Question about Husqvarna Viking 1
As Iam quilting with my macine the top stitches are ok, but back of quilt the thread is all boggled up-Tension ??
    Novelist:
  • Husqvarna Expert
  • 371 Answers
Yes, this is a tension issue. Check your bobbin area. Make sure you have put the bobbin in the case with the H logo up and the thread pulls off the spool in a counter clockwise motion. Make sure the bobbin is sitting in the case and threaded through the "catch" on the bobbin case. Then leave a long piece of thread from the bottom, holding the end of the top thread, lower the needle for one revolution using the handwheel. Does the top thread catch the bobbin thread and pull it to the top? This is done without fabric. Your checking to determine if the top thread catches the bobbin thread and pulls it to the top. IIf it does not, it is most likely hook/needle timing. f it does, gently pull on the bobbin thread and determine if it pulls through with a little resistence (checking bobbin tension). Make sure you are using correct needle -- Schmitz or Inspira needles are recommended (Universal size 80 is standard). Make sure you are using Husqvarna Viking made for your machine -- original ones were green but there are some new colored ones but all have the Husqvarna logo on them. Otherwise take it to an authorized Husqvarna Viking dealer. You can find your closest dealer at the Husqvarna Viking website - http://www.husqvarnaviking.com/us Good luck
Posted on Sep 25, 2009
I am making a quilt on Husqvarna Lily 530 and cannot get my upper/lower thread equal for outlining design in quilt..book doesnot help me....any suggestions for stitch setting
Tension for stitching a quilt sandwich is tricky. It helps if you use the same color for top and bobbin thread,. If your quilting thread is not the same weight (either heavier or lighter) than thread used for regular sewing, then the bobbin tension may need to be adjusted. My quilting thread is lighter weight so I have a separate bobbin case whos tension has been adjusted specifically for quilting. The goal is have both threads meet in the middle of the sandwich. If the top thread is showing under the sandwich, you probably need to tighten the top tension so it will pull the bobbin thread up into the sandwich. Do the reverse if the bobbin thread shows on top.
It may also make a difference by changing the type and size needle. I tend to prefer a top-stitch needle. An embroidery or microtex may also work for you.
Machine Quilting Thread and Tension
Tension troubles on your quilting machine Try these tricks
5 Free Motion Quilting Problems and How to Fix Them
Mar 08, 2018 | Husqvarna Sewing Machines
My machine is adding loops under my stitches when I try to stitch a straight stitch, I am trying to machine stitch a quilt top!
Quilting is a bit more finicky than regular sewing. Be sure to ALWAYS RAISE the presser foot when threading the top thread. FWIW, I use a separate bobbin case for FMQ that I have tightened the tension to keep the bobbin thread from coming to the top of the sandwich, but I tend to use a finer thread for quilting so adjusting the bobbin takes care of it. In your case, however, it sounds like the top thread is staying under the fabric. I would try tightening the top tension. Also, install a brand new needle--a top stitch, embroidery, or microtex needle seem to work well for me. Test well on a sandwich made of the same fabric and batting and get it adjusted well before sewing on your quilt. Sometimes sewing speed will affect stitches under the fabric, or even on top.
Correcting Sewing Machine Tension for Free Motion Quilting NQC
LOOPS Tension or Speed
https://www.generations-quilt-patterns.com/machine-quilting-thread.html
https://www.generations-quilt-patterns.com/sewing-machine-tension.html
https://www.generations-quilt-patterns.com/machine-quilting-tension-problems.html
Feb 27, 2018 | Sewing Machines
My bottom stitch is perfect but my top stitch is sloppy,how do I fix that?
Is the top thread making a thread mess under the fabric? That usually means the top tension is too loose or the thread is not seated in the tension disk.
Remove the top thread from the machine.
ALWAYS RAISE the presser foot and rethread from the beginning.
Set the top tension at the midpoint and test your machine. Then adjust the tension until the two threads meet in the middle of the fabric.
Jan 02, 2018 | Sewing Machines
CANT QUILT WITH MY JUKI TENSION PROBLEMS
Okay, you've tried a lot of things. The question is this: is the thread snapping (where abouts in the path), or is it shredding at the needle? Here are a few more:
Remove the top thread, ALWAYS RAISE the presser foot, and rethread from the beginning.
Try different thread--perhaps a polyester thread like Isacord or Aurafil. (AVOID old or bargain bin thread.)
Try a different kind of needle (brand new needle!)--like a top-stitch, microtex, or embroidery. The top stitch needle has a larger scarf that will better protect the thread if shredding is the issue. (I use a special bobbin case that I've increased the tension for Isacord thread and I use the same thread in top and bobbin.) I also decrease the top tension a tad so the bobbin thread will not pull to the top. You may need to install brand-new needles several times on one quilt when they get dull.
Usually an 80 or 90 needle will work for FMQ through a fabric/batting sandwich.
Check that the needle's eye is the appropriate size for the thread (also a cause of shredding thread).
Set the upper tension at the midway point perhaps a bit looser for FMQ (this tension will probably need to be tweaked for your particular machine due to wear and age).
Use an FMQ foot and drop the feed dogs. A Supreme Slider (avlb on the internet) is very helpful in helping move the quilt while doing FMQ.
Work at a moderate but steady pace. I find a faster speed while FMQ gets me into trouble...like spots I can't get out of, overlapping stitches, or outside the quilt edge.
FWIW, I still get some skipped stitches with FMQ. Usually, it happens when I move the fabric too fast, especially around a curve. I have a tendency of speeding up while going around a curve that will cause skipped stitches or eyelashing.
I'm also wondering if there is something to do with the fabric and/or batting you are using...like is it Batik? Batik is very tightly woven and presents some particular challenges. The type of batting could be more dense, making it harder for the needle to penetrate the sandwich. Also, pulling or stretching the fabric can cause skipped stitches.
Basic Maintenance Tension Skipped Stitches
Here What to Do if Your Sewing Machine is Skipping Stitches
10 reasons for skipped stitches
If you see no improvement in your machine's stitching, you may want to have it serviced.
Apr 28, 2017 | Juki Sewing Machines
Stitches too small
TIP: A general rule of thumb is that if the stitch looks bad on the top it is the bottom tension.
If the stitch looks bad on the bottom it is the upper tension. The upper and lower threads play
tug of war with each other.
Tension
You need correct tension on the top and bottom threads, but you must also have correct tension on
the quilt held between the rails. You should have a small amount of "sag" in your fabric. This allows
enough movement of your quilt layers for the needle to penetrate and make good stitches.
Before you start making adjustments to your machine ask yourself, "What changed?" If your machine
was stitching great and all of a sudden it has loopies on the back or puckers, "What changed?" Did
you just change the bobbin? Did you just lift the take up rail? Did you lower the take up rail after
finishing your last quilt? Did you recently change the needle? Did you just roll the quilt?
If the take up rail with the quilted portion of your quilt is too high, it will result in poor stitch quality. You
need a finger tip space between the quilt and the machine bed. Higher will result in poor stitch
quality, too low and the quilt will create a drag on your machine's movement.
Look at your bobbin, a sloppy wound bobbin will not create a good stitch. Make sure that the threads
on the bobbin are snug and evenly wound. Check to see if there is a piece of lint in the bobbin case
Dec 19, 2016 | Sewing Machines
Husqvarna sapphire 870 quilt
Could be several things.
First, install a brand new needle, perhaps a top-stitch needle will work better because it has a groove in the shaft that protects the thread. Make sure the needle is the appropriate size for the thread you are using--a needle eye that is too small will cause the thread to hang or shred. When the needle penetrates the sandwich, the top thread forms a loop. If the eye is too small, the thread will not come back up through the sandwich, leaving a loop under the fabric.
Set the top tension to the midway point and retest your machine on a quilt sandwich made of the same fabric layers as your project.. Tension problems are more evident when sewing multiple layers of fabric, so tweak the tension until the top and bobbin threads meet in the middle of the sandwich.
I don't believe you will have to adjust the bobbin tension, but in case you do, be very careful. Mark the tension screw setting FIRST so you can reverse any changes you make. Bobbin adjustments are made in very SMALL increments. Because I tend to use a lighter weight thread for my quilting, I have a specific bobbin case that is adjusted for my quilt thread and I keep my other bobbin for regular sewing. Then I don't have to keep adjusting the bobbin tension when going from sewing a quilt to something else.
Some machines do better with certain brands of threads than others.
Adjusting Sewing Machine Tension to Prevent Problems
Mar 02, 2018 | Sewing Machines
I'm using a Janome 1600 DBX on my Grace quilt frame. It keeps skipping stitches and breaking the thread. I put in a new # 16 Janome needle - made sure it was installed correctly, and tried 30 weight and...
The tension is not right and you are moving the machine to fast. Go back to your 50 weight thread top and bottom. Have you got a quilting foot on and the foot in the down position
Dec 01, 2017 | Janome 1600P-DB Mechanical Sewing Machine
Problems with tension on machine
Yes, you need to set your top tension higher. and make sure that the top quilt isn't stretched too tight.
Sep 23, 2009 | Husqvarna Viking 1
Skipped stitches & looping on the bottom of Quilt
Try a different needle. Use a quilting or topstitch or even a metallic needle - one that has a larger scarf than normal. The scarf is the groove at the back of the needle where the thread goes while the stitch is being formed. Quilting threads often need more "room" there. I have been told that the Inspira quilting needles are good because they have a thread groove on the front and the back of the needle. Not tried them personally but might be worthwhile for you to consider.
For the looping, you could fiddle with your tensions a little either loosening the bobbin tension or tightening the top, or both. Only ever do this in very small increments. But the good news is that even the "professional" quilters do not have perfect quilt backs - just have a look at them at quilt shows!
Pam M.
Apr 27, 2009 | Brother LS-2125 Mechanical Sewing Machine
Needle thread breaks while quilting on machine frame
My friend and I both have the Juki 98Q but on different frames - we were both having problems (needles breaking, thread getting tangled) we removed the thin metal thing inside the bobbin case and have had no problems since (over a year now!).
Nov 01, 2008 | Juki TL-98Q
Sewing Machines Logo
175 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
