Question about Electrical Supplies
Motor reving too high the gen is producing about 270 volts i believe the solonoid to the auto idle is not working .i also have to exite the gen field coil to get it to produce power is this all because of one problem/
  • 36 Answers
Start engine and check starter moter gear is runing with fri wheel or not? I think this is a frquency froblem genset RPM is too high, if not Than set volts with 1000watts load on AVR
Posted on Sep 23, 2009
Honda EM5000SX generator - will not idle up when a load is placed on. Will produce power but will not idle up.
from your description and what you do , the problem is in the auto control unit
it will be in the system to reduce the rpm to idle when there is no load ( auto mains on off controller switching between genset and mains supply)
by turning the auto operation off you are committing the gen set to full rpms regardless of the power requirement
you have the option of having it fixed at an gen set repair shop or leaving it off and starting the genset only when you have a mains power outage
check with an electrician to ensure that it is possible to run it that way as if the mains power unit is not correct , when you start it and you still have mains power , it will destroy the gen set
Dec 13, 2016 | Honda Electrical Supplies
I have a husqvarna generator 1365GN. The engine runs but it does not produce electricity. also the auto idile stopped working. I've replaced the brushes and rectifier. but still no electricity.
I can't advise on the electrics but on my gen the auto idle works off the gen load. Load=revs up. No load=cut to idle. Fix one will probably fix the other. Husqvarna is part of Electrolux if thats any help identify the generator unit.
Feb 17, 2016 | Electrical Supplies
Miller roughneck 2e has low voltage 0ut of 120 volt receptacle only 5 volts at idle and 45 volts under power
have the alternator checked by an electrician
a t idle will be low as the exciter circuit will be producing low volts but it should go up when at operating rpms
45 volts at rpms indicates that the field windings of the alternator are not getting full current to produce the desired out put
Nov 20, 2015 | Miller Electrical Supplies
Can voltage on Powermate be adjusted?
yes
the adjustment is by the rpm setting on the governor spring
thee is a nut that you adjust the spring tension with and lower the rpms and watch the voltage gauge until you get the desired voltage
if the load is going to be constant but is well within the rated capacity( example 2kva of a 6.5 kva set) of the gen set then the variation when the load comes on will be less than 5 volts
however if the power required is close to the max capacity of the gen set ( example 4.5kva of a rated 5 kva set) , then turn the unit on and adjust the rpms up to the required voltage required
remember that an advertised kva is not the rated kva
rated kva is what the gen set will produce all day and is normally around 1kva less than advertised kva
so if you have a 6.5 kva gen set ,it will handle current peaks to 6.5 kva but will burn out if required to run long time at that load
if the gen set is 1000 watts then rated watts will be less ( 750-800) for long time use
Oct 22, 2015 | Electrical Supplies
Why do i only have 94 volt output on dewalt generator 2900 watt
It should change with the load, the more load you put on the line the magnetic field increases with the amperage and the gen will produce more output until its rating is reached. This happens especially if it has been sitting a long time.
Aug 15, 2014 | Dewalt DG2900 Heavy Duty 2900 Watt Gas...
Kubota GL11000 Diesel generator starts out delivering 120 volts, and within a few minutes will drop down and stay at 90 volts. Any ideas?
Is there an auto/man switch? Try both ways, just to see if the problem is in the auto controller. I believe on man it runs at high speed all the time, on auto only when it senses load. So, if the inverter doesn't draw, it backs off.
Nov 30, 2013 | Electrical Supplies
I have a coleman vangard generator 7000 watt and it will not produce power any more,when it quit producing power it was running and then just up and stopped producing power but the motor was still running....
gen sets require a dc voltage to energize the field windings and there is a voltage regulator built in
That could be faulty
talk with your local genset repair shop to get ideas
May 27, 2017 | Coleman Electrical Supplies
I have a vt1100c what sure the battery charge at??I got 13 v at Idle but it seem to go down the high you rev it,when i turn on my aux light bar it goes down to battery volts at idle w/o lights ---13.77...
Sounds like your battery is on the way out
But first check all connections from alternator to regulator/rectifier to battery. make sure they are all clean & make a good coonection
Ride Safe
Bike-doc
Please mark this as useful (if it has been!!)
Aug 05, 2009 | Honda VT 1100 C Motorcycles
Blower motor just stopped working in my 02 Town & Country
HI Zac the resistor shoud be bypassed in the high setting, If it is not working at all I would suspect the blower motor. If you have a volt meter you can check the power to the blower, should read about 12 volts with the switch in high position.
Jun 26, 2009 | 2002 Chrysler Town & Country
1991 CR 500 (reving to high on idle high serges)
take some wd 40 & spray around the carb boot while running to see if the idle drops for a few seconds. sounds like you have an intake side air leak causing a lean condition making the motor rev high.
Feb 16, 2009 | 2001 Honda CR 500 R
Electrical Supplies Logo
144 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
