Question about Sony Cyber-Shot DSC-W7 Digital Camera
Only turns on in play mode and wont take photos
I can only get the camera to turn on in play mode and then when you turn it to any other mode it turns off. I have tried numerous types of batteries and no luck. Any help?
  • 56789 Dec 19, 2007
    Can only view play mode. If I want to take a picture in any mode all I have is a black screen and am unable to take any pictures. Camera is useless at this point. Ive tried everything too, including new batteries. Any ideas?
I hv the same issue. Perhaps, from leaving out in the cold... No solution other than to send it in for repair, which is cost prohibitive. Time for a new camera, unfortunately.
Posted on Jan 06, 2008
Lamp lights without command no longer open in the minidv box black screen does not play, not record one more thing to do?
Solution 1 • Unlock focus area selector. • Auto-area AF selected for Custom Setting 2 (AFarea mode): choose another mode. • Press shutter-release button halfway to turn monitor o?¬? or activate exposure meter • Memory card is full, locked, or not inserted. • Flash is charging. • Camera is not in focus. • CPU lens with aperture ring attached without locking aperture at highest f/-number. • Non-CPU lens is attached: rotate camera mode dial to M. • Mode dial rotated to S after shutter speed of bulb selected in mode M: choose new shutter speed • P, S, A, and M modes: lower ?¬? ash. • Digital Vari-Program modes: turn ?¬? ash o?¬? Turn long exposure noise reduction o?¬? Turn long exposure noise reduction o?¬? Press multi selector up or down or rotate sub-command dial to choose photo information displayed Select All for Playback folder. Note that Current will automatically be selected when next photo is taken • Select On for Rotate tall. • Photo was taken with O?¬? selected for Auto image rotation. • Camera orientation was changed while shutter-release button was pressed in continuous shooting mode. • Camera was pointed up or down when photo was taken Use Nikon-approved card. • Card may be damaged. Contact retailer or Nikonauthorized service representative. • Delete unwanted ?¬ les or insert new memory car
Jan 26, 2011 | Samsung SC-D103 Mini DV Digital Camcorder
I dont have my manual with me .Could you please tell me how I view the 'photo that I have just taken on my Samsung S630
■ If the memory card is inserted in the camera, all the camera functions apply only
to the memory card.
■ If the memory card is not inserted in the camera, all the camera functions apply
only to the internal memory.
■ If you have turned on the camera by pressing the POWER button, you can press
the PLAY MODE button once to switch to Play mode and press it again to switch
to Recording mode.
■ You can turn the power on with the play mode button. The camera is turned on in
play mode. Press the play mode button again and the camera will be turned off.
■ You can set up the PLAY mode function by using the camera buttons and LCD
monitor.
2. The last image stored on the memory is
displayed on the LCD monitor.
● Playing back a still image
1. Select the PLAY mode by pressing the
play mode button ( ).
100-0007
3. Select an image that you want to play back
by pressing the LEFT / RIGHT button.
※ Press and hold the Left or Right button to
fast forward the images played.
AND here is the manual in free downloadable form
http://www.fixyourownprinter.com/forums/inkjet/24191
Oct 09, 2009 | Samsung Digimax S630 Digital Camera
My panasonic tz5 has started playing up. The lens moves in & out, will not focus & a message 'please turn camera off and on again' appears. This happens each time I want to use it. The battery is charged....
Same problem. At least for now, I solved problem, or at least camera is working again, by putting mode dial in "normal" (not A1) and holding down menu and down button (macro button) while turning camera on. Hope it works for you and continues to work for me.
Apr 18, 2009 | Panasonic DMC-TZ5 Digital Camera
Camera wont show my photos
Hi
First check whether display mode is on...
Check the battery...
U can remove the memory card and then using memory reader u can transfer the photo to ur system...
thank you
Dec 04, 2008 | Cameras
Put camera on screen come on lens came out thwn power went off now power light wont stay on long enough lens wont go back in
maybe this works: turn your camera on in play mode (if you have play button press it to turn on camera) and if your camera hase a shoot-play switch select play mode and then turn your camera on.) repeat this until lens goes back. I hope this works...
Nov 01, 2008 | Samsung Cameras
It won't take a photo with flash
Ah! I just figured it out. I read that the image stabilization doesn't work as well with a flash, so I turned it off. While in camera mode (not play mode), hit Menu, then scroll down to IS Mode. There are a few options. I chose "Off." And I was immediately able to take a photo. I'll play around with the other options (Continuous, Shoot Only, Panning). Now my only problem is that I JUST changed the batteries about 10 minutes ago and it's already telling me to change them again. Ug.
Jun 26, 2008 | Canon PowerShot A710 IS Digital Camera
Wont take photos outside
The symptoms you're describing could be caused by either the "Fireworks" special scene selection mode, or manual mode with too much exposure compensation. Look at your mode selector (back of the camera, upper left hand corner). Is the mode set to the still image setting (pointing at the liittle red camera)? Or is it set to special scene selection (SCN)?
If you are unintentionally in SCN mode, to get it out of "Fireworks", just turn the mode selector dial to select "still image" (pointing at the little red camera). Or you can also select an SCN mode more appropriate for outdoors. Just turn the dial to SCN, press the FUNC button, then press the left/right arrow buttons to select Portrait, Beach, Snow etc...
But if your mode selector is already in still image selection, then check to make sure that you're not in "Manual" picture mode. Turn the mode selector dial to "still picture mode" (pointing at the little red camera), then press the "FUNC" button. Now look at the bottom of the screen. If it says "Manual", press the "left" button controller once to select and put the camera in "Auto" still picture mode.
Feb 29, 2008 | Canon PowerShot A400 Digital Camera
Flash can not be turned on
I had the exact same problem as Dude2891 and it took me ages to work out what was wrong. The problem turned out to be that when I first got it and was playing with the menus, I managed to put it on burst mode, and in burst mode flash is automatically set to off. So you need to turn it on, press menu bottom left and scroll to REC mode (the first option) and then check that you're on Normal not Burst. That fixed it for me! See also Sony's tips at http://support.sony-europe.com/DIME/faq/faq.asp?l=en&c=DIME&sc=DSC&m=DSC-T200&f=mod_dsc_W_H_T
Hope that works guys, let me know how you get on.
Dec 16, 2007 | Sony Cybershot DSC-T200 Digital Camera
Fuhifilm finepix a700
Can you play back pictures and is the quality of these ok ? If you can but there is no image in capture mode then the CCD sensor is faulty and needs replacing.
Sep 10, 2007 | Cameras
Sony Cyber-Shot DSC-W7 Digital Camera Logo
73 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
