Question about Saeco Spidem Villa
Repair spidem villa
Drip very slow/ have downloaded instructions on cleaning grinder and it is better, btu still not working properly.
nearest service center for zip 23113 USA
A little spring felt off from the inside part when I was cleaning
Posted on Dec 03, 2011
Empty drip tray message
On the bottom of the machine attached to the drip tray is a sensor that "sees" liquid. If there is no liquid thgere, clean the sensor, if there is, empty the tray!
Jan 01, 2013 | Gaggia 1003380 Accademia Espresso Machine
I have a Saeco Spidem Villa. Iâ??ve been
I dont understand what exactly happen when you try to make coffee? Is the coffee comes out or no?
Apr 20, 2017 | Saeco Spidem Villa
My Spidem Villa has stopped grinding beans when I press the button for an espresso. The automatic tamper tamps an empty chamber and then hot water comes out, but no coffee is ground or put into the...
Hi
Sorry but that doesn't make sence. The grind chamber has to be full inorder for the doser to activate, unless you have an oiley bean and it has hardened inside the doser.
Try removing the brew group. Then inside on the roof of the machine above where the brew unit sat, there is a drop chute where the coffee is dropped into the brew unit. From the left side of the drop chute pull down and back, and it should drop coffee. This should clear the opening that relieves pressure on the passage. There is a passage inside the drop chute area that goes to the grinder. Vacuum it out. It will be on the right side of the drop chute.
Once that is cleared go to the bean hopper. There is a lever under the bean hopper. Push the lever back to the largest number. You can push the lever to a larger number any time, but it has to be grinding to pull to a smaller number. Now replace everything and make your coffee. Once you have made your coffee you can pull back to a number that was higher than the one you had it on, but only when the grinder is running.
May 20, 2010 | Saeco Spidem Villa
My Saeco Spidem Villa leaks after it despenses the coffee. Have attempted to clean descale to no avail. Any suggestions?
Take out the grounds box and the brew group. At the back there is an opening. If grounds get in the opening, it can't drain. Get some hot water in a squirt bottle and flush out that opening at the back ... this may end your problem with leaking after dispensing
Apr 05, 2010 | Saeco Spidem Villa
Broken"ON" button on Spidem Villa by Saeco
see repair shop. It is a ***** to replace,
Sep 19, 2009 | Saeco Spidem Villa
How should the hopper gears be aligned?
Here is a diagram, that will be of help.
Jul 16, 2009 | Saeco Spidem Villa
How do you take apart the grinder on Saeco Spidem Villa Household Coffee Machine
There should be screws on the side or the bottom of the unit that will allow you to pull it apart. The problem seems to be that the two grinding wheels have gone bad and needs to be replaced. On this unit you cannot adjust the grinding as far as would need to be to fix the problem when the teeth get to small
Jun 03, 2009 | Saeco Spidem Villa
How do you take apart the grinderon Saeco Spidem Villa Household Coffee Machine
Remove all the beans in the hopper, there are 2-3 screws in the hopper. Remove and then lift hopper, this will give access to the grinder chamber and burrs.
May 29, 2009 | Saeco Spidem Villa
How to descale Saeco Spidem Villa
Hi
Don't use vinegar. Its only 5% acid at full strength and if you mix it with water a lot less. It also leaves an after taste for about 2 weeks. Use descaling powder or other products especially made for espresso machines.
Remember, it is better to descale more often than not enough.
1. To decalcify your boiler, remove your water tank and fill it with hot water (100 to 120 degrees). Open a pack of decalcifier and mix into the water tank. Once it is dissolved, place the tank back on the machine, and then turn the machine on.
2. If you just open the steam knob and run approximately eight ounces of solution into a spare container. Turn the machine off and let set about 10 to 15 minutes. Longer is better. It is very important that the machine does not remain on to heat the boiler anymore than necessary.
3. Repeat step #2 for your machine. Do this until you have consumed the entire water tank of solution (approximately four to five cycles). (I do it at night before I go to bed and let the last cycle set in the boiler till morning.)
4. Remove water tank and rinse it with fresh water.
5. Refill water tank with fresh water and place it back on the machine.
Repeat step #2 to rinse the machine, only this time use the entire water tank at one time, and there is no need to let it set.
Mar 17, 2009 | Saeco Spidem Villa
Power button loose - comes out (cracked)
Contact your reseller or your nearest Saeco Service Center as your machine will have a 2 year warranty.
Paul from Coffee Shrine
Saeco Coffee Machines
Aug 19, 2008 | Saeco Spidem Villa
Saeco Spidem Villa Logo
426 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
