled a to d). This is a dynamic mic so you don't need phantom power and should make sure your phantom power switch is off (out) on the 2488. You'd then assign the input you've chosen to a track, arm the track for recording, turn up the input level for that input to test the signal level, and record away by pressing record and play together.
Hope this helps.
bd.
Nov 02, 2008 | Tascam 2488 Portastudio Multitrack...
Vocal effects on Tascam 2488 MK 2 portable studio
Hi again,
The easiest way to record using an external Lexicon effects unit (without an external mixer) is to connect your mic onto one of the 2488's inputs and assign that input to a channel strip (track). You should have the 2488 sends (output) going to the Lexicon's inputs. Then connect the Lexicon outputs back into another set of inputs on your 2488 and assign those inputs to two empty channel strips (tracks).
Then you will have to take that channel that has your mic input assigned to it and press send and set the levels there to send the signal out the sends (to the Lexicon).
Now you have a channel strip assigned to the mic input which contains your dry signal, and you have the two inputs returning from the Lexicon which contains your wet or effected signal.
You then have some options. You can control the amount of effected signal you hear while recording by adjusting the faders of the two wet tracks and you can either record the dry signal or the wet signal (or both) onto separate tracks.
Typically when recording the singer will want to hear an effect (say reverb) on his voice, but the engineer wants to record only the dry track at recording time (because effects can always be added later, but they can't be taken out). To accomplish this you would use the setup above, but only arm the mic input track for recording. In this way the singer hears the reverb, but only the dry vocals get recorded and the engineer can add reverb to that track again later as desired (and mix it back with the dry vocal etc).
On the other hand if you want to record only the effected signal you would simply arm the two channels to which the inputs coming back from your Lexicon are assigned for recording. This will get you a recording of the effected signal only.
Hope this helps you do what you are trying to do.
Cheers.
bd.
Aug 30, 2008 | Tascam 2488 Portastudio Multitrack...
How do I connect effects rack (Lexicon) to Tascam 2488 MK 2?
I've got a Lexicon too and I love the thing.
To use the Lexicon as a 'send effect' (which is what it is) you'll need to connect the effect sends from the back of the 2488 to the inputs on your Lexicon. Then connect the outputs from the Lexicon into two inputs on the 2488. Then assign those inputs to tracks.
You've got to select the previously recorded track(s) where you want to add reverb or other effects (by pressing the select key) and then press the 'send' key to get into the 'send effect' screen. Here you can adjust the amount of signal is sent from that channel to either of the effect sends (typically you might want to send one track of a stereo set of tracks out eff 1 and send the other track out eff 2).
Pre, post or off will determine whether the fader affects the signal being sent or not and the loop setting on the top of this screen is for the internal effects.
Once you've got this set up the way you want you just arm the tracks where the Lexicon output is coming into the 2488 for recording, mute whatever you don't want to hear and you can bounce record the raw signal through the Lexicon and record (print) the effected signal on the tracks you've armed.
Hope this helps.
bd.
Tracks 13/14 etc...
As far as I'm aware there is no way to record to just one of the stereo paired tracks (channels) on the 2488. There are individual mono tracks underneath those channels, but they are controlled with one fader and can only be recorded to in stereo. They are designed to be used for recording stereo sources and stereo bounces. You can however record to any of tracks 1 to 12 and then move (assign) that track to say track (channel) 13 or you can clone any single track to any other track (channel).
The term track can be misleading on the 2488. It might be easier to refer to the 1-24 fader controlled 'tracks' on the 2488 as 'channel strips' and refer to each of the 250 virtual 'tracks' on the 2488 as 'tracks'. You can assign any of the 250 virtual tracks on the 2488 to any of the channel strips. So you have 250 tracks available, but can only work with 24 of them at a time. The stereo pairs just offer some extra convenience when working in stereo. They allow you to control the volume of two tracks with one fader making working with stereo easier.
Channels 1 and 2, 3 and 4, 4 and 6, ...11 and 12 can also be linked as stereo pairs and will be controlled with the fader of the odd numbered (first) track when linked.
Cheers,
bd
Jul 03, 2008 | Tascam 2488 Portastudio Multitrack...
Sonic maximizer
To use the maximizer as a send effect, connect the effect send (1 or 2) to the input on your maximizer, then connect the output from your maximizer back into any input A thru G on your 2488. You then assign the track you want to maximize to the correct send (1 or 2) using the send key and then assign the input to a track to record to.
To use a maximizer as an input effect (assuming guitar) simply plug yoiur guitar into the maximizer and then patch the maximizer to input H (Hi Z input of the front panel of the 2488). Assign input H to a track to record and this will record the maximized input signal.
Jan 03, 2008 | Tascam 2488 Portastudio Multitrack...
2488 to pro tools
There is no way to 'sync' with protools from the 2488. In order to use your 2488 tracks in protools you have to first export your tracks as wav files and move them to your computer via usb and then import them into protools.
To get Protools files into your Tascam 2488 you'll have to export your Protools files into mono wav files first. They must also have a sampling rate of 44.1KHz and can be either 16 or 24 bit. Then load these files into your 2488 via usb and import them into tracks on the 2488.
Nov 21, 2007 | Tascam 2488 Portastudio Multitrack...
I can't figure out how to record on 8 tracks at the same time.
Link to Tascam 2488 documents page:
http://tascam.com/Products/2488_downloads.html
Individual Items as Listed:
Link to the Tascam 2488 product brochure:
http://tascam.com/Products/2488/2488_bro.pdf
Link to the Tascam 2488 application guide:
http://tascam.com/Products/2488/2488_AppGuide.pdf
Here's the link to the Tascam 2488 quick start guide:
http://tascam.com/Products/2488/2488_quickstart.pdf
Link to the updated Tascam 2488 manual:
http://www.tascamcontractor.com/ftp_resour...w_additions.pdf
Link to the Tascam 2488 manual additions:
http://www.tascamcontractor.com/ftp_resour...e_additions.pdf
Link to the Tascam 2488 MIDI Parameter Mapping
http://www.tascamcontractor.com/ftp_resour...ontrol_v0.2.pdf
Link to TASCAM 2488 Hi-Res images:
http://www.tascamcontractor.com/ftp_resour...488_images.html
Nov 07, 2007 | Tascam 2488 Portastudio Multitrack...
Tascam 2488
Oct 23, 2007 | Tascam 2488 Portastudio Multitrack...
Tascam 2488 Portastudio Multitrack Recorder System Logo
52 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
John
John
 Grubhead
Grubhead
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
