Question about Cadence Exercise & Fitness
Got a weslo cadence m5. on it for 15 minutes stopped completely. got electric working again by pressing trip switch on bottom. when i press go it try's to jolt a little but thats it. had a look underneath and found old pictures and a twenty pence coin fell out. not sure if was actually stuck in there or just in the casing. motor not burnt out don't think. wondering how to test the motor. belt seems fine unless come off cog. didn;t want to do too much as didn't want to break it perminently!
You know I have exactly the same problem..with mine jolt and nothing more. trieed it for 15 minutes then just stopped! have you found a solution yet!
Posted on Dec 04, 2009
Can anybody Help me? My Weslo Cadence goes working slowly and fast. Not Constant. What is defect or wrong?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. Check for treadmill articles
http://electro-medical.blogspot.com/
Feb 22, 2016 | Weslo Exercise & Fitness
Hello i have a weslo cadence 260 treadmill,it runs for about 1 minute then stops,the motor stops too,i have to keep tuning it off and on for it to work again,whats the problem with it,would be great if you...
It sounds like you have a worn deck and (or) belt. If the machine runs just fine without being on it but stops when someone is on it, then it sounds like a worn belt/deck.
The friction under the belt is so great that it overworks the motor to the point where it shuts itself down. The surface needs to be slick and smooth for the motor to work the least amount.
You could try to put some silicone under the walking belt and see if it helps. It really depends on how many miles are on it.
Feb 24, 2011 | Cadence Weslo 620/630 Treadmill Walking...
I have a Weslo Cadence M5 treadmill. When i used it, it tended to trip out the electrics when the treadmill was started, but worked when I put the trip switch back up again and tried again. However, it has...
hi, firstly change the fuse in the plug to a higher voltage, then if you are using an extention wire make sure all the wire is unrolled. i had the same problem with my m5. i was using an extention wire on a roll that was shorting out the trip on the treadmill and cutting the electric off. so just by putting a higher amp in the plug and i am now using a 2m extention alot safer and much better,
Nov 18, 2010 | Cadence Weslo 5.0A Treadmill Walking Belt
Don't have a manual......how do you turn on?
hi in the front bottom of the treadmill there should be a power on switch, turn this on and next to that there should be a power breaker switch turn that on also. now you should be ready to go! if still nothing telephone 08451770512 this is the number og the main suppliers of weslo cadence treadmills, local call and i am sure these people will help.
Nov 11, 2010 | Weslo Cadence 60 SE Treadmill
Treadmill will not operate when plugged up.
check the outlet first by plunging in a light to make sure their is power and that the house breaker was not tripped. then plug in the power cord next locate the reset/off circuit breaker on the treadmill frame near the power cord. Switch the circuit breaker to the reset position. Then place safety key on console and the display should light up if not then you may have a lower board problem.
May 17, 2010 | Weslo Cadence Ct 5.8 Treadmill
Weslo Cadence 450 Treadmill Manual
When turned on it acts like the walking surface is grabbing.Itgoes and stops its not as bad when speed is increased,but it still feels like it is grabbing.
Mar 22, 2009 | Cadence Exercise & Fitness
Exercise & Fitness Logo
343 people viewed this question
Top Cadence Exercise & Fitness Experts
Jim London
Jim London
Ross Metcalfe
Ross Metcalfe
Electro Med Services...
Are you a Cadence Exercise and Fitnes Expert? Answer questions, earn points and help others
